    MMM-TelegramBot : Control MM on Telegram
    47 Posts 20 Posters 27.4k Views 21 Watching
      Bronno @DinoDog
      @DinoDog Did you know the solution? I have the same problem…
        robiv8 @DinoDog
        @DinoDog said in MMM-TelegramBot : Control MM on Telegram:
        hi
        When i use /alert, i see the message on my MM, but /telecast don’t show any on my MM
        How can i found, whats the error?
        The IDs are all correct
        Hallo,
        any help is welcome.
        I have the same problem. Any codes and numbers are correct.
        No error in logs.
        /alert is coming and displayed
        but when I send a message like TEST123 nothing happens?
        The Modul is on top_left~~
        So now I understand! This is only with telecast possible!
          A Former User
            robiv8
            Yes! You are right :-)
            by the way, is it possible to clear the chat
            or to delete a message
            or to delete the message after a while -> telecastLife OK
            so that when you have sent a few messages you can delete them so that this don’t stand there forever.
            and
            Videos are not going?
            Robert
              A Former User
              And …
              The ReadMe file says:
              New Updates
              **[1.3.7] 2020-09-11
              • add TelegramBot Service (catch all Errors of Telegram)
              [1.3.5-1.3.6] 2020-09-08
              • add telecast directly on allowedUser
              • add emojis (@eouia purpose)
              • add telecastContainer feature
              • add Play audio on received audio file
              • add Video play… (if codec is there…)
              • add Voice audio ! @MIRCO
              [1.3.4] 2020-09-07
              • add /clean command for clean telecast screen
              • update fr translations
              • add dateFormat feature
              [1.3.3] 2020-09-05
              • Add stickers support (not animated)
              • Add gifs support
              • Add native default sound on message received
              Just little part of the file…
                robiv8
                :man_facepalming_light_skin_tone:
                Thank you!
                Send a video from iPhone is not display! are you now what kind of codec are necessary
                  A Former User
                  Need some modification in MagicMirror Core but i think send a video file for playing is actually optional, video cast is better
                    robiv8
                      alex1258
                      • O Offline
                        OberfragGER
                        i dont get this to work.
                        I already have setup a bot for ioBroker. I want to have this Notifications also in the MagicMirror.
                        Is that even possible to use the same token on 2 devices?- because when i enter the API Token in the MagicMirror-Config i get some warning in ioBroker and no chat or something in MM2.
                        warn: telegram.0 (17441) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                        My config looks like
                          module: 'MMM-TelegramBot',
                            telegramAPIKey : 'Api-Token',
                            allowedUser : ['username']
                        I use pages and i have fixed “MMM-TelegramBot”.
                        • lavolp3L Offline
                          lavolp3 Module Developer @OberfragGER
                          @oberfragger I’ve had a few issues getting i to work as well but eventually it works. Rebooted the RasPi on the way so that might help although I doubt it.
                          And don’t forget to include your chatID as descripbed in the README.
                          I think the error is not necessarily the problem. I got that as well when starting the mirror on the laptop as well, so having two front-end instances running. Module still worked
                          How to troubleshoot modules
                          MMM-soccer v2, MMM-AVStock
                          • lavolp3L Offline
                            I’m astonished by the power of this module and the telegram bot. I am using it to send messages and pictures to the mirror. And it is so much fun, especially for the kids.
                            What I am missing is:
                            can the last messages of the chat be loaded at startup? Does anyone know?
                            They do not in my case.
                            It’s a shame that there’s apparently no support from the owner anymore here, so I might decide to work with a fork and publish it here again to have a support and troubleshooting base on this forum again.
                            bugsounetB 1 Reply Last reply Reply Quote 0
                            • bugsounetB Offline
                              bugsounet Banned @lavolp3
                              @lavolp3 really? 😂
                              • lavolp3L Offline
                                lavolp3 Module Developer @bugsounet
                                @bugsounet am I wrong? It’s a great module as a lot of the other ones @Sean has established. Happy for any support you can give to the people here.
                                  sdetweil @lavolp3
                                  @lavolp3 @bugsounet has taken over quite a few of Sean’s modules.
                                  • lavolp3L Offline
                                    @sdetweil said in MMM-TelegramBot : Control MM on Telegram:
                                    I know. No problem for me as long as the modules get troubleshooting support on this forum or at least on github. Which I don’t think they do anymore.
                                    • 3 / 3
