    Head first developing MM module for extreme beginners
    27 Posts 9 Posters 32.2k Views 12 Watching
      Dobi @sdetweil
      @sdetweil ok, but it dosen’t change something.
      notificationReceived: function (notification, payload, sender) {
      		self = this;
      		switch (notification) {
      			case "DOM_OBJECTS_CREATED":
      				var timer = setInterval(() => {
      					//this.updateDom()
      					self.sendSocketNotification("DO_YOUR_JOB", this.count);
      					console.log(`self.sendSocketNotification("DO_YOUR_JOB", this.count)`, self.sendSocketNotification("DO_YOUR_JOB", this.count))
      					this.subElementUp.innerHTML = "Count UP:" + this.count
      					this.count++
      				}, 1000)
      				break
      Now i could post a picture of my console
      S 2 Replies Last reply
        sdetweil @Dobi
        @dobi show the source code page. u had to fix both counters
        sources tab, modules, mmm-cookbook, mmm-cookbook.js
          sdetweil @Dobi
          @dobi
          but u didn’t change this.count to self.count
          in all the places
          D 1 Reply Last reply
            Dobi @sdetweil
            @sdetweil I replaced all this. … calls to self. … but I don’t get a change. Is there a way that I can check to check that I can check that the function is loaded correctly from the kernal?
              sdetweil @Dobi
              @dobi view the source in the dev window
              what u showed above is not changed
                Dobi @sdetweil
                sorry I only updated it on github
                		var self = this;
                					//this.updateDom()
                					self.sendSocketNotification("DO_YOUR_JOB", self.count);
                					console.log(`self.sendSocketNotification("DO_YOUR_JOB", this.count)`, self.sendSocketNotification("DO_YOUR_JOB", self.count))
                					self.subElementUp.innerHTML = "Count UP:" + self.count
                					self.count++
                				}, 1000)
                				break
                  sdetweil @Dobi
                  @dobi and in the console.log too
                    Dobi @sdetweil
                    @sdetweil Hey sorry for my quite late response. But I wanted to tell you that I found my error it was quite stupid. I had to restart my raspi. After a restart the node_helper worked fine :)
                    I wrote my first module.
                    Thanks for your patient
                    S cowboysdudeC 2 Replies Last reply
                    Reply Quote 2
                      sdetweil @Dobi
                      @dobi glad you found it… so much fun!!
                      • cowboysdudeC
                        cowboysdude Module Developer @Dobi
                        @dobi See you can do it! Great job and glad that it all worked out for you! :) This is what this project is about…learning.
                        NOW you can make your mirror your own by showing information that you want and/or need to see…
                          riich
                          Anyone have an idea on how to display an image instead of a line. I downloaded a jpeg image of a dog and I would like to display that instead of
