    Head first developing MM module for extreme beginners
    27 Posts 9 Posters 31.9k Views 12 Watching
      sdetweil @Dobi
      @dobi two things
      when the DomObject Created method is called, its POSSIBLE that the elements are not yet accessible… so your code fails as the document.getElementbyID returns null…
      second, do you have a position: set in the module def in config.js?
      third and MOST important
      the module NAME must match the folder name AND the filename and the register in the file…
      so, the filename is MMM-cookbook.js
      therefore ALL the things must be called MMM-cookbook
      git clone will name the folder the name of the github repo
      (unless u add an extra part to git clone repo_url output_folder_name)
      I fixed all those and the module displays the countdown/up each second
        Dobi @sdetweil
        @sdetweil ahh thank you for these information I will give it a try.
          Dobi
          @sdetweil I gave it a try but without differences :(
          I made a new git repo : https://github.com/Dobherrmann/MMM-cookbook.git
          Now there I should have the same name in the repo like my module.
          my config. js looks like this (I gave it a position):
                module: "MMM-cookbook",
                position: "middle_center",
                  header: "My Cookbook",
                  foo: "I'm the King of the world!"
          I started to debug “my code” a little bit and I found this when I want to send a socket notification:
          self.sendSocketNotification("DO_YOUR_JOB", this.count);
          					console.log("Notfication", this.sendSocketNotification("DO_YOUR_JOB", this.count))
          					this.subElementUp.innerHTML = "Count UP:" + this.count
          On my console i get the feedback that “this.sendSocketNotification(“DO_YOUR_JOB”, this.count” is undefined. It looks like that this function is unkown.
            sdetweil @Dobi
            @dobi u are inside a callback. change the ‘this’ to ‘self’ like the self.sendSocketNotification
            ‘this’ is always tricky. depends on the context, and some of the programming idioms used
            that’s why we typically see
            var self = this;
            at the beginning of functions that have callbacks or .then() used inside
              Dobi @sdetweil
              @sdetweil ok, but it dosen’t change something.
              notificationReceived: function (notification, payload, sender) {
              		self = this;
              		switch (notification) {
              			case "DOM_OBJECTS_CREATED":
              				var timer = setInterval(() => {
              					//this.updateDom()
              					console.log(`self.sendSocketNotification("DO_YOUR_JOB", this.count)`, self.sendSocketNotification("DO_YOUR_JOB", this.count))
              					this.count++
              				}, 1000)
              				break
              Now i could post a picture of my console
                sdetweil @Dobi
                @dobi show the source code page. u had to fix both counters
                sources tab, modules, mmm-cookbook, mmm-cookbook.js
                  sdetweil @Dobi
                  @dobi
                  but u didn’t change this.count to self.count
                  in all the places
                    Dobi @sdetweil
                    @sdetweil I replaced all this. … calls to self. … but I don’t get a change. Is there a way that I can check to check that I can check that the function is loaded correctly from the kernal?
                      sdetweil @Dobi
                      @dobi view the source in the dev window
                      what u showed above is not changed
                        Dobi @sdetweil
                        sorry I only updated it on github
                        		var self = this;
                        					//this.updateDom()
                        					self.sendSocketNotification("DO_YOUR_JOB", self.count);
                        					console.log(`self.sendSocketNotification("DO_YOUR_JOB", this.count)`, self.sendSocketNotification("DO_YOUR_JOB", self.count))
                        					self.subElementUp.innerHTML = "Count UP:" + self.count
                        					self.count++
                        				}, 1000)
                        				break
                          sdetweil @Dobi
                          @dobi and in the console.log too
                            Dobi @sdetweil
                            @sdetweil Hey sorry for my quite late response. But I wanted to tell you that I found my error it was quite stupid. I had to restart my raspi. After a restart the node_helper worked fine :)
                            I wrote my first module.
                            Thanks for your patient
                            S cowboysdudeC 2 Replies Last reply Reply Quote 2
                              sdetweil @Dobi
                              @dobi glad you found it… so much fun!!
                              • cowboysdudeC Offline
                                cowboysdude Module Developer @Dobi
                                @dobi See you can do it! Great job and glad that it all worked out for you! :) This is what this project is about…learning.
                                NOW you can make your mirror your own by showing information that you want and/or need to see…
                                  riich
                                  Anyone have an idea on how to display an image instead of a line. I downloaded a jpeg image of a dog and I would like to display that instead of
