    Home Assistant Toggle?
    3 Posts 3 Posters 1.5k Views 3 Watching
      bendonahue
      Hi all,
      I’m new to MagicMirror but can see me enjoying it a LOT , once I get my head around everything that is. Oh, and please accept my apologies if this post is in the wrong place :)
      What got me in to the idea of a MagicMirror is this video on YT - https://www.youtube.com/watch?v=QBJH3s0cIJE&t=4s
      They use a ‘toggle’ in the bottom right corner to switch between MM and Home Assistant, but unfortunately he doesn’t explain how to do this. I’ve looked on this forum, and googled everything I can think of but no luck.
      Does anybody know? This would be great for me as I have a dashboard for HA and if I can switch between the two quickly like this it would be amazing!!
      Any help would be appreciated :)
      S F 2 Replies Last reply Reply Quote 0
        smithbill17 @bendonahue
        @bendonahue It looks like he’s using the MMM-OnScreenMenu module. I don’t know how he’s using it, but he’s probably hiding/showing Home Assistant as some sort of embedded module or webpage.
        Possibly his Home Assistant page is inside an iFrame using the MMM-iFrame module and he’s using a toggle to show/hide the iFrame (as per the show/hide clock example in the MMM-OnScreenMenu module). This might explain the white ‘border’ that appears on the right & bottom of his HA controls page.
        There will be some HA dashboard cards don’t like being inside an iFrame so may not work correctly.
        • F Offline
          fribse @bendonahue
          @bendonahue I’ve set it up here with MQTT.
          I wrote a small guide on the HA forum:
          https://community.home-assistant.io/t/magicmirror-integration-into-home-assistant-with-mqtt/177246/15
