    Moment Timezone / Invalid time value
    18 Posts 4 Posters 6.4k Views 4 Watching
    • T
      thger1312
      Suddenly after several months of a successful usage of my outlook calendar and the calendar-module a bug. Maybe somebody knows a suitable solution?
      also adding some lines of code didn’t fix the issue https://forum.magicmirror.builders/topic/15803/error-moment-timezone-has-no-data-for-customized-time-zone/6?_=1651432649589&lang=de
        sdetweil @thger1312
        @thger1312 see this
        https://forum.magicmirror.builders/topic/16617/error-moment-timezone-has-no-data-for-customized-time-zone/2?_=1650986841061
        if you turn on debug
        add , “DEBUG”
        to the config.js so that it looks like this
        	logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
        then if using pm2,
        pm2 stop all
        npm start  >somefile.txt 2>&1
        run til the cal should appear
        ctrl-c on the npm start window
        then edit the somefile.txt and search for error ,
        RangeError
        you should find the troubling cal event…
        the timezone should be America/New York , instead of EST5EDT
        (or whatever your timezone is, from the IANA timezone database https://www.iana.org/time-zones
        neither MM nor the library, nor any of the javascript libraries used to parse the ICS file contents uses the timezone definitions inside the ICS file.
        MM DID change the luxon library in this release which is used on the specific call that fails with that error
        last person I helped, their cal event looked like this
        BEGIN:VEVENT
        DTSTART;TZID=EST5EDT:20220118T080000     <------ these two lines are the trouble
        DTEND;TZID=EST5EDT:20220118T090000   <------
        RRULE:FREQ=MONTHLY;WKST=SU;INTERVAL=1;BYMONTHDAY=18
        DTSTAMP:20220425T012218Z
        • T
          thger1312
          thanks, I found the wrong calendar entry!
          I have inserted a recurring event that seems to have been converted by Outlook as a wrong Customized Time Zone…
          • T
            thger1312
            S spitzlbergerjS 2 Replies Last reply Reply Quote 0
              sdetweil @thger1312
              @thger1312 can u fix that in outlook?
              is it your local TZ?
              • spitzlbergerjS
                spitzlbergerj Project Sponsor Module Developer @thger1312
                I have now also received this error message. Unfortunately, my mirror is “deeply” integrated so that I cannot connect a keyboard and mouse. So I cannot easily create the log file as described above without removing the mirror from the wall.
                Is it possible to recognise the wrong time zone from the data excerpt you posted here?
                @thger1312 said in Moment Timezone / Invalid time value:
                I couldn’t find anything suspicious at the moment. What have I overlooked?
                Thank you
                Sepp
                Regards
                Josef
                http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
                  sdetweil @spitzlbergerj
                  @spitzlbergerj you of course enabled SSH on the pi, right??
                  so you can do this from the ssh session
                  you can also download the ics on your PC to examine, search for TZID
                  is the TZID for you local tz?? I may be able to create a fix for this
                  but I don’t want to drag in looking up the broken TZID… already do this for all the MS created non-standard
                  junk.
                  spitzlbergerjS 1 Reply Last reply Reply Quote 0
                  • spitzlbergerjS
                    spitzlbergerj Project Sponsor Module Developer @sdetweil
                    @sdetweil yes, of course I did. I work exclusively via ssh. But the command above seems to try to open a window. Unfortunately, this then breaks off with
                    /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
                    i found these tzid
                    "tzid":"W. Europe Standard Time"
                    "tzid":"undefined"
                    "tzid":"Customized Time Zone"
                    The first one is my time zone.
                    I try to identify the outlook calender entries, so that i can probably fix this there. I’m just wondering why this suddenly occurs. So it must be a newly added appointment that is causing the problem. I just can’t remember which appointments I have recently added :worried_face:
                    Regards
                    Josef
                    spitzlbergerjS S 2 Replies Last reply Reply Quote 0
                    • spitzlbergerjS
                      spitzlbergerj Project Sponsor Module Developer @spitzlbergerj
                      … solved for me now …
                      I have just deleted one of my oldest serial appointments. It had one of the above tzid (unfortunately I don’t know which one) and the error messages have disappeared …
                      Regards
                      Josef
                        @spitzlbergerj if u looked at the error messages, the UUID is a unique value, set in the ICS file… so you canget that and search for it…
                        my question is
                        do you think the ‘bad’ timezone was YOUR timezone?
                        I could create a fix to do the if undefined, set it to local system tz…
                        i think the latest luxon library barfs now , where it used to return something…
                        • T
                          thger1312 @sdetweil
                          @sdetweil I just use Putty to connect via ssh. It won’t open a new window. You can check on your mirror or in browser, whether the mirror is loading the modules. When the error message appeared, I canceled the script via crtl + c. Then you have to search a bit in your logfile e.g.
                          cat /pathtoyourfile/somefile.txt
                          in order to figure out where the wrong appointments are. In my case it was more or less easy because the RangeError and the null-values in the array were very noisy.
                          • T
                            thger1312
                            @sdetweil sorry for the wrong reply, it refers to @spitzlbergerj …
                            My local TZ seems to be right, but it don’t know, why there are these null values in the array. I subscribed my outlook calendar in another google calendar and it worked. These appointments are also rightly displayed in my iPhone, just by subcribing the outlook cal.
                            • spitzlbergerjS
                              @sdetweil I am sorry, I don’t know anymore what the bad tz was.i believe it was undefined, but I don’t know… Sorry
                              Regards
                              Josef
                                sdetweil @thger1312
                                the luxon library (which handles repeating events) had a problem and returned trash(all nulls)
                                doesn’t matter what other cal systems do… ours is hand written by volunteers over many years…
                                I spent a year getting it to handle timezone and std/dst time shifts…
                                and then added on the MS crasy special TZ…(custom tz… what do you need THAT for)
                                here is another crappy bug that every system has to handle…
                                • T
                                  thger1312 @sdetweil
                                  @sdetweil ok, sounds nasty… I recognized in my debug-logfile that those custom time zones were converted correctly. Just the null values were the problem. Fixed for me now…
                                    sdetweil @thger1312
                                    @thger1312 what did u do to fix it? so that we might help others
                                    • T
                                      thger1312 @sdetweil
                                      @sdetweil I deleted the bad event in outlook and added a new google calendar with that occurrence series in order to subscribe it againg with my outlook cal…
                                        sdetweil @thger1312
                                        @thger1312 ok moved event from Outlook to Google cal.
                                        then used multiple cal entries to merge the results together
