    MMM-TelegramBot : Control MM on Telegram
    47 Posts 20 Posters 27.4k Views 21 Watching
      robiv8 @DinoDog
      @DinoDog said in MMM-TelegramBot : Control MM on Telegram:
      hi
      When i use /alert, i see the message on my MM, but /telecast don’t show any on my MM
      How can i found, whats the error?
      The IDs are all correct
      Hallo,
      any help is welcome.
      I have the same problem. Any codes and numbers are correct.
      No error in logs.
      /alert is coming and displayed
      but when I send a message like TEST123 nothing happens?
      The Modul is on top_left~~
      So now I understand! This is only with telecast possible!
        A Former User
          robiv8
          Yes! You are right :-)
          by the way, is it possible to clear the chat
          or to delete a message
          or to delete the message after a while -> telecastLife OK
          so that when you have sent a few messages you can delete them so that this don’t stand there forever.
          and
          Videos are not going?
          Robert
            A Former User
            And …
            The ReadMe file says:
            New Updates
            **[1.3.7] 2020-09-11
            • add TelegramBot Service (catch all Errors of Telegram)
            [1.3.5-1.3.6] 2020-09-08
            • add telecast directly on allowedUser
            • add emojis (@eouia purpose)
            • add telecastContainer feature
            • add Play audio on received audio file
            • add Video play… (if codec is there…)
            • add Voice audio ! @MIRCO
            [1.3.4] 2020-09-07
            • add /clean command for clean telecast screen
            • update fr translations
            • add dateFormat feature
            [1.3.3] 2020-09-05
            • Add stickers support (not animated)
            • Add gifs support
            • Add native default sound on message received
            Just little part of the file…
              robiv8
              :man_facepalming_light_skin_tone:
              Thank you!
              Send a video from iPhone is not display! are you now what kind of codec are necessary
                A Former User
                Need some modification in MagicMirror Core but i think send a video file for playing is actually optional, video cast is better
                  robiv8
                    alex1258
                    • O Offline
                      OberfragGER
                      i dont get this to work.
                      I already have setup a bot for ioBroker. I want to have this Notifications also in the MagicMirror.
                      Is that even possible to use the same token on 2 devices?- because when i enter the API Token in the MagicMirror-Config i get some warning in ioBroker and no chat or something in MM2.
                      warn: telegram.0 (17441) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      My config looks like
                        module: 'MMM-TelegramBot',
                          telegramAPIKey : 'Api-Token',
                          allowedUser : ['username']
                      I use pages and i have fixed “MMM-TelegramBot”.
                      • lavolp3L Offline
                        lavolp3 Module Developer @OberfragGER
                        @oberfragger I’ve had a few issues getting i to work as well but eventually it works. Rebooted the RasPi on the way so that might help although I doubt it.
                        And don’t forget to include your chatID as descripbed in the README.
                        I think the error is not necessarily the problem. I got that as well when starting the mirror on the laptop as well, so having two front-end instances running. Module still worked
                        How to troubleshoot modules
                        MMM-soccer v2, MMM-AVStock
                        • lavolp3L Offline
                          I’m astonished by the power of this module and the telegram bot. I am using it to send messages and pictures to the mirror. And it is so much fun, especially for the kids.
                          What I am missing is:
                          can the last messages of the chat be loaded at startup? Does anyone know?
                          They do not in my case.
                          It’s a shame that there’s apparently no support from the owner anymore here, so I might decide to work with a fork and publish it here again to have a support and troubleshooting base on this forum again.
                          bugsounetB 1 Reply Last reply Reply Quote 0
                          • bugsounetB Offline
                            bugsounet Banned @lavolp3
                            @lavolp3 really? 😂
                            • lavolp3L Offline
                              lavolp3 Module Developer @bugsounet
                              @bugsounet am I wrong? It’s a great module as a lot of the other ones @Sean has established. Happy for any support you can give to the people here.
                                sdetweil @lavolp3
                                @lavolp3 @bugsounet has taken over quite a few of Sean’s modules.
                                • lavolp3L Offline
                                  @sdetweil said in MMM-TelegramBot : Control MM on Telegram:
                                  I know. No problem for me as long as the modules get troubleshooting support on this forum or at least on github. Which I don’t think they do anymore.
                                  • 3 / 3
