    hello lucy
    12 Posts 3 Posters 2.9k Views 3 Watching
      derick4963 @Mykle1
      @mykle1
      I am new to programing stuff and MM. Not sure if the below log useful.
      Once i started MM, there is green color mic icon with command please then just a sec become white color mic icon with error
      Below is the log
      pi@raspberrypi:~/MagicMirror $ npm start dev
      magicmirror@2.14.0 start /home/pi/MagicMirror
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “dev”
      [19.02.2021 02:17.31.097] [LOG] Starting MagicMirror: v2.14.0
      [19.02.2021 02:17.31.103] [LOG] Loading config …
      [19.02.2021 02:17.31.109] [LOG] Loading module helpers …
      [19.02.2021 02:17.31.111] [LOG] No helper found for module: MMM-ViewNotifications.
      [19.02.2021 02:17.32.415] [LOG] Initializing new module helper …
      [19.02.2021 02:17.32.416] [LOG] Module helper loaded: Hello-Lucy
      [19.02.2021 02:17.32.418] [LOG] No helper found for module: alert.
      [19.02.2021 02:17.32.554] [LOG] Initializing new module helper …
      [19.02.2021 02:17.32.555] [LOG] Module helper loaded: updatenotification
      [19.02.2021 02:17.32.557] [LOG] No helper found for module: clock.
      [19.02.2021 02:17.32.905] [LOG] Initializing new module helper …
      [19.02.2021 02:17.32.906] [LOG] Module helper loaded: calendar
      [19.02.2021 02:17.32.906] [LOG] No helper found for module: compliments.
      [19.02.2021 02:17.32.907] [LOG] No helper found for module: currentweather.
      [19.02.2021 02:17.32.908] [LOG] No helper found for module: weatherforecast.
      [19.02.2021 02:17.32.930] [LOG] Initializing new module helper …
      [19.02.2021 02:17.32.930] [LOG] Module helper loaded: newsfeed
      [19.02.2021 02:17.32.931] [LOG] All module helpers loaded.
      [19.02.2021 02:17.33.031] [LOG] Starting server on port 8080 …
      [19.02.2021 02:17.33.040] [WARN] You’re using a full whitelist configuration to allow for all IPs
      [19.02.2021 02:17.33.050] [LOG] Server started …
      [19.02.2021 02:17.33.051] [LOG] Connecting socket for: Hello-Lucy
      [19.02.2021 02:17.33.052] [LOG] Starting module helper: Hello-Lucy
      [19.02.2021 02:17.33.053] [LOG] Connecting socket for: updatenotification
      [19.02.2021 02:17.33.054] [LOG] Connecting socket for: calendar
      [19.02.2021 02:17.33.055] [LOG] Starting node helper for: calendar
      [19.02.2021 02:17.33.056] [LOG] Connecting socket for: newsfeed
      [19.02.2021 02:17.33.056] [LOG] Starting node helper for: newsfeed
      [19.02.2021 02:17.33.057] [LOG] Sockets connected & modules started …
      [19.02.2021 02:17.33.326] [ERROR] Whoops! There was an uncaught exception…
      [19.02.2021 02:17.33.333] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
      at Server.setupListenHandle [as _listen2] (net.js:1300:14)
      at listenInCluster (net.js:1348:12)
      at GetAddrInfoReqWrap.doListen [as callback] (net.js:1487:7)
      at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
      code: ‘EADDRINUSE’,
      errno: ‘EADDRINUSE’,
      syscall: ‘listen’,
      address: ‘127.0.0.1’,
      port: 8080
      [19.02.2021 02:17.33.335] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [19.02.2021 02:17.33.335] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [19.02.2021 02:17.33.353] [LOG] Launching application.
      [19.02.2021 02:17.33.397] [WARN] (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently “false”. It will change to be “true” in Electron 9. For more information please check https://github.com/electron/electron/issues/18397
      [19.02.2021 02:18.24.112] [LOG] Shutting down server…
      [19.02.2021 02:18.24.117] [LOG] Stopping module helper: Hello-Lucy
      [19.02.2021 02:18.24.118] [LOG] Stopping module helper: updatenotification
      [19.02.2021 02:18.24.120] [LOG] Stopping module helper: calendar
      [19.02.2021 02:18.24.122] [LOG] Stopping module helper: newsfeed
      Mykle1M S 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @derick4963
        @derick4963 said in hello lucy:
        EADDRINUSE
        You have a conflict with port 8080 that needs to be resolved
          sdetweil @derick4963
          @derick4963 maybe u have an instance running already w pm2
          pm2 status
          pm2 stop all
          then try your npm start
            derick4963 @sdetweil
            @ Mykle1
            I have reformat with clean MM with only Hello-lucy and default module but still getting white mic with ERROR.
            [20.02.2021 15:27.50.505] [LOG] Starting MagicMirror: v2.14.0
            [20.02.2021 15:27.50.511] [LOG] Loading config …
            [20.02.2021 15:27.50.516] [LOG] Loading module helpers …
            [20.02.2021 15:27.51.806] [LOG] Initializing new module helper …
            [20.02.2021 15:27.51.808] [LOG] Module helper loaded: Hello-Lucy
            [20.02.2021 15:27.51.810] [LOG] No helper found for module: alert.
            [20.02.2021 15:27.51.925] [LOG] Initializing new module helper …
            [20.02.2021 15:27.51.927] [LOG] Module helper loaded: updatenotification
            [20.02.2021 15:27.51.928] [LOG] No helper found for module: clock.
            [20.02.2021 15:27.52.265] [LOG] Initializing new module helper …
            [20.02.2021 15:27.52.266] [LOG] Module helper loaded: calendar
            [20.02.2021 15:27.52.266] [LOG] No helper found for module: compliments.
            [20.02.2021 15:27.52.267] [LOG] No helper found for module: currentweather.
            [20.02.2021 15:27.52.268] [LOG] No helper found for module: weatherforecast.
            [20.02.2021 15:27.52.288] [LOG] Initializing new module helper …
            [20.02.2021 15:27.52.289] [LOG] Module helper loaded: newsfeed
            [20.02.2021 15:27.52.290] [LOG] All module helpers loaded.
            [20.02.2021 15:27.52.367] [LOG] Starting server on port 8080 …
            [20.02.2021 15:27.52.381] [LOG] Server started …
            [20.02.2021 15:27.52.382] [LOG] Connecting socket for: Hello-Lucy
            [20.02.2021 15:27.52.383] [LOG] Starting module helper: Hello-Lucy
            [20.02.2021 15:27.52.384] [LOG] Connecting socket for: updatenotification
            [20.02.2021 15:27.52.385] [LOG] Connecting socket for: calendar
            [20.02.2021 15:27.52.386] [LOG] Starting node helper for: calendar
            [20.02.2021 15:27.52.387] [LOG] Connecting socket for: newsfeed
            [20.02.2021 15:27.52.388] [LOG] Starting node helper for: newsfeed
            [20.02.2021 15:27.52.389] [LOG] Sockets connected & modules started …
            [20.02.2021 15:27.52.656] [LOG] Launching application.
            [20.02.2021 15:27.52.689] [WARN] (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently “false”. It will change to be “true” in Electron 9. For more information please check https://github.com/electron/electron/issues/18397
            [20.02.2021 15:27.56.904] [LOG] Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
            [20.02.2021 15:27.57.027] [LOG] Create new news fetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
            [20.02.2021 15:27.57.082] [INFO] Checking git for module: Hello-Lucy
            [20.02.2021 15:27.58.320] [INFO] Newsfeed-Fetcher: Broadcasting 56 items.
            [20.02.2021 15:27.58.952] [INFO] Calendar-Fetcher: Broadcasting 10 events.
            [20.02.2021 15:32.58.623] [INFO] Newsfeed-Fetcher: Broadcasting 56 items.
            [20.02.2021 15:33.00.255] [INFO] Calendar-Fetcher: Broadcasting 10 events.
            ^C
              I don’t know why you would have done that yet. Did you attempt to rectify the port conflict? Did you follow the instructions given by sdetweil? When given help, it is customary (and polite) to let the helper know if you followed their directions and the result. Anyway . .
              What hardware are you using?
              What OS is on the hardware?
              How did you install MM?
              Run arecord -l in a terminal and post the output.
              Please use a code block when posting any code on the forum. It makes the code much easier to read for people trying to help you.
              Click the icon with the yellow box around it and post your code accordingly.
                derick4963 @Mykle1
                @mykle1
                pi@raspberrypi:~ $ arecord -l
                **** List of CAPTURE Hardware Devices ****
                card 2: UM02 [UM02], device 0: USB Audio [USB Audio]
                  Subdevices: 1/1
                  Subdevice #0: subdevice #0
                pi@raspberrypi:~ $
                Yes, by changing the the port from 8080 to 8188.
                Yes, but didnt work.
                Sorry first time using the forum and new to all these. Will take note of it when using the forum.
                raspberry pi 4b, 4GB ram. 32GB sd card
                pi@raspberrypi:~ $ uname -a
                Linux raspberrypi 5.10.11-v7l+ #1399 SMP Thu Jan 28 12:09:48 GMT 2021 armv7l GNU/Linux
                pi@raspberrypi:~ $ cat /etc/os-release
                PRETTY_NAME=“Raspbian GNU/Linux 10 (buster)”
                NAME=“Raspbian GNU/Linux”
                VERSION_ID=“10”
                VERSION=“10 (buster)”
                VERSION_CODENAME=buster
                ID=raspbian
                ID_LIKE=debian
                HOME_URL=“http://www.raspbian.org/”
                SUPPORT_URL=“http://www.raspbian.org/RaspbianForums”
                BUG_REPORT_URL=“http://www.raspbian.org/RaspbianBugs”
                By following the offical Magic mirror website
                S Mykle1M 2 Replies Last reply Reply Quote 0
                  @derick4963 how did u confirm mic?
                  arecord test.wav
                  speak something
                  ctrl-c to stop recording
                  aplay test.wav
                  do u hear what u said before,?
                    Just confirming your microphone entry in the Lucy config entry
                    microphone: "2,0", - Yes?
                      @sdetweil said in hello lucy:
                      aplay test.wav
                      Yes i have record and able to hear the recoded audio.
                        derick4963 @Mykle1
                        @mykle1
                        Yes
                        below is my config
                        disabled: false,
                        module: "Hello-Lucy",
                        position: "top_center",
                            keyword: 'HELLO LUCY',              // keyword to activate listening for a command/sentence
                            timeout: 15,                        // timeout listening for a command/sentence
                            standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                            microphone: "2,0",                  // run "arecord -l" card # and device # mine is "0,0"
                            sounds: ["1.mp3", "11.mp3"],        // welcome sound at startup. Add several for a random greetings
                            confirmationSound: "ding.mp3",      // name and extension of sound file
                            startHideAll: true,                 // All modules start as hidden EXCEPT PAGE ONE
                            //*** Page One is your default startup page *** This overrides startHideAll: true,
                            pageOneModules: ["Hello-Lucy","MMM-EasyPix"],                     // default modules to show on page one/startup
                            //pageTwoModules: ["Hello-Lucy", "MMM-BMW-DS", "MMM-EventHorizon"], // modules to show on page two
                            //pageThreeModules: ["Hello-Lucy", "MMM-Lunartic"],                 // modules to show on page three
                            //pageFourModules: ["Hello-Lucy", "MMM-PC-Stats"],                  // modules to show on page four
                            //pageFiveModules: ["Hello-Lucy", "MMM-Searchlight"],               // modules to show on page five
                            //pageSixModules: ["Hello-Lucy", "MMM-NOAA3"],                      // modules to show on page six
                            //pageSevenModules: ["Hello-Lucy", "MMM-Recipe"],                   // modules to show on page seven
                            //pageEightModules: ["Hello-Lucy", "MMM-rfacts"],                   // modules to show on page eight
                            //pageNineModules: ["Hello-Lucy", "MMM-History"],                   // modules to show on page nine
                            //pageTenModules: ["Hello-Lucy", "MMM-HardwareMonitor"]             // modules to show on page ten
