    [ERROR] Moment Timezone has no data for Customized Time Zone
    moment timezone calendar
    8 Posts 2 Posters 2.4k Views 2 Watching
    • K Offline
      Klassieker
      Hello all,
      I just upgraded to version 2.17.1 and see this error. It is in the deault app Calendar.
      What can I change to stop this error?
      Thanks in advance.
        sdetweil @Klassieker
        @klassieker 2.15 and above have special code to work around that problem… (I know , I added it) but this is for MS 365 cals.
        can u show me a cal entry from the ics file (use the url to download the file, and then u can edit it, as it is just text)
        a cal event starts with BEGIN:VEVENT
        and ends with END:VEVENT
        • K Offline
          Klassieker @sdetweil
          Hi Sam, I use a special agenda from office 365 for the calender module
          Here is the information. Maybe I can change something in this agenda instead of the special code as work around?
          BEGIN:VEVENT
          UID: ....
          SUMMARY:Verpakkingen
          DTSTART;TZID=Customized Time Zone:20210107T080000
          DTEND;TZID=Customized Time Zone:20210107T090000
          CLASS:PUBLIC
          PRIORITY:5
          DTSTAMP:20211030T090840Z
          TRANSP:OPAQUE
          STATUS:CONFIRMED
          SEQUENCE:0
          X-MICROSOFT-CDO-APPT-SEQUENCE:0
          X-MICROSOFT-CDO-BUSYSTATUS:BUSY
          X-MICROSOFT-CDO-INTENDEDSTATUS:BUSY
          X-MICROSOFT-CDO-ALLDAYEVENT:FALSE
          X-MICROSOFT-CDO-IMPORTANCE:1
          X-MICROSOFT-CDO-INSTTYPE:0
          X-MICROSOFT-DONOTFORWARDMEETING:FALSE
          X-MICROSOFT-DISALLOW-COUNTER:FALSE
          END:VEVENT
          Thanks in advance
          • K Offline
            Klassieker @Klassieker
            @klassieker
            Current timezone in the agenda.
              @klassieker ok, its just noise, doesn’t hurt anything…
              BUT if u want to test getting rid of the message do this
              edit ~/MagicMirror/modules/default/calendar/calendarutils.js
              	if (event.start.tz.includes(" ")) {  // this is line 37 , not changed
              	        let tz = null                // first replacement line
              		// if the tz is the MS customized TZ
              		if(event.start.tz ==='Customized Time Zone')
              			// use the locally set tz
              			tz=moment.tz.guess()
              		else
              			// use the lookup table to get the IANA name as moment and date don't know MS timezones
              			tz = CalendarUtils.getIanaTZFromMS(event.start.tz);  // last replacement line
              			Log.debug("corrected TZ=" + tz);      // line not to be changed
              replace the lines BETWEEN line 37 and the last line (also not changed)
              with first replacement line thru last replacement line
              so it looks like that
              • K Offline
                Hi Sam,
                I changed the rows and it works, no more noise.
                But what if the module is updated bu the developer?
                Thank you very much,
                  @klassieker you were testing… I will submit a change request … next release is January 1.
                  • K Offline
                    @sdetweil Thanks, I will close this topic as solved
                    • spitzlbergerjS spitzlbergerj referenced this topic on
                    • T thger1312 referenced this topic on
