    'Official' recommended node.js version for MM?
    Scheduled Pinned Locked Moved Solved General Discussion
    12 Posts 4 Posters 2.8k Views 4 Watching
      administrator
      Hi. I’m very new to MagicMirror and have a question regarding which version of Node to use. Working through the manual installation guide it specifies Node v10, however this version goes End of Life this coming Friday.
      Is there a more recent agreed recommended version of Node to use with MagicMirror?
      Steve
        sdetweil @administrator
        @administrator we have not released a new version supported yet…
        shouldn’t matter…
        if you use my install script it does the whole thing (still on node 10)
        see https://github.com/sdetweil/MagicMirror_scripts
          administrator @sdetweil
          Thanks for the response, @sdetweil.
          If I understand correctly, then, Node v10 is the current ‘default’ for installing MM, but later versions are probably also fine.
          Once v10 goes End of Life next week, we don’t really want anyone to be installing v10 as it will no longer receive security fixes, so ideally we need a later version to be the new default.
            @administrator there’s an mm release every 3 months
            • karsten13K Offline
              karsten13
              mm is working with later versions, I’m using node lts in the docker setup which is currently v14 without any problems.
              A lavolp3L 2 Replies Last reply Reply Quote 0
                administrator @karsten13
                I’ll upgrade to v14. Thanks.
                • lavolp3L Offline
                  lavolp3 Module Developer @karsten13
                  @karsten13 @administrator @sdetweil I have v15.12.0 installed and works like a charm
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
                    karsten13 @lavolp3
                    @lavolp3
                    v16 works too … the official documentation is now updated and the recommended version there is now v14.
                      sdetweil @karsten13
                      @karsten13 said in 'Official' recommended node.js version for MM?:
                      and my script is changed to 14 now too
                      A karsten13K 2 Replies Last reply Reply Quote 0
                        @sdetweil @karsten13 That’s great news! Thank you very much :-)
                          karsten13 @sdetweil
                          @sdetweil maybe I’m wrong but looking into your updated script I see still install 10.x in this line
                            sdetweil @karsten13
                            @karsten13 good catch,
