    MMM-NewPIR v3
    67 Posts 18 Posters 41.1k Views 20 Watching
    • cowboysdudeC
      cowboysdude Module Developer @sdetweil
      @sdetweil Thanks Sam.
        philmavedzenge
        Hi guys,
        After updating my MagicMirror to the latest version, this modules does not work. I tried reinstalling but its giving an error that i do not understand. Could someone help please? I have attached the logs, not sure if they will help.
        npm WARN notsup Unsupported engine for electron-rebuild@3.2.3: wanted: {“node”:“>=12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
        npm WARN notsup Not compatible with your version of node/npm: electron-rebuild@3.2.3
        npm WARN notsup Unsupported engine for @malept/cross-spawn-promise@2.0.0: wanted: {“node”:“>= 12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
        npm WARN notsup Not compatible with your version of node/npm: @malept/cross-spawn-promise@2.0.0
        npm WARN notsup Unsupported engine for fs-extra@10.0.0: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
        npm WARN notsup Not compatible with your version of node/npm: fs-extra@10.0.0
        npm WARN notsup Unsupported engine for yargs@17.2.1: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
        npm WARN notsup Not compatible with your version of node/npm: yargs@17.2.1
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! @bugsounet/pir@1.0.6 postinstall: electron-rebuild
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the @bugsounet/pir@1.0.6 postinstall script.
          DJBOOB66
          @philmavedzenge said in MMM-NewPIR v3:
          You need to update npm and node
          P 1 Reply Last reply
            philmavedzenge @DJBOOB66
            @djboob66 said in MMM-NewPIR v3:
            Thanks for the response. How do I do that? Which folder should I update it in?
            FoziF 1 Reply Last reply
            • FoziF
              Fozi Project Sponsor @philmavedzenge
              @philmavedzenge in your home directory execute following two commands:
              sudo npm  install -g n
              sudo n latest
              This installs the latest node version
              Edit: added sudo
                DJBOOB66
                Ok you need to find a working node and npm for all module if you have Bugs Google Aisstant v3 then it is best to check the module first GA v3 needs,
                Node: v12.x.x upto v14.x.x
                npm: = v6.14.15 (some trouble with v7.x)
                I suggest trying.
                Do in this order.
                sudo npm cache clean -f
                sudo n 14.0
                now check npm with npm -v
                If 6.14.15 do nothing more but over 7.x use below
                sudo npm install -g npm@6.14.15
                FoziF P 2 Replies Last reply
                • FoziF
                  Fozi Project Sponsor @DJBOOB66
                  @djboob66 you’re right…I forgot that there might be potential issues with the latest version. Thanks for the correction!
                  @philmavedzenge : Generally I’d recommend to use @sdetweil update script when updating to a new MM version. (see here) As you already updated to 2.17.1, use this command with force at he end instead of apply
                  bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                  Sam‘s script checks, if the correct node and npm versions are installed and updates them accorgingly if necessary.
                    thank you guys very much, this worked for me
                      philmavedzenge @Fozi
                      @fozi i had used that script to update, i don’t know why it didn’t update the other components. Thanks a lot for your help
                        sdetweil @philmavedzenge
                        @philmavedzenge it doesn’t upgrade mode/npm
                        install checks, upgrade does not (usually didn’t need to)
                          philmavedzenge @sdetweil
                          @sdetweil said in MMM-NewPIR v3:
                          I see now. Thanks a lot for the help
                          • uros76U
                            uros76
                            Hi. Does anyone know of a way to format “LastPresence” output? Default is a full date and time in one line however I would like to change the format of the output. Don’t see any config option to format it…
                            • cowboysdudeC
                              cowboysdude Module Developer @uros76
                              @uros76 said in MMM-NewPIR v3:
                              How would you like it formatted?
                              uros76U 1 Reply Last reply
                              • uros76U
                                uros76 @cowboysdude
                                @cowboysdude ideally I would like to specify the date/time format, like on a stock MM Clock module.
                                • 4 / 4
