    Cannot find module "moment"
    98 Posts 2 Posters 67.0k Views 2 Watching
    • U
      uok825 @sdetweil
      @sdetweil Nothing Happened.
      My Log again:
      Upgrade started - Paz Tem 12 22:41:23 +03 2020
      system is Linux raspberrypi 4.19.118+ #1311 Mon Apr 27 14:16:15 BST 2020 armv6l GNU/Linux
      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
      user requested to apply changes
      doing test run = false
      saving custom.css
      remote name = origin
      upgrading from version 2.11.0 to 2.12.0
      fetching latest revisions
      git fetch rc=0
      current branch = master
      On branch master
      Your branch is up to date with 'origin/master'.
        (use "git add <file>..." to update what will be committed)
        (use "git checkout -- <file>..." to discard changes in working directory)
      	modified:   installers/mm.sh
      	modified:   modules/default/newsfeed/newsfeed.js
      	modified:   package-lock.json
      	modified:   package.json
      Untracked files:
        (use "git add <file>..." to include in what will be committed)
      	core
      	css/icons/
      	css/save_custom.css
      	fonts/LemonMilk.otf
      	installers/pm2_MagicMirror.json
      	run-start.sh
      no changes added to commit (use "git add" and/or "git commit -a")
      there are 4 local files that are different than the master repo
         installers/mm.sh
         package-lock.json
         package.json
      save/restore files selection = n
      restoring installers/mm.sh from repo
      restoring modules/default/newsfeed/newsfeed.js from repo
      restoring package-lock.json from repo
      restoring package.json from repo
      test merge result rc='' , if empty, no conflicts
      executing merge, apply specified
      merge result rc= 0
       Already up to date.
      processor architecture is armv6l
      > magicmirror@2.12.0 install /home/pi/MagicMirror
      " && cd vendor && npm install --loglevel=error
      audited 150 packages in 44.188s
      found 8 vulnerabilities (7 low, 1 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      > magicmirror@2.12.0 postinstall /home/pi/MagicMirror
      > npm run install-fonts && echo "MagicMirror installation finished successfully!
      > magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
      > echo "Installing fonts ...
      " && cd fonts && npm install --loglevel=error
      updated 1 package and audited 1 package in 19.099s
      found 0 vulnerabilities
      audited 1050 packages in 275.039s
      74 packages are looking for funding
        run `npm fund` for details
      found 62 vulnerabilities (61 low, 1 moderate)
      npm install completed - Paz Tem 12 22:46:48 +03 2020 on base
      package.json update for armv6l completed ok
      downloading dumpactivemodules script
      processing for module MMM-MyPrayerTimes please wait
      npm notice created a lockfile as package-lock.json. You should commit this file.
      added 2 packages from 6 contributors and audited 2 packages in 12.29s
      processing complete for module MMM-MyPrayerTimes
      processing for module MMM-PIR please wait
      > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
      > node-gyp rebuild
      make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
        CXX(target) Release/obj.target/epoll/src/epoll.o
        SOLINK_MODULE(target) Release/obj.target/epoll.node
        COPY Release/epoll.node
      make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
      added 6 packages from 9 contributors and audited 6 packages in 57.611s
      processing complete for module MMM-PIR
      restoring custom.css
      removing git alias
      Upgrade ended - Paz Tem 12 22:48:25 +03 2020
      Upgrade started - Sal Tem 14 17:31:45 +03 2020
      saving custom.css
      local version 2.12.0 already same as master 2.12.0
      removing git alias
      Upgrade ended - Sal Tem 14 17:31:48 +03 2020
      Upgrade started - Cum Eki 30 11:24:00 +03 2020
      saving custom.css
      restoring file    package.json before switch back to master branch
      package-lock.json: needs merge
      local version 2.13.0 already same as master 2.13.0
      removing git alias
      Upgrade ended - Cum Eki 30 11:24:05 +03 2020
      Upgrade started - Paz Tem 18 13:21:20 +03 2021
      saving custom.css
      reverting to master branch from develop, saving changed files
      would restore file package.json before switch back to master branch
      Upgrade ended - Paz Tem 18 13:21:23 +03 2021
      Upgrade started - Paz Tem 18 13:44:35 +03 2021
      saving custom.css
      Upgrade ended - Paz Tem 18 13:44:37 +03 2021
      Upgrade started - Paz Tem 18 13:44:39 +03 2021
      saving custom.css
      saving file package.json as package.json.save before switch back to master branch
      Upgrade ended - Paz Tem 18 13:44:41 +03 2021
      Raspberry’s date is wrong
        sdetweil @uok825
        @uok825 ok, I don’t get it.
        git status
        again
        U 1 Reply Last reply Reply Quote 0
        • U
          uok825 @sdetweil
          @sdetweil said in Cannot find module "moment":
          git status
            sdetweil @uok825
            @uok825 ok
            git checkout package.json
            git checkout master
            • U
              uok825 @sdetweil
              git checkout master
                sdetweil @uok825
                @uok825 but we just checked out the older copy, so it should be unchanged now…
                git diff package.json
                • U
                  uok825 @sdetweil
                    sdetweil @uok825
                    @uok825 right, says no changes…
                    grep start package.json
                    • U
                      uok825 @sdetweil
                      Can you give me a Reputation. I cant reply you fast.
                        sdetweil @uok825
                        @uok825 hm… but that’s different than master, shouldn’t be.
                        git stash
                        git checkout master
                        • U
                          uok825 @sdetweil
                          git checkout master
                            sdetweil @uok825
                            @uok825 yay!!!
                            run upgrade apply
                            • U
                              uok825 @sdetweil
                              @sdetweil 7183d73a-87b7-41e7-8c98-3a25969d7361-image.png It is not normal i think. I am about to cry. How can i check my MagicMirror version?
                                sdetweil @uok825
                                @uok825 but u had it downloaded already
                                grep version package.json
                                u were on develop
                                so either 2.13 or 2.12
                                • U
                                  uok825 @sdetweil
                                  Version 2.12.0
                                    sdetweil @uok825
                                    @uok825 run the upgrade script from installers
                                    like u were doing
                                    or run just the curl… part of the whole command so we can see the error
                                      @sdetweil NEVER EVER SUDO!!!
                                      • U
                                        uok825 @sdetweil
                                        @sdetweil Okey im sorry. Now run just
                                        curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh
                                          sdetweil @uok825
                                          @uok825
                                          cd ~
                                          MagicMirror/installers/upgrade-script.sh apply
                                          • U
                                            uok825 @sdetweil
                                            @sdetweil 0ac068d6-c12e-4b8a-8052-f77778b56ae2-image.pngAccess denied
                                            • 3 / 5
