    MM Standby loop _ Unable to access raspberry
    11 Posts 3 Posters 7.0k Views 3 Watching
    • N Offline
      Nneuland
      I’m in a bit of a pickle here. I have my magic mirror programed to start automatically upon booting of the raspberry pi. However something happened last night that I can’t explain or get around.
      When I boot the Pi (4) everything works as expected, but once the mirror starts up the monitors connection to hdmi is cut immediately and I have zero signal. I have not found a way to get connection to the monitor to be able to troubleshoot.
      This is definitely a Pi issue, as I tried in a different monitor with the same issue .
      I am at a loss here. I have no idea how this happened. Please. Any help?
      S N 2 Replies Last reply Reply Quote 0
        sdetweil @Nneuland
        @nneuland use ssh to connect to the pi so u can work on it.
        do you use pir for motion sense? turn off monitor?
        • N Offline
          Nneuland @Nneuland
          • N Offline
            Nneuland @sdetweil
            I hope that I have enabled SSH on the raspberry. I think I had.
            I have yet to try accessing the pi yet from SSH, but fingers crossed.
            Yes. I am using PIR as a motion sensor. I have tried detaching the PIR with no luck.
            • G Offline
              George @Nneuland
              @nneuland , If the PIR sensor does not work, the mirror does not work.
              • N Offline
                Nneuland @George
                @george
                I believe the PIR is working fine. Just not sure why the HDMI connection is immediately lost after the mirror has loaded.
                Wouldn’t disconnecting the PIR from the Pi correct this?
                  sdetweil @Nneuland
                  @nneuland the pir module has turned off the hdmi port… (as if no motion, time to sleep)
                  • N Offline
                    Nneuland @Nneuland
                    Not sure how that happened out of nowhere. I should delete the PIR module through ssh to see what’s going on then?
                    Unless I can modify the config file through the remote app. Not sure that’s safe though.
                    N
                      sdetweil @Nneuland
                      @nneuland things work reliably until they dont!
                      if u can thru remote, just add disabled:true,
                      after the pir module name line
                      • N Offline
                        Nneuland @Nneuland
                        @nneuland
                        Nothing truer has been said. I’ll give it a go
                        • N Offline
                          Nneuland @Nneuland
                          Deleting PIR from the config through the remote worked!
                          Thank you Sam.
