    Cannot find module "moment"
    98 Posts 2 Posters 68.3k Views 2 Watching
      sdetweil @uok825
      @uok825 ok, now,
      git checkout master
      U 1 Reply Last reply
      • U
        uok825 @sdetweil
        @sdetweil said in Cannot find module "moment":
        @uok825 ok, now,
        git checkout master
          sdetweil @uok825
          @uok825 ok, the upgrade script will handle that
          run upgrade with apply
          • U
            uok825 @sdetweil
            @sdetweil Nothing Happened.
            My Log again:
            Upgrade started - Paz Tem 12 22:41:23 +03 2020
            system is Linux raspberrypi 4.19.118+ #1311 Mon Apr 27 14:16:15 BST 2020 armv6l GNU/Linux
            the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
            user requested to apply changes
            doing test run = false
            saving custom.css
            remote name = origin
            upgrading from version 2.11.0 to 2.12.0
            fetching latest revisions
            git fetch rc=0
            current branch = master
            On branch master
            Your branch is up to date with 'origin/master'.
              (use "git add <file>..." to update what will be committed)
              (use "git checkout -- <file>..." to discard changes in working directory)
            	modified:   installers/mm.sh
            	modified:   modules/default/newsfeed/newsfeed.js
            	modified:   package-lock.json
            	modified:   package.json
            Untracked files:
              (use "git add <file>..." to include in what will be committed)
            	core
            	css/icons/
            	css/save_custom.css
            	fonts/LemonMilk.otf
            	installers/pm2_MagicMirror.json
            	run-start.sh
            no changes added to commit (use "git add" and/or "git commit -a")
            there are 4 local files that are different than the master repo
               installers/mm.sh
               package-lock.json
               package.json
            save/restore files selection = n
            restoring installers/mm.sh from repo
            restoring modules/default/newsfeed/newsfeed.js from repo
            restoring package-lock.json from repo
            restoring package.json from repo
            test merge result rc='' , if empty, no conflicts
            executing merge, apply specified
            merge result rc= 0
             Already up to date.
            processor architecture is armv6l
            > magicmirror@2.12.0 install /home/pi/MagicMirror
            " && cd vendor && npm install --loglevel=error
            audited 150 packages in 44.188s
            found 8 vulnerabilities (7 low, 1 high)
              run `npm audit fix` to fix them, or `npm audit` for details
            > magicmirror@2.12.0 postinstall /home/pi/MagicMirror
            > npm run install-fonts && echo "MagicMirror installation finished successfully!
            > magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
            > echo "Installing fonts ...
            " && cd fonts && npm install --loglevel=error
            updated 1 package and audited 1 package in 19.099s
            found 0 vulnerabilities
            audited 1050 packages in 275.039s
            74 packages are looking for funding
              run `npm fund` for details
            found 62 vulnerabilities (61 low, 1 moderate)
            npm install completed - Paz Tem 12 22:46:48 +03 2020 on base
            package.json update for armv6l completed ok
            downloading dumpactivemodules script
            processing for module MMM-MyPrayerTimes please wait
            npm notice created a lockfile as package-lock.json. You should commit this file.
            added 2 packages from 6 contributors and audited 2 packages in 12.29s
            processing complete for module MMM-MyPrayerTimes
            processing for module MMM-PIR please wait
            > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
            > node-gyp rebuild
            make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
              CXX(target) Release/obj.target/epoll/src/epoll.o
              SOLINK_MODULE(target) Release/obj.target/epoll.node
              COPY Release/epoll.node
            make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
            added 6 packages from 9 contributors and audited 6 packages in 57.611s
            processing complete for module MMM-PIR
            restoring custom.css
            removing git alias
            Upgrade ended - Paz Tem 12 22:48:25 +03 2020
            Upgrade started - Sal Tem 14 17:31:45 +03 2020
            saving custom.css
            local version 2.12.0 already same as master 2.12.0
            removing git alias
            Upgrade ended - Sal Tem 14 17:31:48 +03 2020
            Upgrade started - Cum Eki 30 11:24:00 +03 2020
            saving custom.css
            restoring file    package.json before switch back to master branch
            package-lock.json: needs merge
            local version 2.13.0 already same as master 2.13.0
            removing git alias
            Upgrade ended - Cum Eki 30 11:24:05 +03 2020
            Upgrade started - Paz Tem 18 13:21:20 +03 2021
            saving custom.css
            reverting to master branch from develop, saving changed files
            would restore file package.json before switch back to master branch
            Upgrade ended - Paz Tem 18 13:21:23 +03 2021
            Upgrade started - Paz Tem 18 13:44:35 +03 2021
            saving custom.css
            Upgrade ended - Paz Tem 18 13:44:37 +03 2021
            Upgrade started - Paz Tem 18 13:44:39 +03 2021
            saving custom.css
            saving file package.json as package.json.save before switch back to master branch
            Upgrade ended - Paz Tem 18 13:44:41 +03 2021
            Raspberry’s date is wrong
              sdetweil @uok825
              @uok825 ok, I don’t get it.
              git status
              again
              • U
                uok825 @sdetweil
                git status
                  sdetweil @uok825
                  @uok825 ok
                  git checkout package.json
                  git checkout master
                  • U
                    uok825 @sdetweil
                    git checkout master
                      sdetweil @uok825
                      @uok825 but we just checked out the older copy, so it should be unchanged now…
                      git diff package.json
                      • U
                        uok825 @sdetweil
                          sdetweil @uok825
                          @uok825 right, says no changes…
                          grep start package.json
                          • U
                            uok825 @sdetweil
                            Can you give me a Reputation. I cant reply you fast.
                              sdetweil @uok825
                              @uok825 hm… but that’s different than master, shouldn’t be.
                              git stash
                              git checkout master
                              • U
                                uok825 @sdetweil
                                git checkout master
                                  sdetweil @uok825
                                  @uok825 yay!!!
                                  run upgrade apply
                                  • U
                                    uok825 @sdetweil
                                    @sdetweil 7183d73a-87b7-41e7-8c98-3a25969d7361-image.png It is not normal i think. I am about to cry. How can i check my MagicMirror version?
                                      sdetweil @uok825
                                      @uok825 but u had it downloaded already
                                      grep version package.json
                                      u were on develop
                                      so either 2.13 or 2.12
                                      • U
                                        uok825 @sdetweil
                                        Version 2.12.0
                                        S 2 Replies Last reply
                                          sdetweil @uok825
                                          @uok825 run the upgrade script from installers
                                          like u were doing
                                          or run just the curl… part of the whole command so we can see the error
                                            @sdetweil NEVER EVER SUDO!!!
                                            • 3 / 5
