    problems with hot word
    6 Posts 5 Posters 680 Views 5 Watching
    • K Offline
      Karalica-Kir
      [2021-03-26 09:53:46.150] [LOG] [HOTWORD] begins.
      [2021-03-26 09:53:46.524] [LOG] [HOTWORD] Detector starts listening.
      [2021-03-26 09:53:49.333] [LOG] [HOTWORD:LPCM16] arecord: main:828: audio open error: No such file or folder
      [2021-03-26 09:53:49.838] [LOG] [HOTWORD] Final Result: { detected: false }
      I can’t find this module on GitHub and reinstall it correctly
        BravoOscar
        @karalica-kir said in problems with hot word:
        HOTWORD
        I dont know the module by there is a module with the same name on GitHub:
        https://github.com/lixiljp/MMM-Hotword
        • K Offline
          Karalica-Kir @BravoOscar
          @bravooscar i can’t understand what’s wrong
          pi@Pi:~/MagicMirror/modules $ cd MMM-Hotword
          pi@Pi:~/MagicMirror/modules/MMM-Hotword $ npm install
          npm WARN deprecated hawk@3.1.3: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
          npm WARN deprecated hoek@2.16.3: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
          npm WARN deprecated cryptiles@2.0.5: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
          npm WARN deprecated sntp@1.0.9: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
          npm WARN deprecated boom@2.10.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
          > snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
          > node-pre-gyp install --fallback-to-build
          node-pre-gyp ERR! Tried to download(403): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
          node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.3.1 and node@10.24.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
          node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
          internal/modules/cjs/loader.js:638
              throw err;
          Error: Cannot find module 'nan'
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
              at Function.Module._load (internal/modules/cjs/loader.js:562:25)
              at Module.require (internal/modules/cjs/loader.js:692:17)
              at require (internal/modules/cjs/helpers.js:25:18)
              at [eval]:1:1
              at Script.runInThisContext (vm.js:122:20)
              at Object.runInThisContext (vm.js:329:38)
              at Object.<anonymous> ([eval]-wrapper:6:22)
              at evalScript (internal/bootstrap/node.js:590:27)
              throw err;
              at [eval]:1:1
          gyp: Call to 'node -e "require('nan')"' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
          gypgyp ERR! configure error
           ERR! gyp configure errorERR! stack Error: `gyp` failed with exit code: 1
          gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
          gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
          gyp
          ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
          gyp ERR! System Linux 5.10.17-v7+
          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm"
          gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
          gypgyp ERR! node -v v10.24.0
          gyp ERR! node-gyp -v v5.1.0
          gyp  ERR! not ok
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
          gyp ERR! not ok
          node-pre-gyp ERR! build error
          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm' (1)
          node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
          node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
          node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
          node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
          node-pre-gyp ERR! System Linux 5.10.17-v7+
          node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
          node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
          node-pre-gyp ERR! node -v v10.24.0
          node-pre-gyp ERR! node-pre-gyp -v v0.6.39
          node-pre-gyp ERR! not ok
          npm WARN MMM-Hotword@1.0.0 No repository field.
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! snowboy@1.3.1 install: `node-pre-gyp install --fallback-to-build`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the snowboy@1.3.1 install script.
          npm ERR!     /home/pi/.npm/_logs/2021-03-26T08_43_05_897Z-debug.log
          lavolp3L S 2 Replies Last reply Reply Quote 1
          • lavolp3L Offline
            lavolp3 Module Developer @Karalica-Kir
            @karalica-kir
            Some dependencies of this module are outdated.
            Snowball did not install. There is an instruction in the README on github. Have you had a look at that?
            When you fail to install snowboy itself.
            cd ~/MagicMirror/modules/MMM-Hotword
            npm install --save snowboy   # Sometimes it could fail, retry again.
            If you doubt errors are caused by different node.JS version, you can try to >compile it by yourself.
            cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
            ./node_modules/node-pre-gyp/bin/node-pre-gyp clean configure build
            If there is no special errors(except some warnings), you can use it. test it with >serveronly mode.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
              sdetweil @Karalica-Kir
              @karalica-kir missing man
              npm install man
              then retry to install smowboy
              bugsounetB 1 Reply Last reply Reply Quote 0
              • bugsounetB Offline
                bugsounet Banned @sdetweil
                @Karalica-Kir : I have deprecied this module, last year. I code another very more simple
                Now, I think you use a very old source (When i close MMM-Hotword it’s the v2.4.0… and you use v1)
                Good luck for using it ;)
