    Cannot find module "moment"
    98 Posts 2 Posters 60.1k Views 2 Watching
      sdetweil @uok825
      @uok825 right, says no changes…
      grep start package.json
      U 1 Reply Last reply Reply Quote 0
      • U Offline
        uok825 @sdetweil
        @sdetweil said in Cannot find module "moment":
        Can you give me a Reputation. I cant reply you fast.
          sdetweil @uok825
          @uok825 hm… but that’s different than master, shouldn’t be.
          git stash
          git checkout master
          • U Offline
            uok825 @sdetweil
            git checkout master
              sdetweil @uok825
              @uok825 yay!!!
              run upgrade apply
              • U Offline
                uok825 @sdetweil
                @sdetweil 7183d73a-87b7-41e7-8c98-3a25969d7361-image.png It is not normal i think. I am about to cry. How can i check my MagicMirror version?
                  sdetweil @uok825
                  @uok825 but u had it downloaded already
                  grep version package.json
                  u were on develop
                  so either 2.13 or 2.12
                  • U Offline
                    uok825 @sdetweil
                    Version 2.12.0
                      sdetweil @uok825
                      @uok825 run the upgrade script from installers
                      like u were doing
                      or run just the curl… part of the whole command so we can see the error
                        @sdetweil NEVER EVER SUDO!!!
                        • U Offline
                          uok825 @sdetweil
                          @sdetweil Okey im sorry. Now run just
                          curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh
                            sdetweil @uok825
                            @uok825
                            cd ~
                            MagicMirror/installers/upgrade-script.sh apply
                            • U Offline
                              uok825 @sdetweil
                              @sdetweil 0ac068d6-c12e-4b8a-8052-f77778b56ae2-image.pngAccess denied
                                sdetweil @uok825
                                @uok825 ah, didn’t mark executable
                                cd ~
                                chmod +x MagicMirror/installers/upgrade-script.sh
                                • U Offline
                                  uok825 @sdetweil
                                    sdetweil @uok825
                                    @uok825 when I do the curl i get
                                    #!/bin/bash
                                    # only DO npm installs when flag is set to  1
                                    # test when set to 0
                                    true=1
                                    plus all the rest of the script.
                                    u have a networking problem going on …
                                    warning, upgrade might fail as IT will try to download new files too
                                    yes, the upgrade uses curl to get the new package.json file to check the version
                                    remote_version=$(curl -s https://raw.githubusercontent.com/MichMich/MagicMirror/master/package.json
                                    and it also fails…
                                    SO… u need to solve that… are you using pihole somewhere?
                                    U 2 Replies Last reply Reply Quote 0
                                    • U Offline
                                      uok825 @sdetweil
                                      @sdetweil AHHHHHHH! Just remembered my other raspberry is stuck on internet too. I change my router so my router adress is changed from 192.168.1.1 to 192.168.1.3 but in my /etc/dhcpcd.conf 37c38ff5-5fcd-4f9b-83c0-5dac86ded6f4-image.png still 192.168.1.1 here sorry for bother you. Trying again.
                                      • U Offline
                                        uok825 @sdetweil
                                        Seems fine. Thanks now i rebooting machine and watch if there is a error.
                                        pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetwe        il/MagicMirror_scripts/master/upgrade-script.sh)" apply
                                        No LSB modules are available.
                                        doing test run = false
                                        saving custom.css
                                        upgrading from version 2.12.0 to 2.16.0
                                        fetching latest revisions
                                        remote: Enumerating objects: 4413, done.
                                        remote: Counting objects: 100% (3550/3550), done.
                                        remote: Compressing objects: 100% (1006/1006), done.
                                        remote: Total 2836 (delta 1962), reused 2490 (delta 1660), pack-reused 0
                                        Receiving objects: 100% (2836/2836), 967.15 KiB | 156.00 KiB/s, done.
                                        Resolving deltas: 100% (1962/1962), completed with 207 local objects.
                                        From https://github.com/MichMich/MagicMirror
                                           10dc315f..26a76f80  master     -> origin/master
                                         * [new tag]           v2.16.0    -> v2.16.0
                                         * [new tag]           v2.15.0    -> v2.15.0
                                        npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@        1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my        best with it!
                                        > core-js@3.15.1 postinstall /home/pi/MagicMirror/node_modules/core-js
                                        > node -e "try{require('./postinstall')}catch(e){}"
                                        Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfill        ing JavaScript standard library!
                                        The project needs your help! Please consider supporting of core-js on Open Colle        ctive or Patreon:
                                        > https://opencollective.com/core-js
                                        > https://www.patreon.com/zloirock
                                        Also, the author of core-js ( https://github.com/zloirock ) is looking for a goo        d job -)
                                        > electron@11.4.9 postinstall /home/pi/MagicMirror/node_modules/electron
                                        > node install.js
                                        HTTPError: Response code 404 (Not Found) for https://github.com/electron/electro        n/releases/download/v11.4.9/electron-v11.4.9-linux-armv6l.zip
                                            at EventEmitter.emitter.on.response (/home/pi/MagicMirror/node_modules/got/s        ource/as-stream.js:35:24)
                                            at EventEmitter.emit (events.js:198:13)
                                            at module.exports (/home/pi/MagicMirror/node_modules/got/source/get-response        .js:22:10)
                                            at ClientRequest.handleResponse (/home/pi/MagicMirror/node_modules/got/sourc        e/request-as-event-emitter.js:155:5)
                                            at Object.onceWrapper (events.js:286:20)
                                            at ClientRequest.emit (events.js:203:15)
                                            at ClientRequest.origin.emit.args [as emit] (/home/pi/MagicMirror/node_modul        es/@szmarczak/http-timer/source/index.js:37:11)
                                            at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:565:21        )
                                            at HTTPParser.parserOnHeadersComplete (_http_common.js:111:17)
                                            at TLSSocket.socketOnData (_http_client.js:451:20)
                                        > magicmirror@2.16.0 install /home/pi/MagicMirror
                                        " && cd vendor && npm install --loglevel=error
                                        > @fortawesome/fontawesome-free@5.15.3 postinstall /home/pi/MagicMirror/vendor/n        ode_modules/@fortawesome/fontawesome-free
                                        > node attribution.js
                                        Font Awesome Free 5.15.3 by @fontawesome - https://fontawesome.com
                                        License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL        1.1, Code: MIT License)
                                        added 1 package from 1 contributor, removed 74 packages, updated 5 packages and        audited 9 packages in 83.089s
                                        found 0 vulnerabilities
                                        > magicmirror@2.16.0 postinstall /home/pi/MagicMirror
                                        > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                        > magicmirror@2.16.0 install-fonts /home/pi/MagicMirror
                                        > echo "Installing fonts ...
                                        " && cd fonts && npm install --loglevel=error
                                        audited 1 package in 7.24s
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 (node_modules/el        ectron):
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 postinstall: `no        de install.js`
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                        added 67 packages from 88 contributors, removed 489 packages, updated 98 package        s and audited 923 packages in 621.679s
                                        34 packages are looking for funding
                                          run `npm fund` for details
                                        processing for module MMM-MyPrayerTimes please wait
                                        npm notice created a lockfile as package-lock.json. You should commit this file.
                                        added 2 packages from 6 contributors and audited 2 packages in 16.096s
                                        processing complete for module MMM-MyPrayerTimes
                                        processing for module MMM-LICE please wait
                                        added 64 packages from 69 contributors and audited 64 packages in 71.651s
                                        13 packages are looking for funding
                                        processing complete for module MMM-LICE
                                        processing for module MMM-PIR please wait
                                        > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
                                        > node-gyp rebuild
                                        make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                                          CXX(target) Release/obj.target/epoll/src/epoll.o
                                          SOLINK_MODULE(target) Release/obj.target/epoll.node
                                          COPY Release/epoll.node
                                        make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                                        added 6 packages from 9 contributors and audited 6 packages in 72.078s
                                        processing complete for module MMM-PIR
                                        restoring custom.css
                                          sdetweil @uok825
                                          @uok825 cool… didn’t need to reboot… I would have asked u to check the package.json file start line
                                          • U Offline
                                            uok825 @sdetweil
                                            Now another module give an error
                                            0|MagicMir | [26.07.2021 00:57.11.255] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'uuid/v4'
                                            0|MagicMir | [26.07.2021 00:57.11.503] [ERROR] Whoops! There was an uncaught exception...
                                            0|MagicMir | [26.07.2021 00:57.11.562] [ERROR] { Error: Cannot find module 'uuid/v4'
                                            0|MagicMir |     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                            0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                            0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                            0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:692:17)
                                            0|MagicMir |     at require (internal/modules/cjs/helpers.js:25:18)
                                            0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/node_modules/request/lib/auth.js:4:12)
                                            0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:778:30)
                                            0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                            0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:653:32)
                                            0|MagicMir |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12) code: 'MODULE_NOT_FOUND' }
                                            0|MagicMir | [26.07.2021 00:57.11.573] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                            0|MagicMir | [26.07.2021 00:57.11.584] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                            /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                                            0|MagicMir | [26.07.2021 00:57.08.308] [LOG] Module helper loaded: newsfeed
                                            0|MagicMir | [26.07.2021 00:57.11.270] [LOG] Loading module helpers ...
                                            0|MagicMir | [26.07.2021 00:57.11.284] [LOG] No helper found for module: alert.
                                            0|MagicMir | [26.07.2021 00:57.11.294] [LOG] Initializing new module helper ...
                                            0|MagicMir | [26.07.2021 00:57.11.307] [LOG] Module helper loaded: updatenotification
                                            0|MagicMir | [26.07.2021 00:57.11.316] [LOG] No helper found for module: clock.
                                            0|MagicMir | [26.07.2021 00:57.11.330] [LOG] Initializing new module helper ...
                                            0|MagicMir | [26.07.2021 00:57.11.340] [LOG] Module helper loaded: calendar
                                            0|MagicMir | [26.07.2021 00:57.11.355] [LOG] Initializing new module helper ...
                                            0|MagicMir | [26.07.2021 00:57.11.361] [LOG] Module helper loaded: currentweather
                                            0|MagicMir | [26.07.2021 00:57.11.372] [LOG] Initializing new module helper ...
                                            0|MagicMir | [26.07.2021 00:57.11.382] [LOG] Module helper loaded: weatherforecast
                                            0|MagicMir | [26.07.2021 00:57.11.396] [LOG] Initializing new module helper ...
                                            0|MagicMir | [26.07.2021 00:57.11.405] [LOG] Module helper loaded: newsfeed
                                            0|MagicMir | Starting chromium browser now, have patience, it takes a minute
                                            Internet is fine.
                                            Package.json
                                            • 3 / 5
