    MMM-NewPIR v3
    67 Posts 18 Posters 41.1k Views 20 Watching
      bdream
      where to run mom run update?
      I tried in home, MagicMirror, modules and MMM-NewPIR
      got th message
      -bash: mom: Kommando nicht gefunden.
      -bash: mom: Command not found.
      cheers, bdream
      B 1 Reply Last reply
        bdream @bdream
        Hast noone an Idea how to get rid of thus Update Message?
        cheers, bdream
        • L
          lolo
          This should work
          cd ~/MagicMirror/modules/MMM-NewPIR
          git pull
          npm run update
          sudo reboot
            bdream @lolo
            @lolo it works!
            Many thanks
            Again this Forum ist so helpful 🥳
            cheers, bdream
              ChrisDub
              Hey there Guys,
              I´m stuck and I need your help.
              My Code:
              			module: 'MMM-NewPIR',
              			position: 'top_left',
              			configDeepMerge: true,
              				debug: false,
              				screen: {
              					delay: 2 * 60 * 1000, // 2 * 60 * 1000 = 2 Minuten
              					turnOffDisplay: true,
              					mode: 1,
              					ecoMode: true,
              					displayCounter: true,
              					text: "Auto Turn Off Screen:",
              					displayBar: true,
              					displayStyle: "SemiCircle",
              					governorSleeping: false,
              					displayLastPresence: true,
              					LastPresenceText: "Last Presence:",
              					useTouch: false,
              					delayed: 0
              				pir: 	{
              					usePir: true,
              					gpio: 21,
              					reverseValue: false
              My HC-SR501 Sensor is wired as following:
              VCC (+5V) > GPIO PIN 2
              OUT > GPIO PIN 21
              GND > GPIO PIN 6
              Problem:
              The timer runs down, the display switches off and then stays black.
              It seems as the movement is not recognized by the PIR.
              I already tried another PIR, same failure.
              Switching to another PIN > 22 with editing the config results with the same “failure”.
              At the moment I don´t know, where the source of my problem is buried and I could use some help from you.
              Thank you in advance
              M 1 Reply Last reply
                MajorC Project Sponsor @ChrisDub
                @chrisdub have you activated the pins at your Raspberry OS?
                C 1 Reply Last reply
                  ChrisDub @MajorC
                  @majorc said in MMM-NewPIR v3:
                  Good morning.
                  To be honest, I don´t really know. Is there a special way to activate the PINS? Maybe via raspi-config?!
                    @chrisdub https://lmgtfy.app/?q=raspberry+pi+activate+gpio :beaming_face_with_smiling_eyes:
                      ChrisDub @MajorC
                      Thank you for your fast answer, ´ve found some articles for activating the GPIOs.
                      I´ve followed this tutorial for testing my PIR Sensor: https://www.einplatinencomputer.com/raspberry-pi-pir-bewegungsmelder-ansteuern/
                      The author doesn´t mention, that activating the GPIOs is necessary. Now I´m a little bit confused.
                      When I´m starting the script, I´m getting the following output. When I´m moving in front of the sensor, nothing happens.
                      Just in case it helps, a picture from my setup:
                        jordes
                        can i add an exception module to not hide, while hiding all others?
                        • cowboysdudeC
                          What is this module made for…RPI3 or RPI4?
                            sdetweil @cowboysdude
                            @cowboysdude I don’t understand the question?
                            it supports all the different screen dimming approaches
                            • cowboysdudeC
                              cowboysdude Module Developer @sdetweil
                              @sdetweil Thanks Sam.
                                philmavedzenge
                                Hi guys,
                                After updating my MagicMirror to the latest version, this modules does not work. I tried reinstalling but its giving an error that i do not understand. Could someone help please? I have attached the logs, not sure if they will help.
                                npm WARN notsup Unsupported engine for electron-rebuild@3.2.3: wanted: {“node”:“>=12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                npm WARN notsup Not compatible with your version of node/npm: electron-rebuild@3.2.3
                                npm WARN notsup Unsupported engine for @malept/cross-spawn-promise@2.0.0: wanted: {“node”:“>= 12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                npm WARN notsup Not compatible with your version of node/npm: @malept/cross-spawn-promise@2.0.0
                                npm WARN notsup Unsupported engine for fs-extra@10.0.0: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                npm WARN notsup Not compatible with your version of node/npm: fs-extra@10.0.0
                                npm WARN notsup Unsupported engine for yargs@17.2.1: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                npm WARN notsup Not compatible with your version of node/npm: yargs@17.2.1
                                npm ERR! code ELIFECYCLE
                                npm ERR! errno 1
                                npm ERR! @bugsounet/pir@1.0.6 postinstall: electron-rebuild
                                npm ERR! Exit status 1
                                npm ERR!
                                npm ERR! Failed at the @bugsounet/pir@1.0.6 postinstall script.
                                  DJBOOB66
                                  @philmavedzenge said in MMM-NewPIR v3:
                                  You need to update npm and node
                                  P 1 Reply Last reply
                                    philmavedzenge @DJBOOB66
                                    @djboob66 said in MMM-NewPIR v3:
                                    Thanks for the response. How do I do that? Which folder should I update it in?
                                    FoziF 1 Reply Last reply
                                    • FoziF
                                      Fozi Project Sponsor @philmavedzenge
                                      @philmavedzenge in your home directory execute following two commands:
                                      sudo npm  install -g n
                                      sudo n latest
                                      This installs the latest node version
                                      Edit: added sudo
                                        DJBOOB66
                                        Ok you need to find a working node and npm for all module if you have Bugs Google Aisstant v3 then it is best to check the module first GA v3 needs,
                                        Node: v12.x.x upto v14.x.x
                                        npm: = v6.14.15 (some trouble with v7.x)
                                        I suggest trying.
                                        Do in this order.
                                        sudo npm cache clean -f
                                        sudo n 14.0
                                        now check npm with npm -v
                                        If 6.14.15 do nothing more but over 7.x use below
                                        sudo npm install -g npm@6.14.15
                                        FoziF P 2 Replies Last reply
                                        • FoziF
                                          Fozi Project Sponsor @DJBOOB66
                                          @djboob66 you’re right…I forgot that there might be potential issues with the latest version. Thanks for the correction!
                                          @philmavedzenge : Generally I’d recommend to use @sdetweil update script when updating to a new MM version. (see here) As you already updated to 2.17.1, use this command with force at he end instead of apply
                                          bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                          Sam‘s script checks, if the correct node and npm versions are installed and updates them accorgingly if necessary.
                                            thank you guys very much, this worked for me
                                            • 3 / 4
