    Weatherunderground - currently - hourly - daily - configurable
    126 Posts 26 Posters 227.5k Views 13 Watching
      Crispis
      Gettin’ the black screen as well…
      I’ve gone to the “post that may assist me” but I can’t seem to find anything from it. When looking at the console tab when F12 is pressed, it has stopped after 3 lines at the “Load script: modules/MMM-WunderGround//MMM-WunderGround.js” Opening that file it has the defaults for the api and pws blank. ok.
      Looking at the module coding…
      var config = {
      port: 8080,
      language: 'en',
      timeFormat: 12,
      units: 'imperial',
      		module: 'MMM-WunderGround',
      		position: 'top_right',
      			apikey: 'NUMBERS',
      			pws: 'CO/Denver',
      			hourly: '1',
      			fctext: '1',
      			fcdaycount: "5",
      			fcdaystart: "0",
      			hourlyinterval: "3",
      			hourlycount: "2",
      I can’t seem to find what is wrong. Are you able to spot my error or suggest some help?
        Shockwave @Crispis
        @Crispis I’m not sure, but I think you may not need the comma after the ending curly bracket if you only have 1 item in modules. (3rd line from the bottom) I think that might be why config: { } doesn’t get an ending comma.
        • bthuilotB Offline
          bthuilot
          Everything seems correct in your config. What worked for me was updating the Magic Mirror itself and then it started working. If that doesn’t do it let me know and I could try to see what else I did.
            Crispis
            Did an update with:
            cd ~\MagicMirror
            git pull
            and then removed the “,” … still getting the black screen.
            When I remove THIS particular module from my whole set, the mirror works fine. I’m not sure whats wrong in that section.
              Shockwave @Crispis
              @Crispis Can you post your full config.js please? (if the above is just truncated) I’m wondering if there’s something just before the MMM-Wunderground module that’s causing you grief.
                chrisfoerg
                Are you sure that CO/Denver is correct?
                  Crispis
                  @chrisfoerg I am not sure if CO/Denver is correct. I thought it was the “STATE/CITY” and Denver happens to be very close to me so I went with that initially. It wasn’t working with the “IUTRETCH” or “NY/New_York” inputs either.
                  @Shockwave I already began to…start…I tried to call up the file through 192.XXX/config/config.js but that gives me a file to save, which then I can’t open as it continues to prompt the save file. When I drop it into notepad, its…word wrap made it too difficult to read and the line was not gonna happen. I’ve got… the entire config.js that I guess I could e-mail? I don’t think attaching it to this would be a good move? Better yet…what is the correct method for acquiring/posting the full config.js?
                    Shockwave @Crispis
                    @Crispis
                    CO/Denver should be okay as that’s the same format I’m using for one of my entries which is AZ/Yuma. You could also try an airport identifier such as KDEN for Denver International.
                    As for saving the file, I assume you’re copying and pasting from Putty? Does turning off word wrap make it any better? Could you copy from putty and paste it in here as a code block?
                      Crispis
                      @shockwave When it comes to saving the file, I open up a file and type in the ip address then /config/config.js …I’m not too sure what Putty is… Turning off word wrap just makes the data appear on two lines but for 100 yards. It doesn’t clean things up. Have not tried the KDEN but I’ll give it a go when I’m home!
                        Crispis
                        @Shockwave Here is my current full config.js -minus the API keys. Gives me the black screen for some reason…
                        /* Magic Mirror Config Sample
                        • MIT Licensed.
                        var config = {
                        port: 8080,
                        language: 'en',
                        timeFormat: 12,
                        units: 'imperial',
                        		module: 'alert',
                        		module: 'clock',
                        		position: 'top_left'
                        		module: 'calendar',
                        		header: 'US Holidays',
                        		position: 'top_left',
                        			maximumEntries: '3',
                        					symbol: 'calendar-check-o ',
                        		module: 'compliments',
                        		position: 'bottom_bar',
                        			updateInterval: '1800000',
                        			compliments: {
                        				morning: [
                        					'What a beautiful morning!',
                        					'Enjoy your day!',
                        					'Good Morning!',
                        					'How was your sleep?'
                        				afternoon: [
                        					'Hey good lookin!',
                        					'Looking good today!',
                        					'You\'re doing great!',
                        					'Looking good!'
                        				evening: [
                        					'Wow, you look great!',
                        					'You look nice!'
                        		module: 'currentweather',
                        		header: 'Firestone, CO',
                        			initialLoadDelay: '100',
                        			locationID: '5577008',
                        			appid: '###'
                        		module: 'weatherforecast',
                        		header: 'Weather Forecast',
                        			locationID: '',  //ID from http://www.openweathermap.org
                                    		appid: '###'
                        		header: 'WEATHER TIME',
                        			apikey: '###',
                        			pws: 'KDEN',
                        			lang: 'NL',
                        			fctext: '1',
                        			fcdaycount: '5',
                        		fcdaystart: '0',
                        		hourly: '1',
                        		hourlyinterval: '3',
                        			hourlycount: '2',
                        if (typeof module !== ‘undefined’) {module.exports = config;}
                          Shockwave @Crispis
                          @Crispis Thanks for posting it. I think you’re missing a comma after appid in the weatherforecast and currentweather modules. Being at the end that may not be it, I seem to have instances where they aren’t on the last line either.
                          You said it works without the Wunderground module, correct? Could it be setting the language to Dutch without having Dutch selected in the International Settings within raspi-config? It sure looks okay unless there’s a hidden symbol in there. How are you editing it on the mirror?
                          Here’s mine if you want to try.
                          		header: 'Ankeny Weather',
                          			apikey: 'api key here',
                          			pws: 'KIKV',
                          			hourly: '0',
                          			fcdaycount: '7',
                          			fade: 'false',
                          			fadePoint: '1',
                          			alerttime: 10000,
                          			UseCardinals: 1,
                          			roundTmpDecs: 1,
                            Crispis
                            @Shockwave Copied yours exactly and I’m still gettin’ that black screen of death! I’m editing on the pi/mirror itself with the terminal+keyboard. Tried CO/Denver and NY/New_York… nothing. I’m not too sure… I’ll try to “reinstall everything” from step one and see if that fixes it.
                              Crispis
                              Honestly not too sure what I did… I mean I just re-cloned things in the module folder and now things are working. …So I guess if someone is having problems, simply start over from the beginning and try again?? No…idea… Anyways thanks for your help!
                              • L Offline
                                lsfourwheeler
                                So I just updated both my Raspberry pi, MagicMirror software, and MMM-Wunderground. The module still works but the moon phases icon is now a blank “image missing” box. Strangely, I can see the moon image just fine on a computer by going to the MagicmirroIP:8080 and viewing the magicmirror sofware from there. Any suggestions?
                                • E Offline
                                  eppzenberg @lsfourwheeler
                                  @lsfourwheeler
                                  I’m facing the same problem. Module is working and up-to-date, but moon phase icon is just showing the “image missing” box. Did you find any solution?
                                  • L Offline
                                    lsfourwheeler @eppzenberg
                                    @eppzenberg
                                    Yes, I found out this issue actually happened because of the MagicMirror Update. Make sure that after you run the “git pull” command you also run the “npm install” command. This fixed my issue. I hope that helps.
                                    • E Offline
                                      @lsfourwheeler
                                      Indeed, I missed that step. It works now. :) Thank you very much!
                                      • O Offline
                                        ostfilinchen
                                        @RedNax : you have update the Module and it doesn’t look like the old style. The humidity is permanent shown and between Icon Wind Direction and Humidity is no space. Also between humidity and sunset/sunrise is no space.
                                        Can u please change this?
                                        • O Offline
                                          ostfilinchen
                                          @RedNax: it’s still not fine:0_1485700269786_upload-26f37467-942f-462d-af4a-c3a3e1bca669
                                          Font is not the same as the other modules and there is not a space between winddirection and humidity-icon
                                          And another issue is the size of the current weather Icon. It’s too big:
                                          0_1485700407613_upload-4cec9558-640a-4d7b-9621-35093b3c4d22
                                          Can u have a look of this?
                                          • O Offline
                                            ostfilinchen
                                            Hi all,
                                            has anyone ideas to Change the iconsize of the current weather? It’s to big and to bold for me.
                                            Thx, Daniel
                                            • 6 / 7
