    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
    • BKeyportB
      BKeyport Module Developer @debaetstony
      @debaetstony
      Use daily view. Eliminates the space almost completely. Also, if I remember right, if you change the order of views in the config.js, you may be able to get month view on top of daily view, but I’m not sure about that. Sean wasn’t too clear in order of building the modules.
      something else you might be interested in. If you’d like empty days to disappear in daily view:
      In your config.js, under views, add the following className: "remove_empty_slot",
      For example:
      views: [
      		mode: "daily",
      		slotCount: 14,
      		timeFormat:"LT",
      		hideOverflow: false,
      		filterPassedEvent: true,
      Then in custom.css add:
      .CX2 .remove_empty_slot .eventCount_0 {
        display:none;
        pkup10
        Re: MMM-CalendarExt2
        I am new here and am trying to get the calendar extension to work. I set it up with the basic configuation but I am getting a blank screen in Magic Mirror. Any help would be appreciated.
        module: ‘MMM-CalendarExt2’,
        calendars : [
        url: “https://www.google.com/calendar/ical/ovb564thnod82u5c4njut98728%40group.calendar.google.com/public/basic.ics”,
        views: [
        mode: “daily”,
        scenes: [
        BKeyportB 1 Reply Last reply
        • BKeyportB
          BKeyport Module Developer @pkup10
          @pkup10 way underconfigured. Compare to mine, stripped down to it’s bare minimum.
          			module: "MMM-CalendarExt2", // https://github.com/MMM-CalendarExt2/MMM-CalendarExt2
          				calendars : [
          						url: "<URL>",
          						name: "Main Calendar",
          				views: [
          						mode: "daily",
          						calendars: ["Main Calendar"],
          				scenes: [
          W 1 Reply Last reply
          • W
            Wenike @BKeyport
            @bkeyport actually, that might be @pkup10 's problem: he didn’t put a position item in his config. MM won’t display it without knowing where to display it.
            S BKeyportB 2 Replies Last reply
              sdetweil @Wenike
              @wenike that module doesn’t use the typical display approach. position is not used
              • BKeyportB
                BKeyport Module Developer @Wenike
                @wenike Take a look at my barebones config above. You’ll notice the position is part of the view config not the main part. This module creates virtual positions after the main stuff is done.
                • A
                  Askedal
                  is there a way to setup a sliding week (sliding 7 days) in the calendar, means always show the actual day as the first day and then e.g. 7 days into the future ?
                  Currently I’m showing two weeks, but on Sundays the first week shows only gone events and is not very helpful. I rather would like to save the space for the first week by just showing only 7 days in the future. Unfortunately I was not able to figure this out by myself :crying_face: .
                  Many thanks for the great addon
                  Clas
                  M 2 Replies Last reply
                    MMRIZE @Askedal
                    @askedal
                    Weeks views purpose is that. Use Daily view with horizontal layout.
                    A 1 Reply Last reply
                      MMRIZE @Askedal
                      @askedal
                      And the start day of week respects your locale. So in your country, if the week starts from Monday, adjust your locale to it.
                      • A
                        Askedal @MMRIZE
                        @mmrize said in MMM-CalendarExt2:
                        @askedal
                        I tried the daily view, but then saturday and sunday were missing, it showed only the working days (maybe there were no events ?)
                          MMRIZE @Askedal
                          @askedal
                          I think you are missing some options;
                          They might be slotCount and fromNow.
                          slotCount in daily view points How many days will appear
                          fromNow in daily view points From which day the view begins.
                          So if you set daily view like this;
                          fromNow: -1,
                          slotCount: 5
                          It will show 5 days schedules from yesterday.
                          I think you probably want 7 days schedule from today. In that case, this will work; (You may need more options and CSS modifying to beautify the look of view)
                            mode: "daily",
                            title: "My Schedule",
                            position: "bottom_bar",
                            type: "row",
                            slotCount: 7,
                            fromNow: 0,
                            useEventTimeRelative: true,
                          • General View options: https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/master/docs/Configuration/View.md
                          • Daily View options : https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/master/docs/Configuration/Views/daily.md
                            MMRIZE @Askedal
                            @askedal
                            Anyway, I need to point this; The MMM-CalendarExt2 is going to die because of its unusual complexity to use and heavy dependencies of obsoleted legacy node modules. I already have archived it. I wish I can release Ext3 in near future to solve those problems.
                            A BKeyportB F 3 Replies Last reply
                            • A
                              Askedal @MMRIZE
                              Many thanks, it is mostly working. I have now set it like this and it is showing the next 7 days correctly.
                                          mode: "daily",
                                          useEventTimeRelative: false,
                                          fromNow: 0,
                                          slotCount: 7,
                                          type: "row",
                                          calendars: [],
                                          dateFormat: "dd",
                                          slotTitleFormat: {
                                              sameDay: "dd",
                                              nextDay: "dd",
                                              nextWeek: "dd",
                                              sameElse: "",
                              But there is a lot of free space between the days, can I somehow move the days closer together so that they look more like a table and not like 7 single days ?
                              Many thanks for your help
                              • BKeyportB
                                BKeyport Module Developer @MMRIZE
                                @mmrize I do believe that there are some working within the code to try and figure out Sean’s work. It’s a shame he stepped back though, but I get it. even with my minor modules I’m suffering a bit of burnout and frustration for a free product.
                                  sdetweil @BKeyport
                                  @bkeyport @MMRIZE IS Sean!!
                                  • G
                                    ge
                                    Will a touch screen work with MMM-CalendarExt2? For example have the current month displayed, and then be able to scroll to the next month, or months ahead like a phone calendar.
                                    • F
                                      flemmingss @MMRIZE
                                      @mmrize Is there a plan for MMM-CalendarExt3 in the near future? :alien:
                                      if so, when can it be expected?
                                      M 1 Reply Last reply
                                        sdetweil @ge
                                        @ge I do not think the module provides any clickable elements
                                        typically the MM is a passive output only device, w no keyboard or mouse
                                        none of my modules provide clickable elements
                                          MMRIZE @flemmingss
                                          @flemmingss
                                          I’m trying to build a new X3 from the scratch, which will respect default MM’s behaviours, will be independent of legacy/external momentJs or other 3rd parties, will be more modular and lighter than X2 and with a few new features.
                                          But it needs more days or weeks to release. I wish I have more dedicated time to that work. Sorry.
                                          Reply Quote 2
                                          • A
                                            almightyyoshi
                                            How can I add an image to the background of a specific slot, such as a pumpkin to October 31 or a Christmas tree to December 25. I was thinking of .slotcontent, but not sure how to filter that. Also, how would it be done for things like Hannukah, where there aren’t set days. I was also thinking of using dayofyear, but leap years would mess with that, and still wouldn’t solve Hannukah or any other shifting holidays.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 21 / 25
