Text to config.js
Hi !
I am new on Rasberry Pi.
Trying to add text from MMM-ImagesPhotos to MagicMirror/config.js :/* Magic Mirror Config Sample
*- By Michael Teeuw https://michaelteeuw.nl
- MIT Licensed.
- For more information on how you can configure this file
- See https://github.com/MichMich/MagicMirror#configuration
var config = {
// - “0.0.0.0”, “::” to listen on any interface
// Default, when address config is left out or empty, is “localhost”
port: 8080,
basePath: “/”, // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],useHttps: false, // Support HTTPS or not, default "false" will use HTTP httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true language: "en", logLevel: ["INFO", "LOG", "WARN", "ERROR"], // Add "DEBUG" for even more logging timeFormat: 24, units: "metric", // serverOnly: true/false/"local" , // local for armv6l processors, default // starts serveronly and then starts chrome browser // false, default for all NON-armv6l devices // true, force serveronly mode, because you want to.. no UI on this device modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "US Holidays", position: "top_left", config: { calendars: [ { symbol: "calendar-check", url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics" } ] } }, { module: "MMM-ImagesPhotos", position: "middle_center", config: { opacity: 0.9, animationSpeed: 500, updateInterval: 5000, }
module: “compliments”,
position: “lower_third”
module: “currentweather”,
position: “top_right”,
locationID: “5128581”, //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
appid: “YOUR_OPENWEATHER_API_KEY”
module: “weatherforecast”,
header: “Weather Forecast”,
module: “newsfeed”,
position: “bottom_bar”,
feeds: [
title: “New York Times”,
url: “https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml”
showSourceTitle: true,
showPublishDate: true,
broadcastNewsFeeds: true,
broadcastNewsUpdates: true
};/*************** DO NOT EDIT THE LINE BELOW ***************/
if (typeof module !== “undefined”) {module.exports = config;}Got wrong position for text when past in ?
Litek
@litek all that doesn’t go in config.js
just a little section
{ module: "?????", position:"??!!!??", config :{ . . } }
see the topics on my signature below
Hi again !
can you add this in to config js for me :
so i can se how the file look like ?Here is an example of an entry in
config.js
{ module: "MMM-ImagesPhotos", position: "middle_center", config: { opacity: 0.9, animationSpeed: 500, updateInterval: 5000, } },
@litek well,
this is the end of the config.js file
{ module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true, broadcastNewsFeeds: true, broadcastNewsUpdates: true } }, ] // < ------- this is the end of the module list (the start is [ above };
so, you place your new module BEFORE the end of the list and AFTER the } of the prior module
{ module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true, broadcastNewsFeeds: true, broadcastNewsUpdates: true } }, // < --- end of prior module // new module goes here { module: "MMM-ImagesPhotos", position: "middle_center", config: { opacity: 0.9, animationSpeed: 500, updateInterval: 5000, } }, ] // < --- end of module list };
ALWAYS check to make sure end of prior module entry } ends with a comma (means more to follow)
File wonr run :
/* Magic Mirror Config Sample * * By Michael Teeuw https://michaelteeuw.nl * MIT Licensed. * * For more information on how you can configure this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "0.0.0.0", "::" to listen on any interface // Default, when address config is left out or empty, is "localhost" port: 8080, basePath: "/", // The URL path where MagicMirror is hosted. If you are using a Reverse proxy // you must set the sub path here. basePath must end with a / ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], useHttps: false, // Support HTTPS or not, default "false" will use HTTP httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true language: "en", logLevel: ["INFO", "LOG", "WARN", "ERROR"], // Add "DEBUG" for even more logging timeFormat: 24, units: "metric", // serverOnly: true/false/"local" , // local for armv6l processors, default // starts serveronly and then starts chrome browser // false, default for all NON-armv6l devices // true, force serveronly mode, because you want to.. no UI on this device modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "US Holidays", position: "top_left", config: { calendars: [ { symbol: "calendar-check", url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "New York", locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "New York", locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true, broadcastNewsFeeds: true, broadcastNewsUpdates: true } }, ] }; module: "MMM-ImagesPhotos", position: "middle_center", config: { opacity: 0.9, animationSpeed: 500, updateInterval: 5000, } /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;} [29.03.2021 18:15.24.533] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:107 position: "middle_center", ^ SyntaxError: Unexpected token ':' at Module._compile (internal/modules/cjs/loader.js:896:18) at Object.Module._extensions..js (internal/modules/cjs/loader.js:986:10) at Module.load (internal/modules/cjs/loader.js:816:32) at Module._load (internal/modules/cjs/loader.js:728:14) at Function.Module._load (electron/js2c/asar.js:748:26) at Module.require (internal/modules/cjs/loader.js:853:19) at require (internal/modules/cjs/helpers.js:74:18) at loadConfig (/home/pi/MagicMirror/js/app.js:70:12) at App.start (/home/pi/MagicMirror/js/app.js:217:3) at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:129:7)
Need some help
@litek cause u put it in the wrong place
Hi again !
Can you make the file for me and wherto so i will understand it ?Please
@litek no. I gave u the very detailed instructions
@litek Sam does not want to do all the work for you and I understand him.
You can see in the file a lot of module entries, and you need to put your module entry in like them.modules
is an array containing objects (if that does not ring a bell you should consider going a bit into javascript before moving much further).The structure of this array is like this:
modules: [ { module: '', position: '...', config: { ... }, }, { module: '', position: '...', config: { ... }, }, { module: '', position: '...', config: { ... }, } ]
You need to take care to use commas as seperators, IN an array or an object, semicolons are always misplaced.
Hope that helps. -
@lavolp3 I gave him exactly where
