    Show Alexa Timer
    16 Posts 5 Posters 5.5k Views 6 Watching
    • MZ-BERM Offline
      MZ-BER
      Hey there 👋 - I would like to display the remaining time of a timer that I scheduled via a physical EchoDot.
      Is there a way to have a module pop up with a timer as soon as I requested it from the EchoDot? Similar to this Module?
      Can you please give me an advice in which direction I can investigate? Is there an API available?
      Thank you very much in advance!
      Best regards from Berlin.
        sdetweil @MZ-BER
        @mz-ber I am not aware of any support for this…
        you know that timers are echo device specific, right?
        start a timer on echo 1, you cannot find it or control it on echo 2
        and a real timer has two parts, on the amazon server is the actual timer event.
        on an echo with a display, there is an independent visual started when the ‘starting now’ is spoken
        • MZ-BERM Offline
          MZ-BER
          Hello @sdetweil - thanks for your quick response.
          I guess you are half right. As soon as I trigger a timer with the EchoDot, I can see it on my iPad, iPhone etc.
          There is some connection - similar to the Module “MMM-NowPlayingOnSpotify”
          And I’ve noticed that some guys from the Home-Assistant Community developed a similar thing (Alexa Timer Card)
          Here are some images from my iPad:
            sdetweil @MZ-BER
            @mz-ber right, but u had to go into the alexa app to get that .
            it didn’t just occur natuarally.
            MZ-BERM cowboysdudeC 2 Replies Last reply Reply Quote 0
            • MZ-BERM Offline
              MZ-BER @sdetweil
              @sdetweil I adjusted my post above with an additional note about the Home Assistant Community that I found.
              https://community.home-assistant.io/t/alexa-timer-card/258234
                sdetweil @MZ-BER
                @mz-ber i saw… looking… somehow they have an alexa api trying to find it…
                  sdetweil @MZ-BER
                  @mz-ber cool… looks like there is a rest api for alarms…
                  https://developer.amazon.com/en-US/docs/alexa/alexa-voice-service/avs-rest-alarms.html
                  haven’t found a node library for this
                  • MZ-BERM Offline
                    MZ-BER
                    @sdetweil Another guy added that as well and presented it on YouTube
                    He also mentioned something in the comments.
                    If that is not working I guess I’ll buy a microphone and test that with the awesome alexa module.
                      sdetweil @MZ-BER
                      @mz-ber awesome alexa will let u set an alarm (its all thru voice) …
                      MZ-BERM 1 Reply Last reply Reply Quote 1
                      • MZ-BERM Offline
                        MZ-BER @sdetweil
                        @sdetweil Oh okay, you can only set an alarm and not a Timer?
