    Text to config.js
    12 Posts 3 Posters 1.8k Views 3 Watching
    • L Offline
      Litek
      Hi !
      I am new on Rasberry Pi.
      Trying to add text from MMM-ImagesPhotos to MagicMirror/config.js :
      /* Magic Mirror Config Sample
      • By Michael Teeuw https://michaelteeuw.nl
      • MIT Licensed.
      • For more information on how you can configure this file
      • See https://github.com/MichMich/MagicMirror#configuration
      var config = {
      // - “0.0.0.0”, “::” to listen on any interface
      // Default, when address config is left out or empty, is “localhost”
      port: 8080,
      basePath: “/”, // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
      language: "en",
      timeFormat: 24,
      units: "metric",
      		module: "alert",
      		module: "updatenotification",
      		position: "top_bar"
      		module: "clock",
      		position: "top_left"
      		header: "US Holidays",
      					symbol: "calendar-check",
      					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
      module: "MMM-ImagesPhotos",
      position: "middle_center",
      	opacity: 0.9,
      	animationSpeed: 500,
      	updateInterval: 5000,
      module: “compliments”,
      position: “lower_third”
      module: “currentweather”,
      position: “top_right”,
      locationID: “5128581”, //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      appid: “YOUR_OPENWEATHER_API_KEY”
      module: “weatherforecast”,
      header: “Weather Forecast”,
      module: “newsfeed”,
      position: “bottom_bar”,
      feeds: [
      title: “New York Times”,
      url: “https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml”
      showSourceTitle: true,
      showPublishDate: true,
      broadcastNewsFeeds: true,
      broadcastNewsUpdates: true
      if (typeof module !== “undefined”) {module.exports = config;}
      Got wrong position for text when past in ?
      Litek
        sdetweil @Litek
        @litek all that doesn’t go in config.js
        just a little section
           module: "?????",
           position:"??!!!??",
           config :{
        see the topics on my signature below
        • L Offline
          Litek
          Hi again !
          can you add this in to config js for me :
          so i can se how the file look like ?
          Here is an example of an entry in config.js
          		opacity: 0.9,
            sdetweil @Litek
            @litek well,
            this is the end of the config.js file
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "New York Times",
            						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
            	]      // < ------- this is the end of the module list (the start is [ above
            so, you place your new module BEFORE the end of the list and AFTER the } of the prior module
            			module: "newsfeed",
            				feeds: [
            		},  // < --- end of prior module
            // new module goes here
            		opacity: 0.9,
            	]   // < --- end of module list
            ALWAYS check to make sure end of prior module entry } ends with a comma (means more to follow)
            • L Offline
              Litek
              File wonr run :
               * By Michael Teeuw https://michaelteeuw.nl
               * MIT Licensed.
              var config = {
              	address: "localhost", 	// Address to listen on, can be:
              	port: 8080,
              	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
              	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
              	language: "en",
              	timeFormat: 24,
              	units: "metric",
              			module: "alert",
              			position: "top_bar"
              			module: "clock",
              			module: "compliments",
              			position: "lower_third"
              			module: "currentweather",
              				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              			module: "weatherforecast",
              			header: "Weather Forecast",
              			module: "newsfeed",
              				feeds: [
              		opacity: 0.9,
              [29.03.2021 18:15.24.533] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:107
              SyntaxError: Unexpected token ':'
                  at Module._compile (internal/modules/cjs/loader.js:896:18)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:986:10)
                  at Module.load (internal/modules/cjs/loader.js:816:32)
                  at Module._load (internal/modules/cjs/loader.js:728:14)
                  at Function.Module._load (electron/js2c/asar.js:748:26)
                  at Module.require (internal/modules/cjs/loader.js:853:19)
                  at require (internal/modules/cjs/helpers.js:74:18)
                  at loadConfig (/home/pi/MagicMirror/js/app.js:70:12)
                  at App.start (/home/pi/MagicMirror/js/app.js:217:3)
                  at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:129:7)
              Need some help
                sdetweil @Litek
                @litek cause u put it in the wrong place
                • L Offline
                  Litek
                  Hi again !
                  Can you make the file for me and wherto so i will understand it ?
                  Please
                  S lavolp3L 2 Replies Last reply Reply Quote 0
                    sdetweil @Litek
                    @litek no. I gave u the very detailed instructions
                    • lavolp3L Offline
                      lavolp3 Module Developer @Litek
                      @litek Sam does not want to do all the work for you and I understand him.
                      You can see in the file a lot of module entries, and you need to put your module entry in like them.
                      modulesis an array containing objects (if that does not ring a bell you should consider going a bit into javascript before moving much further).
                      The structure of this array is like this:
                          module: '',
                          position: '...',
                          module: '',
                          position: '...',
                          module: '',
                          position: '...',
                      You need to take care to use commas as seperators, IN an array or an object, semicolons are always misplaced.
                      Hope that helps.
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                        sdetweil @lavolp3
                        @lavolp3 I gave him exactly where
                        • lavolp3L Offline
                          @sdetweil Yeah right you did. Have overseen that.
                          • L Offline
                            Litek
                            Hi again !
                            Thanks for help .Think I beginn to under stand now :
                            Litek :)
