    PIR Sensor ??
    28 Posts 5 Posters 11.1k Views 5 Watching
      sdetweil @MDLefevere
      @mdlefevere yes… getting harder and harder to find monitors that do this…
      none of mine do.
        MDLefevere @sdetweil
        So. I came home after work frustrated that it didn’t work.
        After connecting another HDMI cable everything is working as expected 🙄.
        I had a MicroHDMI to HDMI convertor and a HDMI cable after that.
        I ordered a Micro to HDMI so i could get rid of the convertor.
        Strange enough it is working with the convertor cable.
          @mdlefevere never a dull moment!
          so not all cables are the same…
            Defenitly not.
            Although it’s weird at the end it’s working.
            Going to test this a couple of days to see if it stays this way…
              c1olli @MDLefevere
              @mdlefevere
              It takes 2 seconds for the startup of the monitor.
              There is also no start screen , because the Raspberry Pi is still running.
              • cowboysdudeC
                cowboysdude Module Developer @c1olli
                @c1olli NICE!!!
                  maptecnet @cowboysdude
                  @MDLefevere
                  Check out this post and see if it helps
                  https://forum.magicmirror.builders/post/88444
                  • cowboysdudeC
                    Sorry for being late to the party but as of 8/8/2021 I can confirm that this is working on my RPI3…NOT the 4!
                    https://github.com/cowboysdude/Pir-Sensor
