    PIR Sensor ??
    28 Posts 5 Posters 11.4k Views 5 Watching
      sdetweil @MDLefevere
      @mdlefevere yes. but can’t turn it off programatically… what else can I do?
      M 1 Reply Last reply
        MDLefevere @sdetweil
        So weird. I can’t imagine that a crontab can do it and the same line in a .sh not.
        That’s bothering me. To be continued.
        Saw another module im gonna try tomorrow: MMM-NewPIR
          @mdlefevere they all use the same 4 commands
          tvservice
          vcgencmd
          dpms
          cec-client
          top three turn off hdmi, leaving the ugly message
          cec-client turns off the display, BUT, needs something 2018 or newer with CEC support
          for it to work… my 55 in tv will turn off, but not on… (so much for standards!), and only from the pi4… nothing else.
          this is the screen library in NewPIR
          https://github.com/bugsounet/screen
          and the matching code
              switch (this.config.mode) {
                case 1:
                  if (set) exec("/usr/bin/vcgencmd display_power 1")
                  else exec("/usr/bin/vcgencmd display_power 0")
                  break
                case 2:
                  if (set) exec("DISPLAY=:0 xset dpms force on")
                  else exec("DISPLAY=:0 xset dpms force off")
                  break
                case 3:
                  if (set) exec("tvservice -p && sudo chvt 6 && sudo chvt 7")
                  else exec("tvservice -o")
                  break
                case 4:
                  if (set) exec("echo 'on 0' | cec-client -s")
                  else exec("echo 'standby 0' | cec-client -s")
                  break
                case 5:
                  if (set) exec("xset dpms force on")
                  else exec("xset dpms force off")
                  break
          C 1 Reply Last reply
            c1olli @sdetweil
            I use a mini pir sensor like this:
            https://www.ebay.de/itm/133654306312
            That switches the monitor directy completely off without any programming.
            That solution works on my MagicMirror since one year without any problems.
            • cowboysdudeC
              cowboysdude Module Developer @MDLefevere
              @mdlefevere No real answer for this… I’ve tried several times. I can turn it off but not back on…
              Are you running a pi4 or pi3?
              This was my answer to the pi3 and it works… cannot figure out the pi4
              https://github.com/cowboysdude/Pir-Sensor
                MDLefevere @c1olli
                @c1olli
                That might be nice.
                But how about the startup?. Do you get the ugly brand boot screen first?. How longt to fire up?
                  MDLefevere @cowboysdude
                  @cowboysdude
                  I’m running a 8GB PI4.
                  I’ve installed NewPIR and configured it like this:
                  			module: 'MMM-NewPIR',
                  			position: 'top_left',
                  			configDeepMerge: true,
                  				screen: {
                  					delay: 20000,
                  					turnOffDisplay: true,
                  					mode: 1,
                  				pir: {
                  					gpio: 17
                  Strange enough it’s working now on another monitor. No sleepy “No Signal” text on screen but just a monitor turning in stand-by.
                  It’s not a new monitor --> Fujitsu L20T-4 connected with DVI
                  I can’t get my hands on it…
                    @mdlefevere that monitor is not energy star compliant.
                    the monitor doesn’t actually turn off, but enters some lower power mode. or they turn off backlight.
                      Ah i see.
                      But on the other hand: It goes into stand-by so the front light turns orange, and the screen goes all black (no backlight).
                        @mdlefevere yes… getting harder and harder to find monitors that do this…
                        none of mine do.
                          So. I came home after work frustrated that it didn’t work.
                          After connecting another HDMI cable everything is working as expected 🙄.
                          I had a MicroHDMI to HDMI convertor and a HDMI cable after that.
                          I ordered a Micro to HDMI so i could get rid of the convertor.
                          Strange enough it is working with the convertor cable.
                            @mdlefevere never a dull moment!
                            so not all cables are the same…
                              Defenitly not.
                              Although it’s weird at the end it’s working.
                              Going to test this a couple of days to see if it stays this way…
                                c1olli @MDLefevere
                                @mdlefevere
                                It takes 2 seconds for the startup of the monitor.
                                There is also no start screen , because the Raspberry Pi is still running.
                                • cowboysdudeC
                                  cowboysdude Module Developer @c1olli
                                  @c1olli NICE!!!
                                    maptecnet @cowboysdude
                                    @MDLefevere
                                    Check out this post and see if it helps
                                    https://forum.magicmirror.builders/post/88444
                                    • cowboysdudeC
                                      Sorry for being late to the party but as of 8/8/2021 I can confirm that this is working on my RPI3…NOT the 4!
