    Moment Timezone / Invalid time value
    18 Posts 4 Posters 6.2k Views 4 Watching
    • spitzlbergerjS Offline
      spitzlbergerj Project Sponsor Module Developer @thger1312
      I have now also received this error message. Unfortunately, my mirror is “deeply” integrated so that I cannot connect a keyboard and mouse. So I cannot easily create the log file as described above without removing the mirror from the wall.
      Is it possible to recognise the wrong time zone from the data excerpt you posted here?
      @thger1312 said in Moment Timezone / Invalid time value:
      I couldn’t find anything suspicious at the moment. What have I overlooked?
      Thank you
      Sepp
      Regards
      Josef
      http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
        sdetweil @spitzlbergerj
        @spitzlbergerj you of course enabled SSH on the pi, right??
        so you can do this from the ssh session
        you can also download the ics on your PC to examine, search for TZID
        is the TZID for you local tz?? I may be able to create a fix for this
        but I don’t want to drag in looking up the broken TZID… already do this for all the MS created non-standard
        junk.
        spitzlbergerjS 1 Reply Last reply Reply Quote 0
          spitzlbergerj Project Sponsor Module Developer @sdetweil
          @sdetweil yes, of course I did. I work exclusively via ssh. But the command above seems to try to open a window. Unfortunately, this then breaks off with
          /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
          i found these tzid
          "tzid":"W. Europe Standard Time"
          "tzid":"undefined"
          "tzid":"Customized Time Zone"
          The first one is my time zone.
          I try to identify the outlook calender entries, so that i can probably fix this there. I’m just wondering why this suddenly occurs. So it must be a newly added appointment that is causing the problem. I just can’t remember which appointments I have recently added :worried_face:
          Regards
          Josef
          spitzlbergerjS S 2 Replies Last reply Reply Quote 0
            spitzlbergerj Project Sponsor Module Developer @spitzlbergerj
            … solved for me now …
            I have just deleted one of my oldest serial appointments. It had one of the above tzid (unfortunately I don’t know which one) and the error messages have disappeared …
            Regards
            Josef
              @spitzlbergerj if u looked at the error messages, the UUID is a unique value, set in the ICS file… so you canget that and search for it…
              my question is
              do you think the ‘bad’ timezone was YOUR timezone?
              I could create a fix to do the if undefined, set it to local system tz…
              i think the latest luxon library barfs now , where it used to return something…
              • T Offline
                thger1312 @sdetweil
                @sdetweil I just use Putty to connect via ssh. It won’t open a new window. You can check on your mirror or in browser, whether the mirror is loading the modules. When the error message appeared, I canceled the script via crtl + c. Then you have to search a bit in your logfile e.g.
                cat /pathtoyourfile/somefile.txt
                in order to figure out where the wrong appointments are. In my case it was more or less easy because the RangeError and the null-values in the array were very noisy.
                • T Offline
                  thger1312
                  @sdetweil sorry for the wrong reply, it refers to @spitzlbergerj …
                  My local TZ seems to be right, but it don’t know, why there are these null values in the array. I subscribed my outlook calendar in another google calendar and it worked. These appointments are also rightly displayed in my iPhone, just by subcribing the outlook cal.
                    @sdetweil I am sorry, I don’t know anymore what the bad tz was.i believe it was undefined, but I don’t know… Sorry
                    Regards
                    Josef
                      sdetweil @thger1312
                      the luxon library (which handles repeating events) had a problem and returned trash(all nulls)
                      doesn’t matter what other cal systems do… ours is hand written by volunteers over many years…
                      I spent a year getting it to handle timezone and std/dst time shifts…
                      and then added on the MS crasy special TZ…(custom tz… what do you need THAT for)
                      here is another crappy bug that every system has to handle…
                      • T Offline
                        thger1312 @sdetweil
                        @sdetweil ok, sounds nasty… I recognized in my debug-logfile that those custom time zones were converted correctly. Just the null values were the problem. Fixed for me now…
                          sdetweil @thger1312
                          @thger1312 what did u do to fix it? so that we might help others
                          • T Offline
                            thger1312 @sdetweil
                            @sdetweil I deleted the bad event in outlook and added a new google calendar with that occurrence series in order to subscribe it againg with my outlook cal…
                              sdetweil @thger1312
                              @thger1312 ok moved event from Outlook to Google cal.
                              then used multiple cal entries to merge the results together
