    MMM-NewPIR v3
    67 Posts 18 Posters 39.2k Views 20 Watching
      philmavedzenge
      Hi guys,
      After updating my MagicMirror to the latest version, this modules does not work. I tried reinstalling but its giving an error that i do not understand. Could someone help please? I have attached the logs, not sure if they will help.
      npm WARN notsup Unsupported engine for electron-rebuild@3.2.3: wanted: {“node”:“>=12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
      npm WARN notsup Not compatible with your version of node/npm: electron-rebuild@3.2.3
      npm WARN notsup Unsupported engine for @malept/cross-spawn-promise@2.0.0: wanted: {“node”:“>= 12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
      npm WARN notsup Not compatible with your version of node/npm: @malept/cross-spawn-promise@2.0.0
      npm WARN notsup Unsupported engine for fs-extra@10.0.0: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
      npm WARN notsup Not compatible with your version of node/npm: fs-extra@10.0.0
      npm WARN notsup Unsupported engine for yargs@17.2.1: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
      npm WARN notsup Not compatible with your version of node/npm: yargs@17.2.1
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! @bugsounet/pir@1.0.6 postinstall: electron-rebuild
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the @bugsounet/pir@1.0.6 postinstall script.
        DJBOOB66
        @philmavedzenge said in MMM-NewPIR v3:
        You need to update npm and node
          philmavedzenge @DJBOOB66
          @djboob66 said in MMM-NewPIR v3:
          Thanks for the response. How do I do that? Which folder should I update it in?
          • FoziF Offline
            Fozi Project Sponsor @philmavedzenge
            @philmavedzenge in your home directory execute following two commands:
            sudo npm  install -g n
            sudo n latest
            This installs the latest node version
            Edit: added sudo
              DJBOOB66
              Ok you need to find a working node and npm for all module if you have Bugs Google Aisstant v3 then it is best to check the module first GA v3 needs,
              Node: v12.x.x upto v14.x.x
              npm: = v6.14.15 (some trouble with v7.x)
              I suggest trying.
              Do in this order.
              sudo npm cache clean -f
              sudo n 14.0
              now check npm with npm -v
              If 6.14.15 do nothing more but over 7.x use below
              sudo npm install -g npm@6.14.15
              FoziF P 2 Replies Last reply Reply Quote 0
              • FoziF Offline
                Fozi Project Sponsor @DJBOOB66
                @djboob66 you’re right…I forgot that there might be potential issues with the latest version. Thanks for the correction!
                @philmavedzenge : Generally I’d recommend to use @sdetweil update script when updating to a new MM version. (see here) As you already updated to 2.17.1, use this command with force at he end instead of apply
                bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                Sam‘s script checks, if the correct node and npm versions are installed and updates them accorgingly if necessary.
                  thank you guys very much, this worked for me
                    philmavedzenge @Fozi
                    @fozi i had used that script to update, i don’t know why it didn’t update the other components. Thanks a lot for your help
                      sdetweil @philmavedzenge
                      @philmavedzenge it doesn’t upgrade mode/npm
                      install checks, upgrade does not (usually didn’t need to)
                        philmavedzenge @sdetweil
                        @sdetweil said in MMM-NewPIR v3:
                        I see now. Thanks a lot for the help
                        • uros76U Offline
                          uros76
                          Hi. Does anyone know of a way to format “LastPresence” output? Default is a full date and time in one line however I would like to change the format of the output. Don’t see any config option to format it…
                          • cowboysdudeC Offline
                            cowboysdude Module Developer @uros76
                            @uros76 said in MMM-NewPIR v3:
                            How would you like it formatted?
                            uros76U 1 Reply Last reply Reply Quote 1
                            • uros76U Offline
                              uros76 @cowboysdude
                              @cowboysdude ideally I would like to specify the date/time format, like on a stock MM Clock module.
                              • 4 / 4
