    MMM-NewPIR v3
    67 Posts 18 Posters 41.1k Views 20 Watching
    • L
      lolo
      Thx. Even one my module have problem with that. For now I will keep it as false.
        bdream
        It’s working :smiling_face_with_open_mouth:
        After a couple of tries with all available PIR Modules it’s working with MMM-NewPIR perfect!
        Many thanks!
        cheers, bdream
          bdream
          …Ohh no.
          Getting update notification for MMM-NewPIR.
          I’m trying in MagicMirror/modules/MMM-NewPIR
          git pull
          but get the message “it’s actual already”
          Notification message still there.
          Any idea please?
          cheers, bdream
          • FoziF
            Fozi Project Sponsor
            I had the same. After
            git pull
            Enter
            mom run update
            and reboot.
              bdream
              where to run mom run update?
              I tried in home, MagicMirror, modules and MMM-NewPIR
              got th message
              -bash: mom: Kommando nicht gefunden.
              -bash: mom: Command not found.
              cheers, bdream
              B 1 Reply Last reply
                bdream @bdream
                Hast noone an Idea how to get rid of thus Update Message?
                cheers, bdream
                • L
                  lolo
                  This should work
                  cd ~/MagicMirror/modules/MMM-NewPIR
                  git pull
                  npm run update
                  sudo reboot
                    bdream @lolo
                    @lolo it works!
                    Many thanks
                    Again this Forum ist so helpful 🥳
                    cheers, bdream
                      ChrisDub
                      Hey there Guys,
                      I´m stuck and I need your help.
                      My Code:
                      			module: 'MMM-NewPIR',
                      			position: 'top_left',
                      			configDeepMerge: true,
                      				debug: false,
                      				screen: {
                      					delay: 2 * 60 * 1000, // 2 * 60 * 1000 = 2 Minuten
                      					turnOffDisplay: true,
                      					mode: 1,
                      					ecoMode: true,
                      					displayCounter: true,
                      					text: "Auto Turn Off Screen:",
                      					displayBar: true,
                      					displayStyle: "SemiCircle",
                      					governorSleeping: false,
                      					displayLastPresence: true,
                      					LastPresenceText: "Last Presence:",
                      					useTouch: false,
                      					delayed: 0
                      				pir: 	{
                      					usePir: true,
                      					gpio: 21,
                      					reverseValue: false
                      My HC-SR501 Sensor is wired as following:
                      VCC (+5V) > GPIO PIN 2
                      OUT > GPIO PIN 21
                      GND > GPIO PIN 6
                      Problem:
                      The timer runs down, the display switches off and then stays black.
                      It seems as the movement is not recognized by the PIR.
                      I already tried another PIR, same failure.
                      Switching to another PIN > 22 with editing the config results with the same “failure”.
                      At the moment I don´t know, where the source of my problem is buried and I could use some help from you.
                      Thank you in advance
                      M 1 Reply Last reply
                        MajorC Project Sponsor @ChrisDub
                        @chrisdub have you activated the pins at your Raspberry OS?
                        C 1 Reply Last reply
                          ChrisDub @MajorC
                          @majorc said in MMM-NewPIR v3:
                          Good morning.
                          To be honest, I don´t really know. Is there a special way to activate the PINS? Maybe via raspi-config?!
                            @chrisdub https://lmgtfy.app/?q=raspberry+pi+activate+gpio :beaming_face_with_smiling_eyes:
                              ChrisDub @MajorC
                              Thank you for your fast answer, ´ve found some articles for activating the GPIOs.
                              I´ve followed this tutorial for testing my PIR Sensor: https://www.einplatinencomputer.com/raspberry-pi-pir-bewegungsmelder-ansteuern/
                              The author doesn´t mention, that activating the GPIOs is necessary. Now I´m a little bit confused.
                              When I´m starting the script, I´m getting the following output. When I´m moving in front of the sensor, nothing happens.
                              Just in case it helps, a picture from my setup:
                                jordes
                                can i add an exception module to not hide, while hiding all others?
                                • cowboysdudeC
                                  What is this module made for…RPI3 or RPI4?
                                    sdetweil @cowboysdude
                                    @cowboysdude I don’t understand the question?
                                    it supports all the different screen dimming approaches
                                    • cowboysdudeC
                                      cowboysdude Module Developer @sdetweil
                                      @sdetweil Thanks Sam.
                                        philmavedzenge
                                        Hi guys,
                                        After updating my MagicMirror to the latest version, this modules does not work. I tried reinstalling but its giving an error that i do not understand. Could someone help please? I have attached the logs, not sure if they will help.
                                        npm WARN notsup Unsupported engine for electron-rebuild@3.2.3: wanted: {“node”:“>=12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                        npm WARN notsup Not compatible with your version of node/npm: electron-rebuild@3.2.3
                                        npm WARN notsup Unsupported engine for @malept/cross-spawn-promise@2.0.0: wanted: {“node”:“>= 12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                        npm WARN notsup Not compatible with your version of node/npm: @malept/cross-spawn-promise@2.0.0
                                        npm WARN notsup Unsupported engine for fs-extra@10.0.0: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                        npm WARN notsup Not compatible with your version of node/npm: fs-extra@10.0.0
                                        npm WARN notsup Unsupported engine for yargs@17.2.1: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                        npm WARN notsup Not compatible with your version of node/npm: yargs@17.2.1
                                        npm ERR! code ELIFECYCLE
                                        npm ERR! errno 1
                                        npm ERR! @bugsounet/pir@1.0.6 postinstall: electron-rebuild
                                        npm ERR! Exit status 1
                                        npm ERR!
                                        npm ERR! Failed at the @bugsounet/pir@1.0.6 postinstall script.
                                          DJBOOB66
                                          @philmavedzenge said in MMM-NewPIR v3:
                                          You need to update npm and node
                                          P 1 Reply Last reply
                                            philmavedzenge @DJBOOB66
                                            @djboob66 said in MMM-NewPIR v3:
                                            Thanks for the response. How do I do that? Which folder should I update it in?
                                            FoziF 1 Reply Last reply
                                            • 3 / 4
