MM Standby loop _ Unable to access raspberry
11 Posts 3 Posters 3.4k Views 3 Watching
  • N Offline
    Nneuland
    I’m in a bit of a pickle here. I have my magic mirror programed to start automatically upon booting of the raspberry pi. However something happened last night that I can’t explain or get around.
    When I boot the Pi (4) everything works as expected, but once the mirror starts up the monitors connection to hdmi is cut immediately and I have zero signal. I have not found a way to get connection to the monitor to be able to troubleshoot.
    This is definitely a Pi issue, as I tried in a different monitor with the same issue .
    I am at a loss here. I have no idea how this happened. Please. Any help?
    S N 2 Replies Last reply Jul 13, 2021, 2:01 PM Reply Quote 0
      sdetweil @Nneuland
      @nneuland use ssh to connect to the pi so u can work on it.
      do you use pir for motion sense? turn off monitor?
      N 1 Reply Last reply Jul 13, 2021, 2:20 PM Reply Quote 0
      • N Offline
        Nneuland @Nneuland
        • N Offline
          Nneuland @sdetweil
          I hope that I have enabled SSH on the raspberry. I think I had.
          I have yet to try accessing the pi yet from SSH, but fingers crossed.
          Yes. I am using PIR as a motion sensor. I have tried detaching the PIR with no luck.
          G 1 Reply Last reply Jul 13, 2021, 3:36 PM Reply Quote 0
          • G Offline
            George @Nneuland
            @nneuland , If the PIR sensor does not work, the mirror does not work.
            N 1 Reply Last reply Jul 13, 2021, 4:09 PM Reply Quote 0
            • N Offline
              Nneuland @George
              @george
              I believe the PIR is working fine. Just not sure why the HDMI connection is immediately lost after the mirror has loaded.
              Wouldn’t disconnecting the PIR from the Pi correct this?
              S N 2 Replies Last reply Jul 13, 2021, 4:10 PM Reply Quote 0
                sdetweil @Nneuland
                @nneuland the pir module has turned off the hdmi port… (as if no motion, time to sleep)
                • N Offline
                  Nneuland @Nneuland
                  Not sure how that happened out of nowhere. I should delete the PIR module through ssh to see what’s going on then?
                  Unless I can modify the config file through the remote app. Not sure that’s safe though.
                  N
                  S N 2 Replies Last reply Jul 13, 2021, 7:17 PM Reply Quote 0
                    sdetweil @Nneuland
                    @nneuland things work reliably until they dont!
                    if u can thru remote, just add disabled:true,
                    after the pir module name line
                    • N Offline
                      Nneuland @Nneuland
                      @nneuland
                      Nothing truer has been said. I’ll give it a go
                      N 1 Reply Last reply Jul 14, 2021, 12:32 PM Reply Quote 0
