    MMM-NewPIR v3
    67 Posts 18 Posters 38.7k Views 20 Watching
    • FoziF Offline
      Fozi Project Sponsor
      I had the same. After
      git pull
      Enter
      mom run update
      and reboot.
        bdream
        where to run mom run update?
        I tried in home, MagicMirror, modules and MMM-NewPIR
        got th message
        -bash: mom: Kommando nicht gefunden.
        -bash: mom: Command not found.
        cheers, bdream
          bdream @bdream
          Hast noone an Idea how to get rid of thus Update Message?
          cheers, bdream
          • L Offline
            lolo
            This should work
            cd ~/MagicMirror/modules/MMM-NewPIR
            git pull
            npm run update
            sudo reboot
              bdream @lolo
              @lolo it works!
              Many thanks
              Again this Forum ist so helpful 🥳
              cheers, bdream
                ChrisDub
                Hey there Guys,
                I´m stuck and I need your help.
                My Code:
                			module: 'MMM-NewPIR',
                			position: 'top_left',
                			configDeepMerge: true,
                				debug: false,
                				screen: {
                					delay: 2 * 60 * 1000, // 2 * 60 * 1000 = 2 Minuten
                					turnOffDisplay: true,
                					mode: 1,
                					ecoMode: true,
                					displayCounter: true,
                					text: "Auto Turn Off Screen:",
                					displayBar: true,
                					displayStyle: "SemiCircle",
                					governorSleeping: false,
                					displayLastPresence: true,
                					LastPresenceText: "Last Presence:",
                					useTouch: false,
                					delayed: 0
                				pir: 	{
                					usePir: true,
                					gpio: 21,
                					reverseValue: false
                My HC-SR501 Sensor is wired as following:
                VCC (+5V) > GPIO PIN 2
                OUT > GPIO PIN 21
                GND > GPIO PIN 6
                Problem:
                The timer runs down, the display switches off and then stays black.
                It seems as the movement is not recognized by the PIR.
                I already tried another PIR, same failure.
                Switching to another PIN > 22 with editing the config results with the same “failure”.
                At the moment I don´t know, where the source of my problem is buried and I could use some help from you.
                Thank you in advance
                  MajorC Project Sponsor @ChrisDub
                  @chrisdub have you activated the pins at your Raspberry OS?
                    ChrisDub @MajorC
                    @majorc said in MMM-NewPIR v3:
                    Good morning.
                    To be honest, I don´t really know. Is there a special way to activate the PINS? Maybe via raspi-config?!
                      @chrisdub https://lmgtfy.app/?q=raspberry+pi+activate+gpio :beaming_face_with_smiling_eyes:
                        ChrisDub @MajorC
                        Thank you for your fast answer, ´ve found some articles for activating the GPIOs.
                        I´ve followed this tutorial for testing my PIR Sensor: https://www.einplatinencomputer.com/raspberry-pi-pir-bewegungsmelder-ansteuern/
                        The author doesn´t mention, that activating the GPIOs is necessary. Now I´m a little bit confused.
                        When I´m starting the script, I´m getting the following output. When I´m moving in front of the sensor, nothing happens.
                        Just in case it helps, a picture from my setup:
                          jordes
                          can i add an exception module to not hide, while hiding all others?
                          • cowboysdudeC Offline
                            What is this module made for…RPI3 or RPI4?
                              sdetweil @cowboysdude
                              @cowboysdude I don’t understand the question?
                              it supports all the different screen dimming approaches
                                cowboysdude Module Developer @sdetweil
                                @sdetweil Thanks Sam.
                                  philmavedzenge
                                  Hi guys,
                                  After updating my MagicMirror to the latest version, this modules does not work. I tried reinstalling but its giving an error that i do not understand. Could someone help please? I have attached the logs, not sure if they will help.
                                  npm WARN notsup Unsupported engine for electron-rebuild@3.2.3: wanted: {“node”:“>=12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                  npm WARN notsup Not compatible with your version of node/npm: electron-rebuild@3.2.3
                                  npm WARN notsup Unsupported engine for @malept/cross-spawn-promise@2.0.0: wanted: {“node”:“>= 12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                  npm WARN notsup Not compatible with your version of node/npm: @malept/cross-spawn-promise@2.0.0
                                  npm WARN notsup Unsupported engine for fs-extra@10.0.0: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                  npm WARN notsup Not compatible with your version of node/npm: fs-extra@10.0.0
                                  npm WARN notsup Unsupported engine for yargs@17.2.1: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                  npm WARN notsup Not compatible with your version of node/npm: yargs@17.2.1
                                  npm ERR! code ELIFECYCLE
                                  npm ERR! errno 1
                                  npm ERR! @bugsounet/pir@1.0.6 postinstall: electron-rebuild
                                  npm ERR! Exit status 1
                                  npm ERR!
                                  npm ERR! Failed at the @bugsounet/pir@1.0.6 postinstall script.
                                    DJBOOB66
                                    @philmavedzenge said in MMM-NewPIR v3:
                                    You need to update npm and node
                                      philmavedzenge @DJBOOB66
                                      @djboob66 said in MMM-NewPIR v3:
                                      Thanks for the response. How do I do that? Which folder should I update it in?
                                      • FoziF Offline
                                        Fozi Project Sponsor @philmavedzenge
                                        @philmavedzenge in your home directory execute following two commands:
                                        sudo npm  install -g n
                                        sudo n latest
                                        This installs the latest node version
                                        Edit: added sudo
                                          DJBOOB66
                                          Ok you need to find a working node and npm for all module if you have Bugs Google Aisstant v3 then it is best to check the module first GA v3 needs,
                                          Node: v12.x.x upto v14.x.x
                                          npm: = v6.14.15 (some trouble with v7.x)
                                          I suggest trying.
                                          Do in this order.
                                          sudo npm cache clean -f
                                          sudo n 14.0
                                          now check npm with npm -v
                                          If 6.14.15 do nothing more but over 7.x use below
                                          sudo npm install -g npm@6.14.15
                                          FoziF P 2 Replies Last reply Reply Quote 0
                                          • FoziF Offline
                                            Fozi Project Sponsor @DJBOOB66
                                            @djboob66 you’re right…I forgot that there might be potential issues with the latest version. Thanks for the correction!
                                            @philmavedzenge : Generally I’d recommend to use @sdetweil update script when updating to a new MM version. (see here) As you already updated to 2.17.1, use this command with force at he end instead of apply
                                            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                            Sam‘s script checks, if the correct node and npm versions are installed and updates them accorgingly if necessary.
                                            • 3 / 4
