    Text to config.js
    12 Posts 3 Posters 2.2k Views 3 Watching
      sdetweil @Litek
      @litek all that doesn’t go in config.js
      just a little section
         module: "?????",
         position:"??!!!??",
         config :{
      see the topics on my signature below
      • L Offline
        Litek
        Hi again !
        can you add this in to config js for me :
        so i can se how the file look like ?
        Here is an example of an entry in config.js
        	module: "MMM-ImagesPhotos",
        	position: "middle_center",
        		opacity: 0.9,
        		animationSpeed: 500,
        		updateInterval: 5000,
          sdetweil @Litek
          @litek well,
          this is the end of the config.js file
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "New York Times",
          						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
          				broadcastNewsUpdates: true
          	]      // < ------- this is the end of the module list (the start is [ above
          so, you place your new module BEFORE the end of the list and AFTER the } of the prior module
          			module: "newsfeed",
          				feeds: [
          		},  // < --- end of prior module
          // new module goes here
          		opacity: 0.9,
          	]   // < --- end of module list
          ALWAYS check to make sure end of prior module entry } ends with a comma (means more to follow)
          • L Offline
            Litek
            File wonr run :
            /* Magic Mirror Config Sample
             * By Michael Teeuw https://michaelteeuw.nl
             * MIT Licensed.
            var config = {
            	address: "localhost", 	// Address to listen on, can be:
            	port: 8080,
            	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
            	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
            	language: "en",
            	timeFormat: 24,
            	units: "metric",
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
            			header: "US Holidays",
            						symbol: "calendar-check",
            						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
            			module: "compliments",
            			position: "lower_third"
            			module: "currentweather",
            				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            			module: "weatherforecast",
            			header: "Weather Forecast",
            			module: "newsfeed",
            				feeds: [
            		opacity: 0.9,
            [29.03.2021 18:15.24.533] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:107
            SyntaxError: Unexpected token ':'
                at Module._compile (internal/modules/cjs/loader.js:896:18)
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:986:10)
                at Module.load (internal/modules/cjs/loader.js:816:32)
                at Module._load (internal/modules/cjs/loader.js:728:14)
                at Function.Module._load (electron/js2c/asar.js:748:26)
                at Module.require (internal/modules/cjs/loader.js:853:19)
                at require (internal/modules/cjs/helpers.js:74:18)
                at loadConfig (/home/pi/MagicMirror/js/app.js:70:12)
                at App.start (/home/pi/MagicMirror/js/app.js:217:3)
                at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:129:7)
            Need some help
              sdetweil @Litek
              @litek cause u put it in the wrong place
              • L Offline
                Litek
                Hi again !
                Can you make the file for me and wherto so i will understand it ?
                Please
                S lavolp3L 2 Replies Last reply Reply Quote 0
                  sdetweil @Litek
                  @litek no. I gave u the very detailed instructions
                  • lavolp3L Offline
                    lavolp3 Module Developer @Litek
                    @litek Sam does not want to do all the work for you and I understand him.
                    You can see in the file a lot of module entries, and you need to put your module entry in like them.
                    modulesis an array containing objects (if that does not ring a bell you should consider going a bit into javascript before moving much further).
                    The structure of this array is like this:
                        module: '',
                        position: '...',
                        module: '',
                        position: '...',
                        module: '',
                        position: '...',
                    You need to take care to use commas as seperators, IN an array or an object, semicolons are always misplaced.
                    Hope that helps.
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                      sdetweil @lavolp3
                      @lavolp3 I gave him exactly where
                      • lavolp3L Offline
                        @sdetweil Yeah right you did. Have overseen that.
                        • L Offline
                          Litek
                          Hi again !
                          Thanks for help .Think I beginn to under stand now :
                          Litek :)
