    used the amazing complete setup but after 'npm start'.....
    17 Posts 6 Posters 10.8k Views 4 Watching
    • alonshwartz1966A Offline
      alonshwartz1966
      I’ve received error messages (see below). WHat should I do?
      sh: 1: electron: not found
      npm ERR! Linux 4.4.34-v7+
      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
      npm ERR! node v6.9.2
      npm ERR! npm v3.10.9
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.0.0 start: electron js/electron.js
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR! electron js/electron.js
      npm ERR! npm bugs magicmirror
      npm ERR! Or if that isn’t available, you can get their info via:
      npm ERR! npm owner ls magicmirror
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      • N Offline
        nuckinfutz @alonshwartz1966
        @alonshwartz1966 you either are tring to start the mirror from the root folder or you didn’t install node.js correctly I believe. I’m on my cell sorry I could give a better answer. I’ll check later tonight
        • brobergB Offline
          broberg Project Sponsor
          Run the install script again.
          alonshwartz1966A 1 Reply Last reply Reply Quote 0
          • N Offline
            nem1
            please check if you had a stabile connection to the internet while running the install process of the mirror. just try it again if you are sure. Thix fixed my problem in the beginning
              Ancient
              I’ve got the same Problem.
              Fresh installation of Raspian on an Raspberry Pi3.
              Running the install Script again doesn’t help.
              • brobergB Offline
                broberg Project Sponsor @Ancient
                @Ancient said in used the amazing complete setup but after 'npm start'.....:
                Even if you remove the magicmirror folder before running it again?
                I had a similar issue (don’t know if it was exactly the same, since I didn’t save the log).
                It seems like the Electron.js is the issue, in my case it was missing for some reason, removing the magicmirror folder and running the install script again did the trick for me.
                  Ancient
                  Yep,
                  deleteing as well as renaming the MagicMirror Folder won’t do the trick for me.
                  Maybe it’s related to this Issue https://github.com/MichMich/MagicMirror/issues/567
                  Where should the electron.js be located, i believe it’s missing here too.
                  • brobergB Offline
                    Yep,
                    In the magicmirror folder, node_modules and then electron or electron-prebuilt
                    maybe try to install it manually?
                    npm install electron --save-dev
                    • brobergB Offline
                      also, are you all running the X GUI or are you trying to start it directly from the prompt it boots in to?
                        Ancient
                        I try to start it directly from the prompt
                        electron@1.4.12 postinstall /home/pi/MagicMirror/node_modules/electron
                        node install.js
                        magicmirror@2.0.0 /home/pi/MagicMirror
                        ├── electron@1.4.12
                        └── UNMET PEER DEPENDENCY grunt@1.0.1
                        npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
