    Fitbit
    129 Posts 42 Posters 226.0k Views 37 Watching
    • K
      kckndrgn @chengstark
      @chengstark,
      Possibly the internet connection was lost during a refresh, this will cause the tokens to get out of date.
      I stop MM, re-run the “setupAccess.py” script using credentials from the file, then re-start MM and all is fine, until the next time I have an internet hiccup.
      C 1 Reply Last reply
        chengstark @kckndrgn
        @kckndrgn thanks, will try
        • VendittelliV
          Vendittelli Module Developer
          I have released a fix for the .ini files problem in the latest version on GitHub. You’ll need to delete your tokens.ini and credentials.ini files and remake them (as well as performing a git pull) for the fix to be effective.
            darrene
            For some reason, I’m getting calories displayed, but nothing else. @Vendittelli, does the module have any additional debugging or logging that I can turn on to look through? - I’m not getting any issues in dev mode or in the terminal - it seems that’s the only data I get. When I look in the dev console, I see:
            writing steps (data/goal): 0/10000
            Writing floors (data/goal): 0/10
            writing calories out (data/goal): 1664/2930
            writing distance (data/goal) 0/5
            writing activeminutes (data/goal): 0/30
            writing sleep (data/goal): 0/480
            When I clear down my tokens.ini and re-run the setupaccess.py, I can see the scope information for the token results includes u’social’, u’settings’, u’profile’, u’sleep’, u’activity’, u’heartrate’, u’weight’, u’nutrition’, u’location’
            if that’s helpful…
            As a slight aside: @olliewarren411, would you mind sharing your ‘vertical-layout’ css? I’m still trying to get my head around cascading style sheets!
            VendittelliV 1 Reply Last reply
            • VendittelliV
              Vendittelli Module Developer @darrene
              @darrene That is weird. The module is pretty unadvanced so I don’t have proper debugging, unfortunately. The scope looks correct, are you sure you have synced your Fitbit today? It would explain why calories are displayed as they are calculated automatically so you don’t need to sync them.
              D 1 Reply Last reply
                darrene @Vendittelli
                Thanks for the quick reply @Vendittelli - that could be the answer. I didn’r realise the calories were calculated like that - as you say, it’d certainly explain it.
                I’ll have a look into it. If it comes to it, I’ll recreate the app - I seem to remember there are a list of tick boxes for the fitibit attributes and on the pi browser, it was really difficult to tell whether or not they were ticked!
                  moshinh
                  I am having the same issue Greppie had at some point.
                  Next thing is, that setupAccess.py doesnt work or I did not understood how it does. The script start a server at port 8080 but if fitbit redirects to it I get an error that the page is not accessible. However I copied the token from url an put it into tokens.ini. There’s only an access token and no refresh token, right?
                  I am having this same problem, I get a 404 error on the attempt to get my tokens. I was able to pull the token from the URL, but have no way to get the refresh. Please help, im so close! Thanks for all of your effort.
                  When I click the autogenerated authorization URL, I am redirected to http://127.0.0.1:8080/ and throw this 404 error.
                  404 Not Found
                  Missing parameters: state
                  File “/usr/local/lib/python2.7/dist-packages/cherrypy/_cprequest.py”, line 670, in respond
                  response.body = self.handler()
                  File “/usr/local/lib/python2.7/dist-packages/cherrypy/lib/encoding.py”, line 217, in call
                  self.body = self.oldhandler
                  (*args, **kwargs)
                  File “/usr/local/lib/python2.7/dist-packages/cherrypy/_cpdispatch.py”, line 67, in call
                  raise sys.exc_info()[1]
                  HTTPError: (404, ‘Missing parameters: state’)
                  This is what I see when I run setupAccess.py
                  Is this part normal?
                  CherryPy Checker:
                  The Application mounted at ‘’ has an empty config.
                  Full output:
                  pi@mirror:~/MagicMirror/modules/MMM-fitbit/python $ sudo python setupAccess.py
                  Get credentials from credentials.ini? (Y/N)
                  n
                  Would you like to enter them manually now? (Y/N)
                  y
                  Enter client id:
                  227WT7
                  Enter client secret:
                  9fe3da42b609603a67e7730aad3ca96a
                  [25/Oct/2016:11:20:26] ENGINE Listening for SIGHUP.
                  [25/Oct/2016:11:20:26] ENGINE Listening for SIGTERM.
                  [25/Oct/2016:11:20:26] ENGINE Listening for SIGUSR1.
                  [25/Oct/2016:11:20:26] ENGINE Bus STARTING
                  CherryPy Checker:
                  [25/Oct/2016:11:20:26] ENGINE Started monitor thread ‘Autoreloader’.
                  [25/Oct/2016:11:20:26] ENGINE Started monitor thread ‘_TimeoutMonitor’.
                  [25/Oct/2016:11:20:27] ENGINE Serving on http://127.0.0.1:8080
                  [25/Oct/2016:11:20:27] ENGINE Bus STARTED
                  127.0.0.1 - - [25/Oct/2016:11:20:40] “GET / HTTP/1.1” 404 1206 “” “Mozilla/5.0 (X11; Linux armv7l) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.91 Safari/537.36”
                  T 1 Reply Last reply
                  • F
                    frog
                    I have the same issue but I think the problem is earlier in the install
                    Well I’m having an even earlier problem in installing the dependencies:
                    pi@Mirror1:~/MagicMirror/modules/MMM-fitbit $ npm install python-shell
                    returns:
                    /home/pi/MagicMirror/modules
                    └── python-shell@0.4.0
                    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
                    npm WARN modules No description
                    npm WARN modules No repository field.
                    npm WARN modules No README data
                    npm WARN modules No license field.
                    The python-shell is clearly not installing.
                    A 1 Reply Last reply
                    • T
                      tismepaulo @moshinh
                      I’m also having the same issues as @moshinh and @frog during installation. Has anyone been able to get this working?
                      F O 2 Replies Last reply
                      • F
                        frog @tismepaulo
                        @tismepaulo Actually, I got it working by firstly not using ssh and running this directly on the display using a terminal and secondly not using sudo. Populated the tokens.ini with the results from the results of the script - and changed the access of the tokens.ini file to 666 - re-ran again the setupAccess.py and it said all was good.
                        having said that - while I get the authorisation page from Fitbit, I got zero values on the MM. The fitbit account page says that I have access, but initially no data comes through… Next thing I did was running getData.py (in the python directory) I do get a good response:
                        {"message": "credentials.ini exists", "type": "status"}
                        {"message": "Reading from credentials.ini", "type": "status"}
                        {"message": "Read of credentials.ini successful.", "type": "status"}
                        {"message": "tokens.ini exists", "type": "status"}
                        {"message": "Reading from tokens.ini", "type": "status"}
                        {"message": "Read of tokens.ini successful.", "type": "status"}
                        {"message": "Making API call", "type": "status"}
                        {"message": "API call okay", "type": "status"}
                        {"message": "Tokens valid", "type": "status"}
                        {"values": {"data": 4684, "goal": 10000}, "resource": "steps", "type": "data"}
                        {"values": {"data": 0, "goal": 1}, "resource": "floors", "type": "data"}
                        So I think it is at least reflecting accurately now what the fitbit site is showing for steps, but is incorrect for distance - still showing 0 (maybe because I’m using KM not miles?)
                          Rmtcts
                          I’m having a bit of trouble getting this to work with my Magic Mirror. The display is there but it has 0 in all of the categories. I have followed the steps and I get up to running setupAccess.py which takes me to a webpage where I allow access to all of the checkboxes, but it then just redirects to the magic mirror screen with 0s in all of the categories. if I run getData.py it says
                          {"message": {"401": {"errors": [{"message": "Access token invalid: <your access token>. Visit https://dev.fitbit.com/docs/oauth2 for more information on the Fitbit Web API authorization process.", "errorType": "invalid_token"}], "success": false}}, "type": "error"}
                          {"message": "Invalid token, reauthorise fitbit API", "type": "status"}
                          and the tokens.ini file says:
                          [Tokens]
                          acc_tok = <your access token>
                          ref_tok = <your refresh token>
                          • F
                            frog
                            Well the token.ini file should be altered to include the correct credentials. That’s why you are getting the error. Fix that and you may get somewhat further. I manually entered the info to get mine to (partially) work.
                              Rmtcts
                              Where could I get the access and refresh tokens from?
                              • A
                                Azrael Masters @frog
                                @frog I’ve got the same Issue with the Image of “2016-11-25-raspbian-jessie”.
                                I’m logged in on the BigScreen (not with SSH) and typing via Terminal:
                                pi@raspberrypi:~/MagicMirror/modules/MMM-fitbit $ npm install python-shell
                                I also tried this, without success:
                                pi@raspberrypi:~/MagicMirror $ npm install python-shell
                                magicmirror@2.0.0 /home/pi/MagicMirror
                                ├── UNMET PEER DEPENDENCY grunt@1.0.1
                                npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
                                Anybody an Idea, what I need to do?
                                • T
                                  tismepaulo @olliewarren411
                                  @olliewarren411 Hi, would you be able to explain what you changed in the CSS to get fitbit to display vertically please? I want to try this out.
                                    codyli2002hk
                                    Hi everyone,
                                    This Module so cool. Is there anyway to show more than one user?
                                    bheplerB 1 Reply Last reply
                                    • bheplerB
                                      bhepler Module Developer @codyli2002hk
                                      @codyli2002hk You could probably put two instances of the module up on your mirror. Just copy & paste the entire module configuration. Change the position tag, clientID & clientSecret and call it good.
                                        daniel44992
                                        Hi, this module works and displays great except for the fact that the only field that is displaying values is steps. Flights, calories, etc. all show 0 values but have the images and progress bars. When I ran setupAccess.py, I made sure all the boxes were checked so that every field was being shared. After doubting whether I actually did this, I went to my Fitbit profile and confirmed that the data is being shared with the app.
                                        As another form of double checking my Fitbit sync, I have my Fitbit profile also linked to my Alexa and when I asked Alexa, it correctly said each of the fields that are currently zeros on the mirror display.
                                        Has anyone else had this issue and if so how did you fix it?
                                        O 1 Reply Last reply
                                        • O
                                          onetwankyfive @tismepaulo
                                          @tismepaulo same issue for me as well
                                            crowbar
                                            Is anybody able to tell me how I would go about changing my distance from miles to kilometers? My mirror is set to metric however I believe this module has its own settings?
                                            • 4 / 7
