    MMM-NewPIR v3
    67 Posts 18 Posters 40.4k Views 20 Watching
      pakal41
      takes PIR sensor HC-SR501 it works on , perso
      I ordered to see a Doppler Microwave Sensor RCWL-0516 to replace HC SR501
      see topic
      https://forum.magicmirror.builders/topic/11704/update-replaced-my-pir-sensor-with-a-doppler-microwave-sensor
      ( more aesthetic )
        A Former User
        v3.1.5 is out!
        added: many mode for touch screen use
        added: delayed activating screen
        see ReadMe File for more informations
        • FoziF
          Fozi Project Sponsor @pakal41
          @pakal41 I can assure you that the Doppler sensor will work 😃
          • L
            lolo @Guest
            @Bugsounet With new version of MagicMirror I decides to try this module.
            Running rpi4 with HC-SR501 sensor.
            Can you please explain me how exactly ecoMode working. I have some problems with that enabled true. I’m still trying to figure out exactly problem but no luck. I’m using MMM-Globe by Eunanibus and its not reloading (not showing ) after monitor is turn on and sometime even monitor doesn’t wont to turn on. Should I just keep this option false? With ecoMode false at the moment everything is working fine.
            Anyway, great work and thank you for your contribution.
              A Former User @lolo
              @lolo ecoMode Feature hide all modules (disable modules), after maybe your globe module have a bug on disable/resume (this fonction is a function coded in the core of MM)
              • L
                lolo
                Thx. Even one my module have problem with that. For now I will keep it as false.
                  bdream
                  It’s working :smiling_face_with_open_mouth:
                  After a couple of tries with all available PIR Modules it’s working with MMM-NewPIR perfect!
                  Many thanks!
                  cheers, bdream
                    bdream
                    …Ohh no.
                    Getting update notification for MMM-NewPIR.
                    I’m trying in MagicMirror/modules/MMM-NewPIR
                    git pull
                    but get the message “it’s actual already”
                    Notification message still there.
                    Any idea please?
                    cheers, bdream
                    • FoziF
                      I had the same. After
                      git pull
                      Enter
                      mom run update
                      and reboot.
                        bdream
                        where to run mom run update?
                        I tried in home, MagicMirror, modules and MMM-NewPIR
                        got th message
                        -bash: mom: Kommando nicht gefunden.
                        -bash: mom: Command not found.
                        cheers, bdream
                          bdream @bdream
                          Hast noone an Idea how to get rid of thus Update Message?
                          cheers, bdream
                          • L
                            lolo
                            This should work
                            cd ~/MagicMirror/modules/MMM-NewPIR
                            git pull
                            npm run update
                            sudo reboot
                              bdream @lolo
                              @lolo it works!
                              Many thanks
                              Again this Forum ist so helpful 🥳
                              cheers, bdream
                                ChrisDub
                                Hey there Guys,
                                I´m stuck and I need your help.
                                My Code:
                                			module: 'MMM-NewPIR',
                                			position: 'top_left',
                                			configDeepMerge: true,
                                				debug: false,
                                				screen: {
                                					delay: 2 * 60 * 1000, // 2 * 60 * 1000 = 2 Minuten
                                					turnOffDisplay: true,
                                					mode: 1,
                                					ecoMode: true,
                                					displayCounter: true,
                                					text: "Auto Turn Off Screen:",
                                					displayBar: true,
                                					displayStyle: "SemiCircle",
                                					governorSleeping: false,
                                					displayLastPresence: true,
                                					LastPresenceText: "Last Presence:",
                                					useTouch: false,
                                					delayed: 0
                                				pir: 	{
                                					usePir: true,
                                					gpio: 21,
                                					reverseValue: false
                                My HC-SR501 Sensor is wired as following:
                                VCC (+5V) > GPIO PIN 2
                                OUT > GPIO PIN 21
                                GND > GPIO PIN 6
                                Problem:
                                The timer runs down, the display switches off and then stays black.
                                It seems as the movement is not recognized by the PIR.
                                I already tried another PIR, same failure.
                                Switching to another PIN > 22 with editing the config results with the same “failure”.
                                At the moment I don´t know, where the source of my problem is buried and I could use some help from you.
                                Thank you in advance
                                  MajorC Project Sponsor @ChrisDub
                                  @chrisdub have you activated the pins at your Raspberry OS?
                                    ChrisDub @MajorC
                                    @majorc said in MMM-NewPIR v3:
                                    Good morning.
                                    To be honest, I don´t really know. Is there a special way to activate the PINS? Maybe via raspi-config?!
                                      @chrisdub https://lmgtfy.app/?q=raspberry+pi+activate+gpio :beaming_face_with_smiling_eyes:
                                        ChrisDub @MajorC
                                        Thank you for your fast answer, ´ve found some articles for activating the GPIOs.
                                        I´ve followed this tutorial for testing my PIR Sensor: https://www.einplatinencomputer.com/raspberry-pi-pir-bewegungsmelder-ansteuern/
                                        The author doesn´t mention, that activating the GPIOs is necessary. Now I´m a little bit confused.
                                        When I´m starting the script, I´m getting the following output. When I´m moving in front of the sensor, nothing happens.
                                        Just in case it helps, a picture from my setup:
                                          jordes
                                          can i add an exception module to not hide, while hiding all others?
                                          • cowboysdudeC
                                            What is this module made for…RPI3 or RPI4?
                                            • 3 / 4
