    Cannot find module "moment"
    98 Posts 2 Posters 68.3k Views 2 Watching
    • U
      uok825 @sdetweil
      @sdetweil Sorry. I dont understand Sam. Can you help a little. What exactly will I write?
        sdetweil @uok825
        @uok825 there are two commands
        git reset -- package-lock.json
        and
        git checkout -- package-lock.json
        then git status
        U 1 Reply Last reply
        • U
          uok825 @sdetweil
            sdetweil @uok825
            @uok825 ok, now,
            git checkout master
            • U
              uok825 @sdetweil
              @sdetweil said in Cannot find module "moment":
              @uok825 ok, now,
              git checkout master
                sdetweil @uok825
                @uok825 ok, the upgrade script will handle that
                run upgrade with apply
                • U
                  uok825 @sdetweil
                  @sdetweil Nothing Happened.
                  My Log again:
                  Upgrade started - Paz Tem 12 22:41:23 +03 2020
                  system is Linux raspberrypi 4.19.118+ #1311 Mon Apr 27 14:16:15 BST 2020 armv6l GNU/Linux
                  the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                  user requested to apply changes
                  doing test run = false
                  saving custom.css
                  remote name = origin
                  upgrading from version 2.11.0 to 2.12.0
                  fetching latest revisions
                  git fetch rc=0
                  current branch = master
                  On branch master
                  Your branch is up to date with 'origin/master'.
                    (use "git add <file>..." to update what will be committed)
                    (use "git checkout -- <file>..." to discard changes in working directory)
                  	modified:   installers/mm.sh
                  	modified:   modules/default/newsfeed/newsfeed.js
                  	modified:   package-lock.json
                  	modified:   package.json
                  Untracked files:
                    (use "git add <file>..." to include in what will be committed)
                  	core
                  	css/icons/
                  	css/save_custom.css
                  	fonts/LemonMilk.otf
                  	installers/pm2_MagicMirror.json
                  	run-start.sh
                  no changes added to commit (use "git add" and/or "git commit -a")
                  there are 4 local files that are different than the master repo
                     installers/mm.sh
                     package-lock.json
                     package.json
                  save/restore files selection = n
                  restoring installers/mm.sh from repo
                  restoring modules/default/newsfeed/newsfeed.js from repo
                  restoring package-lock.json from repo
                  restoring package.json from repo
                  test merge result rc='' , if empty, no conflicts
                  executing merge, apply specified
                  merge result rc= 0
                   Already up to date.
                  processor architecture is armv6l
                  > magicmirror@2.12.0 install /home/pi/MagicMirror
                  " && cd vendor && npm install --loglevel=error
                  audited 150 packages in 44.188s
                  found 8 vulnerabilities (7 low, 1 high)
                    run `npm audit fix` to fix them, or `npm audit` for details
                  > magicmirror@2.12.0 postinstall /home/pi/MagicMirror
                  > npm run install-fonts && echo "MagicMirror installation finished successfully!
                  > magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
                  > echo "Installing fonts ...
                  " && cd fonts && npm install --loglevel=error
                  updated 1 package and audited 1 package in 19.099s
                  found 0 vulnerabilities
                  audited 1050 packages in 275.039s
                  74 packages are looking for funding
                    run `npm fund` for details
                  found 62 vulnerabilities (61 low, 1 moderate)
                  npm install completed - Paz Tem 12 22:46:48 +03 2020 on base
                  package.json update for armv6l completed ok
                  downloading dumpactivemodules script
                  processing for module MMM-MyPrayerTimes please wait
                  npm notice created a lockfile as package-lock.json. You should commit this file.
                  added 2 packages from 6 contributors and audited 2 packages in 12.29s
                  processing complete for module MMM-MyPrayerTimes
                  processing for module MMM-PIR please wait
                  > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
                  > node-gyp rebuild
                  make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                    CXX(target) Release/obj.target/epoll/src/epoll.o
                    SOLINK_MODULE(target) Release/obj.target/epoll.node
                    COPY Release/epoll.node
                  make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                  added 6 packages from 9 contributors and audited 6 packages in 57.611s
                  processing complete for module MMM-PIR
                  restoring custom.css
                  removing git alias
                  Upgrade ended - Paz Tem 12 22:48:25 +03 2020
                  Upgrade started - Sal Tem 14 17:31:45 +03 2020
                  saving custom.css
                  local version 2.12.0 already same as master 2.12.0
                  removing git alias
                  Upgrade ended - Sal Tem 14 17:31:48 +03 2020
                  Upgrade started - Cum Eki 30 11:24:00 +03 2020
                  saving custom.css
                  restoring file    package.json before switch back to master branch
                  package-lock.json: needs merge
                  local version 2.13.0 already same as master 2.13.0
                  removing git alias
                  Upgrade ended - Cum Eki 30 11:24:05 +03 2020
                  Upgrade started - Paz Tem 18 13:21:20 +03 2021
                  saving custom.css
                  reverting to master branch from develop, saving changed files
                  would restore file package.json before switch back to master branch
                  Upgrade ended - Paz Tem 18 13:21:23 +03 2021
                  Upgrade started - Paz Tem 18 13:44:35 +03 2021
                  saving custom.css
                  Upgrade ended - Paz Tem 18 13:44:37 +03 2021
                  Upgrade started - Paz Tem 18 13:44:39 +03 2021
                  saving custom.css
                  saving file package.json as package.json.save before switch back to master branch
                  Upgrade ended - Paz Tem 18 13:44:41 +03 2021
                  Raspberry’s date is wrong
                    sdetweil @uok825
                    @uok825 ok, I don’t get it.
                    git status
                    again
                    • U
                      uok825 @sdetweil
                      git status
                        sdetweil @uok825
                        @uok825 ok
                        git checkout package.json
                        git checkout master
                        • U
                          uok825 @sdetweil
                          git checkout master
                            sdetweil @uok825
                            @uok825 but we just checked out the older copy, so it should be unchanged now…
                            git diff package.json
                            • U
                              uok825 @sdetweil
                                sdetweil @uok825
                                @uok825 right, says no changes…
                                grep start package.json
                                • U
                                  uok825 @sdetweil
                                  Can you give me a Reputation. I cant reply you fast.
                                    sdetweil @uok825
                                    @uok825 hm… but that’s different than master, shouldn’t be.
                                    git stash
                                    git checkout master
                                    • U
                                      uok825 @sdetweil
                                      git checkout master
                                        sdetweil @uok825
                                        @uok825 yay!!!
                                        run upgrade apply
                                        • U
                                          uok825 @sdetweil
                                          @sdetweil 7183d73a-87b7-41e7-8c98-3a25969d7361-image.png It is not normal i think. I am about to cry. How can i check my MagicMirror version?
                                            sdetweil @uok825
                                            @uok825 but u had it downloaded already
                                            grep version package.json
                                            u were on develop
                                            so either 2.13 or 2.12
                                            • 3 / 5
