used the amazing complete setup but after 'npm start'.....
17 Posts 6 Posters 10.0k Views 4 Watching
    alonshwartz1966
    I’ve received error messages (see below). WHat should I do?
    sh: 1: electron: not found
    npm ERR! Linux 4.4.34-v7+
    npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
    npm ERR! node v6.9.2
    npm ERR! npm v3.10.9
    npm ERR! file sh
    npm ERR! code ELIFECYCLE
    npm ERR! errno ENOENT
    npm ERR! syscall spawn
    npm ERR! magicmirror@2.0.0 start: electron js/electron.js
    npm ERR! spawn ENOENT
    npm ERR!
    npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
    npm ERR! If you do, this is most likely a problem with the magicmirror package,
    npm ERR! not with npm itself.
    npm ERR! electron js/electron.js
    npm ERR! npm bugs magicmirror
    npm ERR! Or if that isn’t available, you can get their info via:
    npm ERR! npm owner ls magicmirror
    npm ERR! /home/pi/MagicMirror/npm-debug.log
    N 1 Reply Last reply Dec 14, 2016, 10:20 PM Reply Quote 0
    • N Offline
      nuckinfutz @alonshwartz1966
      @alonshwartz1966 you either are tring to start the mirror from the root folder or you didn’t install node.js correctly I believe. I’m on my cell sorry I could give a better answer. I’ll check later tonight
        broberg Project Sponsor
        Run the install script again.
        A 1 Reply Last reply Dec 16, 2016, 5:01 PM Reply Quote 0
        • N Offline
          nem1
          please check if you had a stabile connection to the internet while running the install process of the mirror. just try it again if you are sure. Thix fixed my problem in the beginning
          A 1 Reply Last reply Dec 16, 2016, 5:04 PM Reply Quote 0
            Ancient
            I’ve got the same Problem.
            Fresh installation of Raspian on an Raspberry Pi3.
            Running the install Script again doesn’t help.
            B 1 Reply Last reply Dec 15, 2016, 10:53 AM Reply Quote 0
              broberg Project Sponsor @Ancient
              @Ancient said in used the amazing complete setup but after 'npm start'.....:
              Even if you remove the magicmirror folder before running it again?
              I had a similar issue (don’t know if it was exactly the same, since I didn’t save the log).
              It seems like the Electron.js is the issue, in my case it was missing for some reason, removing the magicmirror folder and running the install script again did the trick for me.
                Ancient
                Yep,
                deleteing as well as renaming the MagicMirror Folder won’t do the trick for me.
                Maybe it’s related to this Issue https://github.com/MichMich/MagicMirror/issues/567
                Where should the electron.js be located, i believe it’s missing here too.
                  Yep,
                  In the magicmirror folder, node_modules and then electron or electron-prebuilt
                  maybe try to install it manually?
                  npm install electron --save-dev
                    also, are you all running the X GUI or are you trying to start it directly from the prompt it boots in to?
                      Ancient
                      I try to start it directly from the prompt
                      electron@1.4.12 postinstall /home/pi/MagicMirror/node_modules/electron
                      node install.js
                      magicmirror@2.0.0 /home/pi/MagicMirror
                      ├── electron@1.4.12
                      └── UNMET PEER DEPENDENCY grunt@1.0.1
                      npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
