    Cannot find module "moment"
    98 Posts 2 Posters 68.6k Views 2 Watching
    • U
      uok825 @sdetweil
      @sdetweil said in Cannot find module "moment":
      git checkout master
        sdetweil @uok825
        @uok825 but we just checked out the older copy, so it should be unchanged now…
        git diff package.json
        U 1 Reply Last reply
        • U
          uok825 @sdetweil
            sdetweil @uok825
            @uok825 right, says no changes…
            grep start package.json
            • U
              uok825 @sdetweil
              Can you give me a Reputation. I cant reply you fast.
                sdetweil @uok825
                @uok825 hm… but that’s different than master, shouldn’t be.
                git stash
                git checkout master
                • U
                  uok825 @sdetweil
                  git checkout master
                    sdetweil @uok825
                    @uok825 yay!!!
                    run upgrade apply
                    • U
                      uok825 @sdetweil
                      @sdetweil 7183d73a-87b7-41e7-8c98-3a25969d7361-image.png It is not normal i think. I am about to cry. How can i check my MagicMirror version?
                        sdetweil @uok825
                        @uok825 but u had it downloaded already
                        grep version package.json
                        u were on develop
                        so either 2.13 or 2.12
                        • U
                          uok825 @sdetweil
                          Version 2.12.0
                          S 2 Replies Last reply
                            sdetweil @uok825
                            @uok825 run the upgrade script from installers
                            like u were doing
                            or run just the curl… part of the whole command so we can see the error
                              @sdetweil NEVER EVER SUDO!!!
                              • U
                                uok825 @sdetweil
                                @sdetweil Okey im sorry. Now run just
                                curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh
                                  sdetweil @uok825
                                  @uok825
                                  cd ~
                                  MagicMirror/installers/upgrade-script.sh apply
                                  • U
                                    uok825 @sdetweil
                                    @sdetweil 0ac068d6-c12e-4b8a-8052-f77778b56ae2-image.pngAccess denied
                                      sdetweil @uok825
                                      @uok825 ah, didn’t mark executable
                                      cd ~
                                      chmod +x MagicMirror/installers/upgrade-script.sh
                                      • U
                                        uok825 @sdetweil
                                          sdetweil @uok825
                                          @uok825 when I do the curl i get
                                          #!/bin/bash
                                          # only DO npm installs when flag is set to  1
                                          # test when set to 0
                                          true=1
                                          plus all the rest of the script.
                                          u have a networking problem going on …
                                          warning, upgrade might fail as IT will try to download new files too
                                          yes, the upgrade uses curl to get the new package.json file to check the version
                                          remote_version=$(curl -s https://raw.githubusercontent.com/MichMich/MagicMirror/master/package.json
                                          and it also fails…
                                          SO… u need to solve that… are you using pihole somewhere?
                                          U 2 Replies Last reply
                                          • U
                                            uok825 @sdetweil
                                            @sdetweil AHHHHHHH! Just remembered my other raspberry is stuck on internet too. I change my router so my router adress is changed from 192.168.1.1 to 192.168.1.3 but in my /etc/dhcpcd.conf 37c38ff5-5fcd-4f9b-83c0-5dac86ded6f4-image.png still 192.168.1.1 here sorry for bother you. Trying again.
                                            • 3 / 5
