    used the amazing complete setup but after 'npm start'.....
    17 Posts 6 Posters 11.8k Views 4 Watching
      Ancient
      I’ve got the same Problem.
      Fresh installation of Raspian on an Raspberry Pi3.
      Running the install Script again doesn’t help.
        broberg Project Sponsor @Ancient
        @Ancient said in used the amazing complete setup but after 'npm start'.....:
        Even if you remove the magicmirror folder before running it again?
        I had a similar issue (don’t know if it was exactly the same, since I didn’t save the log).
        It seems like the Electron.js is the issue, in my case it was missing for some reason, removing the magicmirror folder and running the install script again did the trick for me.
          Ancient
          Yep,
          deleteing as well as renaming the MagicMirror Folder won’t do the trick for me.
          Maybe it’s related to this Issue https://github.com/MichMich/MagicMirror/issues/567
          Where should the electron.js be located, i believe it’s missing here too.
            Yep,
            In the magicmirror folder, node_modules and then electron or electron-prebuilt
            maybe try to install it manually?
            npm install electron --save-dev
              also, are you all running the X GUI or are you trying to start it directly from the prompt it boots in to?
                Ancient
                I try to start it directly from the prompt
                electron@1.4.12 postinstall /home/pi/MagicMirror/node_modules/electron
                node install.js
                magicmirror@2.0.0 /home/pi/MagicMirror
                ├── electron@1.4.12
                └── UNMET PEER DEPENDENCY grunt@1.0.1
                npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
                  alonshwartz1966 @broberg
                  @broberg the install of what? the entire process of the MagicMirrir?
                    alonshwartz1966 @nem1
                    @nem1 thanks for the feedback. My connection was OK during the installation
                      broberg Project Sponsor @alonshwartz1966
                      @alonshwartz1966
                      Yes, remove the entire magicmirror folder and run the install script again, for me the script stopped (without errors) several times,
                      Also, when you are trying to start it, do you try to start it via the LXterminal in the desktop environment or directly in the boot prompt?
                      • H Offline
                        Heretic
                        I get a very similar error if I’m just running at the CLI. With the GUI running NPM START (from a local terminal window) is successful, I never did get it going from CLI.
                        I also never got PM2 to successfully work without manually kicking it off after the gui has launched.
                        I’ve taken about 4 runthroughs at the install, so at this point I’ve no idea what the issue is.
                        pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
                        magicmirror@2.0.0 start /home/pi/MagicMirror
                        electron js/electron.js
                        npm ERR! Linux 4.4.32-v7+
                        npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
                        npm ERR! node v6.9.1
                        npm ERR! npm v4.0.2
                        npm ERR! code ELIFECYCLE
                        npm ERR! magicmirror@2.0.0 start: electron js/electron.js
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
                        npm ERR! If you do, this is most likely a problem with the magicmirror package,
                        npm ERR! not with npm itself.
                        npm ERR! electron js/electron.js
                        npm ERR! npm bugs magicmirror
                        npm ERR! Or if that isn’t available, you can get their info via:
                        npm ERR! npm owner ls magicmirror
                        npm ERR! /home/pi/MagicMirror/npm-debug.log
                        • N Offline
                          nuckinfutz
                          Here is what I would do as I’ve been in your shoes’
                          This is how I do it and I’ve done it close to 50 times.
                          Ignore everyone else for now. You will be starting from scratch. Again.
                          Go here and follow the Noobs install procedure. You want the full Noobs NOT Noobs Lite
                          https://www.raspberrypi.org/downloads/noobs/
                          When you boot this choose the first option (raspian) After it finishes
                          Dont add users or change anything else leave all defaults with the exception of the following
                          Make sure you set your localization, keyboard, wireless etc. by going to
                          Preferences -> Raspberry Pi Configuration
                          Open a terminal session
                          Your prompt should look like the following
                          pi@raspberrypi:~ $
                          copy and paste the following into a terminal. This is one line. accept any defaults if a question comes up.
                          curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                          Now Copy and paste
                          cd /home/pi/MagicMirror
                          DISPLAY=:0 npm start dev
                          If you dont want the Console running omit “dev” from the end
                          I always start the MM using this method.
                            alonshwartz1966 @nuckinfutz
                            @nuckinfutz Hi. Thanks for the instructions. I’ve managed to run the MagicMirror. Now I just need to work on adjustments.
                              @broberg Hi. Thanks for the instructions. I’ve managed to run the MagicMirror. Now I just need to work on adjustments.
