    I get error in magic mirror when am installing the magic mirror the cmd: npm run start
    20 Posts 3 Posters 6.9k Views 3 Watching
      sdetweil @Chethan
      @chethan you must be in the MagicMirror folder
      cd MagicMirror
      npm start
        Chethan @0m4r
        @0m4r yes i allready install whatin magic mirror doc i follow the same steps
        but its not working
          Chethan @sdetweil
          Yes am in that folder only before start the magic mirror i use this steps: npm install after that npm run
          but error look like the same check bellow
          magicmirror@2.14.0 start /home/pi/MagicMirror
          /home/pi/MagicMirror/node_modules/electron/index.js:14
          throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
          Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
          at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
          at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
          at Module._compile (internal/modules/cjs/loader.js:1063:30)
          at Object.Module._extensions…js (internal/modules/cjs/loader.js:1092:10)
          at Module.load (internal/modules/cjs/loader.js:928:32)
          at Function.Module._load (internal/modules/cjs/loader.js:769:14)
          at Module.require (internal/modules/cjs/loader.js:952:19)
          at require (internal/modules/cjs/helpers.js:88:18)
          at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! magicmirror@2.14.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.14.0 start script.
          npm ERR! /home/pi/.npm/_logs/2021-02-12T12_06_40_294Z-debug.log
          help me any one
            Chethan @0m4r
            @0m4r when am running in the server its working but when am try to run in the local its not working
            0m4r0 1 Reply Last reply Reply Quote 0
            • 0m4r0 Offline
              0m4r Module Developer @Chethan
              @chethan what is the Os you have installed it on? it it is the “lite” version it will not work. Electron requires a GUI interface to run
              https://github.com/0m4r
                Chethan @0m4r
                @0m4r raspberry pi 4
                • 0m4r0 Offline
                  @chethan yeah, thanks, but what operating system?
                    Chethan @0m4r
                    i dont know what is the software that is being fresher in this
                      sdetweil @Chethan
                      @chethan are u running in desktop mode, or text mode command prompt.
                      must be desktop mode, electron requires graphics mode
                      C 2 Replies Last reply Reply Quote 0
                        Chethan @sdetweil
                        @sdetweil no am running my own Samsung desktop I connect raspberry to that display
