    PIR Sensor ??
    28 Posts 5 Posters 11.4k Views 5 Watching
      MDLefevere @cowboysdude
      @cowboysdude
      I’m running a 8GB PI4.
      I’ve installed NewPIR and configured it like this:
      			module: 'MMM-NewPIR',
      			position: 'top_left',
      			configDeepMerge: true,
      				screen: {
      					delay: 20000,
      					turnOffDisplay: true,
      					mode: 1,
      				pir: {
      					gpio: 17
      Strange enough it’s working now on another monitor. No sleepy “No Signal” text on screen but just a monitor turning in stand-by.
      It’s not a new monitor --> Fujitsu L20T-4 connected with DVI
      I can’t get my hands on it…
        sdetweil @MDLefevere
        @mdlefevere that monitor is not energy star compliant.
        the monitor doesn’t actually turn off, but enters some lower power mode. or they turn off backlight.
        M 1 Reply Last reply
          MDLefevere @sdetweil
          Ah i see.
          But on the other hand: It goes into stand-by so the front light turns orange, and the screen goes all black (no backlight).
            @mdlefevere yes… getting harder and harder to find monitors that do this…
            none of mine do.
              So. I came home after work frustrated that it didn’t work.
              After connecting another HDMI cable everything is working as expected 🙄.
              I had a MicroHDMI to HDMI convertor and a HDMI cable after that.
              I ordered a Micro to HDMI so i could get rid of the convertor.
              Strange enough it is working with the convertor cable.
                @mdlefevere never a dull moment!
                so not all cables are the same…
                  Defenitly not.
                  Although it’s weird at the end it’s working.
                  Going to test this a couple of days to see if it stays this way…
                    c1olli @MDLefevere
                    @mdlefevere
                    It takes 2 seconds for the startup of the monitor.
                    There is also no start screen , because the Raspberry Pi is still running.
                    • cowboysdudeC
                      cowboysdude Module Developer @c1olli
                      @c1olli NICE!!!
                        maptecnet @cowboysdude
                        @MDLefevere
                        Check out this post and see if it helps
                        https://forum.magicmirror.builders/post/88444
                        • cowboysdudeC
                          Sorry for being late to the party but as of 8/8/2021 I can confirm that this is working on my RPI3…NOT the 4!
                          https://github.com/cowboysdude/Pir-Sensor
