    used the amazing complete setup but after 'npm start'.....
    17 Posts 6 Posters 10.8k Views 4 Watching
    • brobergB Offline
      broberg Project Sponsor @Ancient
      @Ancient said in used the amazing complete setup but after 'npm start'.....:
      I’ve got the same Problem.
      Fresh installation of Raspian on an Raspberry Pi3.
      Running the install Script again doesn’t help.
      Even if you remove the magicmirror folder before running it again?
      I had a similar issue (don’t know if it was exactly the same, since I didn’t save the log).
      It seems like the Electron.js is the issue, in my case it was missing for some reason, removing the magicmirror folder and running the install script again did the trick for me.
        Ancient
        Yep,
        deleteing as well as renaming the MagicMirror Folder won’t do the trick for me.
        Maybe it’s related to this Issue https://github.com/MichMich/MagicMirror/issues/567
        Where should the electron.js be located, i believe it’s missing here too.
        • brobergB Offline
          Yep,
          In the magicmirror folder, node_modules and then electron or electron-prebuilt
          maybe try to install it manually?
          npm install electron --save-dev
          • brobergB Offline
            also, are you all running the X GUI or are you trying to start it directly from the prompt it boots in to?
              Ancient
              I try to start it directly from the prompt
              electron@1.4.12 postinstall /home/pi/MagicMirror/node_modules/electron
              node install.js
              magicmirror@2.0.0 /home/pi/MagicMirror
              ├── electron@1.4.12
              └── UNMET PEER DEPENDENCY grunt@1.0.1
              npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
              • alonshwartz1966A Offline
                alonshwartz1966 @broberg
                @broberg the install of what? the entire process of the MagicMirrir?
                  alonshwartz1966 @nem1
                  @nem1 thanks for the feedback. My connection was OK during the installation
                  • brobergB Offline
                    broberg Project Sponsor @alonshwartz1966
                    @alonshwartz1966
                    Yes, remove the entire magicmirror folder and run the install script again, for me the script stopped (without errors) several times,
                    Also, when you are trying to start it, do you try to start it via the LXterminal in the desktop environment or directly in the boot prompt?
                    alonshwartz1966A 1 Reply Last reply Reply Quote 0
                    • H Offline
                      Heretic
                      I get a very similar error if I’m just running at the CLI. With the GUI running NPM START (from a local terminal window) is successful, I never did get it going from CLI.
                      I also never got PM2 to successfully work without manually kicking it off after the gui has launched.
                      I’ve taken about 4 runthroughs at the install, so at this point I’ve no idea what the issue is.
                      pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
                      magicmirror@2.0.0 start /home/pi/MagicMirror
                      electron js/electron.js
                      npm ERR! Linux 4.4.32-v7+
                      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
                      npm ERR! node v6.9.1
                      npm ERR! npm v4.0.2
                      npm ERR! code ELIFECYCLE
                      npm ERR! magicmirror@2.0.0 start: electron js/electron.js
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
                      npm ERR! If you do, this is most likely a problem with the magicmirror package,
                      npm ERR! not with npm itself.
                      npm ERR! electron js/electron.js
                      npm ERR! npm bugs magicmirror
                      npm ERR! Or if that isn’t available, you can get their info via:
                      npm ERR! npm owner ls magicmirror
                      npm ERR! /home/pi/MagicMirror/npm-debug.log
                      • N Offline
                        nuckinfutz
                        Here is what I would do as I’ve been in your shoes’
                        This is how I do it and I’ve done it close to 50 times.
                        Ignore everyone else for now. You will be starting from scratch. Again.
                        Go here and follow the Noobs install procedure. You want the full Noobs NOT Noobs Lite
                        https://www.raspberrypi.org/downloads/noobs/
                        When you boot this choose the first option (raspian) After it finishes
                        Dont add users or change anything else leave all defaults with the exception of the following
                        Make sure you set your localization, keyboard, wireless etc. by going to
                        Preferences -> Raspberry Pi Configuration
                        Open a terminal session
                        Your prompt should look like the following
                        pi@raspberrypi:~ $
                        copy and paste the following into a terminal. This is one line. accept any defaults if a question comes up.
                        curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                        Now Copy and paste
                        cd /home/pi/MagicMirror
                        DISPLAY=:0 npm start dev
                        If you dont want the Console running omit “dev” from the end
                        I always start the MM using this method.
