    MMM-NewPIR v3
    67 Posts 18 Posters 41.1k Views 20 Watching
      A Former User @lolo
      @lolo ecoMode Feature hide all modules (disable modules), after maybe your globe module have a bug on disable/resume (this fonction is a function coded in the core of MM)
      • L
        lolo
        Thx. Even one my module have problem with that. For now I will keep it as false.
          bdream
          It’s working :smiling_face_with_open_mouth:
          After a couple of tries with all available PIR Modules it’s working with MMM-NewPIR perfect!
          Many thanks!
          cheers, bdream
            bdream
            …Ohh no.
            Getting update notification for MMM-NewPIR.
            I’m trying in MagicMirror/modules/MMM-NewPIR
            git pull
            but get the message “it’s actual already”
            Notification message still there.
            Any idea please?
            cheers, bdream
            • FoziF
              Fozi Project Sponsor
              I had the same. After
              git pull
              Enter
              mom run update
              and reboot.
                bdream
                where to run mom run update?
                I tried in home, MagicMirror, modules and MMM-NewPIR
                got th message
                -bash: mom: Kommando nicht gefunden.
                -bash: mom: Command not found.
                cheers, bdream
                B 1 Reply Last reply
                  bdream @bdream
                  Hast noone an Idea how to get rid of thus Update Message?
                  cheers, bdream
                  • L
                    lolo
                    This should work
                    cd ~/MagicMirror/modules/MMM-NewPIR
                    git pull
                    npm run update
                    sudo reboot
                      bdream @lolo
                      @lolo it works!
                      Many thanks
                      Again this Forum ist so helpful 🥳
                      cheers, bdream
                        ChrisDub
                        Hey there Guys,
                        I´m stuck and I need your help.
                        My Code:
                        			module: 'MMM-NewPIR',
                        			position: 'top_left',
                        			configDeepMerge: true,
                        				debug: false,
                        				screen: {
                        					delay: 2 * 60 * 1000, // 2 * 60 * 1000 = 2 Minuten
                        					turnOffDisplay: true,
                        					mode: 1,
                        					ecoMode: true,
                        					displayCounter: true,
                        					text: "Auto Turn Off Screen:",
                        					displayBar: true,
                        					displayStyle: "SemiCircle",
                        					governorSleeping: false,
                        					displayLastPresence: true,
                        					LastPresenceText: "Last Presence:",
                        					useTouch: false,
                        					delayed: 0
                        				pir: 	{
                        					usePir: true,
                        					gpio: 21,
                        					reverseValue: false
                        My HC-SR501 Sensor is wired as following:
                        VCC (+5V) > GPIO PIN 2
                        OUT > GPIO PIN 21
                        GND > GPIO PIN 6
                        Problem:
                        The timer runs down, the display switches off and then stays black.
                        It seems as the movement is not recognized by the PIR.
                        I already tried another PIR, same failure.
                        Switching to another PIN > 22 with editing the config results with the same “failure”.
                        At the moment I don´t know, where the source of my problem is buried and I could use some help from you.
                        Thank you in advance
                        M 1 Reply Last reply
                          MajorC Project Sponsor @ChrisDub
                          @chrisdub have you activated the pins at your Raspberry OS?
                          C 1 Reply Last reply
                            ChrisDub @MajorC
                            @majorc said in MMM-NewPIR v3:
                            Good morning.
                            To be honest, I don´t really know. Is there a special way to activate the PINS? Maybe via raspi-config?!
                              @chrisdub https://lmgtfy.app/?q=raspberry+pi+activate+gpio :beaming_face_with_smiling_eyes:
                                ChrisDub @MajorC
                                Thank you for your fast answer, ´ve found some articles for activating the GPIOs.
                                I´ve followed this tutorial for testing my PIR Sensor: https://www.einplatinencomputer.com/raspberry-pi-pir-bewegungsmelder-ansteuern/
                                The author doesn´t mention, that activating the GPIOs is necessary. Now I´m a little bit confused.
                                When I´m starting the script, I´m getting the following output. When I´m moving in front of the sensor, nothing happens.
                                Just in case it helps, a picture from my setup:
                                  jordes
                                  can i add an exception module to not hide, while hiding all others?
                                  • cowboysdudeC
                                    What is this module made for…RPI3 or RPI4?
                                      sdetweil @cowboysdude
                                      @cowboysdude I don’t understand the question?
                                      it supports all the different screen dimming approaches
                                      • cowboysdudeC
                                        cowboysdude Module Developer @sdetweil
                                        @sdetweil Thanks Sam.
                                          philmavedzenge
                                          Hi guys,
                                          After updating my MagicMirror to the latest version, this modules does not work. I tried reinstalling but its giving an error that i do not understand. Could someone help please? I have attached the logs, not sure if they will help.
                                          npm WARN notsup Unsupported engine for electron-rebuild@3.2.3: wanted: {“node”:“>=12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                          npm WARN notsup Not compatible with your version of node/npm: electron-rebuild@3.2.3
                                          npm WARN notsup Unsupported engine for @malept/cross-spawn-promise@2.0.0: wanted: {“node”:“>= 12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                          npm WARN notsup Not compatible with your version of node/npm: @malept/cross-spawn-promise@2.0.0
                                          npm WARN notsup Unsupported engine for fs-extra@10.0.0: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                          npm WARN notsup Not compatible with your version of node/npm: fs-extra@10.0.0
                                          npm WARN notsup Unsupported engine for yargs@17.2.1: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
                                          npm WARN notsup Not compatible with your version of node/npm: yargs@17.2.1
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! errno 1
                                          npm ERR! @bugsounet/pir@1.0.6 postinstall: electron-rebuild
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the @bugsounet/pir@1.0.6 postinstall script.
                                            DJBOOB66
                                            @philmavedzenge said in MMM-NewPIR v3:
                                            You need to update npm and node
                                            P 1 Reply Last reply
                                            • 3 / 4
