    MMM-NewPIR v3
    67 Posts 18 Posters 40.4k Views 20 Watching
      ChrisDub @MajorC
      @majorc said in MMM-NewPIR v3:
      @chrisdub https://lmgtfy.app/?q=raspberry+pi+activate+gpio :beaming_face_with_smiling_eyes:
      Thank you for your fast answer, ´ve found some articles for activating the GPIOs.
      I´ve followed this tutorial for testing my PIR Sensor: https://www.einplatinencomputer.com/raspberry-pi-pir-bewegungsmelder-ansteuern/
      The author doesn´t mention, that activating the GPIOs is necessary. Now I´m a little bit confused.
      When I´m starting the script, I´m getting the following output. When I´m moving in front of the sensor, nothing happens.
      Just in case it helps, a picture from my setup:
        jordes
        can i add an exception module to not hide, while hiding all others?
        • cowboysdudeC
          What is this module made for…RPI3 or RPI4?
            sdetweil @cowboysdude
            @cowboysdude I don’t understand the question?
            it supports all the different screen dimming approaches
            • cowboysdudeC
              cowboysdude Module Developer @sdetweil
              @sdetweil Thanks Sam.
                philmavedzenge
                Hi guys,
                After updating my MagicMirror to the latest version, this modules does not work. I tried reinstalling but its giving an error that i do not understand. Could someone help please? I have attached the logs, not sure if they will help.
                npm WARN notsup Unsupported engine for electron-rebuild@3.2.3: wanted: {“node”:“>=12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                npm WARN notsup Not compatible with your version of node/npm: electron-rebuild@3.2.3
                npm WARN notsup Unsupported engine for @malept/cross-spawn-promise@2.0.0: wanted: {“node”:“>= 12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                npm WARN notsup Not compatible with your version of node/npm: @malept/cross-spawn-promise@2.0.0
                npm WARN notsup Unsupported engine for fs-extra@10.0.0: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                npm WARN notsup Not compatible with your version of node/npm: fs-extra@10.0.0
                npm WARN notsup Unsupported engine for yargs@17.2.1: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                npm WARN notsup Not compatible with your version of node/npm: yargs@17.2.1
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! @bugsounet/pir@1.0.6 postinstall: electron-rebuild
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the @bugsounet/pir@1.0.6 postinstall script.
                  DJBOOB66
                  @philmavedzenge said in MMM-NewPIR v3:
                  You need to update npm and node
                    philmavedzenge @DJBOOB66
                    @djboob66 said in MMM-NewPIR v3:
                    Thanks for the response. How do I do that? Which folder should I update it in?
                    • FoziF
                      Fozi Project Sponsor @philmavedzenge
                      @philmavedzenge in your home directory execute following two commands:
                      sudo npm  install -g n
                      sudo n latest
                      This installs the latest node version
                      Edit: added sudo
                        DJBOOB66
                        Ok you need to find a working node and npm for all module if you have Bugs Google Aisstant v3 then it is best to check the module first GA v3 needs,
                        Node: v12.x.x upto v14.x.x
                        npm: = v6.14.15 (some trouble with v7.x)
                        I suggest trying.
                        Do in this order.
                        sudo npm cache clean -f
                        sudo n 14.0
                        now check npm with npm -v
                        If 6.14.15 do nothing more but over 7.x use below
                        sudo npm install -g npm@6.14.15
                        FoziF P 2 Replies Last reply Reply Quote 0
                        • FoziF
                          Fozi Project Sponsor @DJBOOB66
                          @djboob66 you’re right…I forgot that there might be potential issues with the latest version. Thanks for the correction!
                          @philmavedzenge : Generally I’d recommend to use @sdetweil update script when updating to a new MM version. (see here) As you already updated to 2.17.1, use this command with force at he end instead of apply
                          bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                          Sam‘s script checks, if the correct node and npm versions are installed and updates them accorgingly if necessary.
                            thank you guys very much, this worked for me
                              philmavedzenge @Fozi
                              @fozi i had used that script to update, i don’t know why it didn’t update the other components. Thanks a lot for your help
                                sdetweil @philmavedzenge
                                @philmavedzenge it doesn’t upgrade mode/npm
                                install checks, upgrade does not (usually didn’t need to)
                                  philmavedzenge @sdetweil
                                  @sdetweil said in MMM-NewPIR v3:
                                  I see now. Thanks a lot for the help
                                  • uros76U
                                    uros76
                                    Hi. Does anyone know of a way to format “LastPresence” output? Default is a full date and time in one line however I would like to change the format of the output. Don’t see any config option to format it…
                                    • cowboysdudeC
                                      cowboysdude Module Developer @uros76
                                      @uros76 said in MMM-NewPIR v3:
                                      How would you like it formatted?
                                      uros76U 1 Reply Last reply Reply Quote 1
                                      • uros76U
                                        uros76 @cowboysdude
                                        @cowboysdude ideally I would like to specify the date/time format, like on a stock MM Clock module.
                                        • 3 / 4
