    MMM-WeatherBackground
    54 Posts 14 Posters 33.5k Views 14 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @richland007
      @richland007 Yes they are…I play with code…THEY know it.
        @cowboysdude said in MMM-WeatherBackground:
        Don’t sell yourself short, bro. There hasn’t been a module I’ve broken that you haven’t been able to fix. I tip my hat to you.
          @mykle1 yeah well…
            A Former User
            I’ve added configuration sample for NOAA3.
            I like @cowboysdude’s forked version, but it’s images are static.
            I always love random. That is why I build this module.
            Fortunately, since @cowboysdude updated his NOAA3, now I can suggest a configuration for my original to use with NOAA3
              //disabled:true,
              module: "MMM-WeatherBackground",
                targetDOM: ".MMM-Dummy", // < -- change to where you want to display
                notification: "WEATHER",
                payloadConverter:(payload)=>{
                  var n = (moment().isAfter(moment(payload.sunset))) ? "night" : "day"
                  var iconMap = {
                    "tstorms": "thunderstorm",
                    "chancesnow": "snow"
                  var ret = (payload.icon in iconMap) ? iconMap[payload.icon] : payload.icon
                  return ret + " " + n
            • BKeyportB Offline
              BKeyport Module Developer
              This module is supposed to be weather images, yet, I have seen exactly one image that’s weather related.
              Most of the time, it’s keyboards, computer related stuff, people, etc.
              Can I restrict the pictures?
                A Former User @BKeyport
                @bkeyport
                Frankly, it is not so easy, because images are the result of searching keywords in unslpash.
                Ideally, https://source.unsplash.com/featured/?clouds should show the clouds - weather related image. But in unsplash, many images - not related with weather itself - might have that name “clouds” because, just photographer named as it.
                I regard it as a funny random stuffs - not weather itself but something like mood or feeling.
                You can adjust obvious keywords in payloadConverter to clearer ones. By example, In above configuration, I change “tstorms” => “thunderstorm”.
                Or if you are using MMM-NOAA3, Try cowboysdude’s forked version.(https://github.com/cowboysdude/MMM-WeatherBackground).
                Instead getting image from unsplash, it serves prepared static image.
                  It’s a great module!! Yes it’s random pictures but it’s still VERY cool because in reality the pictures returned are usually really good!!!
                    A Former User
                    UPDATED
                    [2018-12-03]
                    • Now you can simply set source instead complex notification & payloadConverter
                      • MMM-DarkSkyForecast is supported as source
                      • Currently supported source : currentweather, MMM-NOAA3, MMM-DarkSkyForecast
                    • Background image position is centered now.
                      UPDATED
                      [2018-12-13]
                      @bkeyport
                      Now you can assign specific collection to specific keyword as your wish to get more related pictures.
                      By example, you can assign 1877260 as source of clear-day pictures.
                      0m4r0 1 Reply Last reply Reply Quote 1
                      • 0m4r0 Offline
                        0m4r Module Developer @Guest
                        is this supposed to work with: MMM-OpenWeatherForecast?
                        and how should this behave if there is more than one instance of the same plugin configured?
                        I see the module, and this post, are not really active, so if it is not supported (or maintained) anymore - just ignore me!
                        https://github.com/0m4r
                          MMRIZE @0m4r
                          @0m4r
                          I was the original author of that module. ;)
                          Basically, if any module could emit any notification and it could be translated properly, it will work.
                          You can define your customization with payloadConverter and notification in config.js
                          notification: "SOME MODULE NOTI",
                                  return  "windy night spring"  // <= query text for the image.
                          Currently, this module is managed by brianHelper
                          0m4r0 E 2 Replies Last reply Reply Quote 2
                          • 0m4r0 Offline
                            0m4r Module Developer @MMRIZE
                            @mmrize hey thanks! I figure that out myself already digging into the code!
                            cool module, I never really thought about using an event to customize the payload and have a function as a config value… I may play around with it a little more and come back if I have any question :)
                              bhepler Module Developer
                              Updated 2021-09-13
                              Thanks goes to @eouia for the many changes.
                              REMOVED Removing dependency of dying momentJS
                              ADDED config.monthMap : Now you can define keywords per month. (It could be the replacement of config.hemisphere). You can set winter christmas santa-clause as keyword for December. Or you can set spring to March, April, May.
                              ADDED config.externalCollections : separated collections data to external file.
                              ADDED config.size is added. you can set pictures original dimension by this value. (this value is not for cropping. Rather for resolution optimizing.)
                              CHANGED Default weather module source - weather is added.
                              REMOVED Obsoleted weather module source - currentweather is removed.
                              ADDED CSS controllable. Now you can control the style(CSS selector .WTHBGR) more comfortably.
                              CHANGED Current collection list was too huge and not maintained. Now Collection fallback is supported. When the module cannot find a proper collection, the keyword searching would be alternated instead.
                              CHANGED Now, collection matching is based on match-score.
                                Updated 2022-05-07
                                • I updated the README for a more complete documentation of the module and options.
                                • Expanded the default collections to source the images.
                                • Added more logging messages for verbose mode
                                • E Offline
                                  EphraimB @MMRIZE
                                  @MMRIZE How do I get it to work with open weather module?
                                    MMRIZE @EphraimB
                                    @EphraimB
                                    There were so many modules using openweather API(So I don’t know which module is what you mentioned), but since MM changed its default weather module, the default weather module could also handle openweather API natively. So, just use the default weather module.
                                    Or, request the developer of your open-weather-using-module to support CURRENTWEATHER_TYPE notification to be compatible with the default weather module.
                                    • E Offline
                                      EphraimB @MMRIZE
                                      @MMRIZE This one: https://github.com/jclarke0000/MMM-OpenWeatherForecast
                                        bhepler Module Developer @EphraimB
                                        @EphraimB - Sounds like a useful modification. I’m working on it now. It doesn’t seem terribly difficult to add.
                                        Edit: Okay, done. It should accept notifications from the MMM-OpenWeatherForecast app. Update the module, change the source parameter to “MMM-OpenWeatherForecast” and it should pick up the notifications.
                                        FoziF E 2 Replies Last reply Reply Quote 1
                                        • FoziF Offline
                                          Fozi Project Sponsor @bhepler
                                          @bhepler Your update for OpenWeatherForecast works with me! Thanks for your effort!
                                          • E Offline
                                            EphraimB @bhepler
                                            @bhepler It works now. Thank you!
                                            • 3 / 3
