    [ERROR] Moment Timezone has no data for Customized Time Zone
    moment timezone calendar
    8 Posts 2 Posters 2.4k Views 2 Watching
    • K Offline
      Klassieker @Klassieker
      @klassieker
      Current timezone in the agenda.
        sdetweil @Klassieker
        @klassieker ok, its just noise, doesn’t hurt anything…
        BUT if u want to test getting rid of the message do this
        edit ~/MagicMirror/modules/default/calendar/calendarutils.js
        	if (event.start.tz.includes(" ")) {  // this is line 37 , not changed
        	        let tz = null                // first replacement line
        		// if the tz is the MS customized TZ
        		if(event.start.tz ==='Customized Time Zone')
        			// use the locally set tz
        			tz=moment.tz.guess()
        		else
        			// use the lookup table to get the IANA name as moment and date don't know MS timezones
        			tz = CalendarUtils.getIanaTZFromMS(event.start.tz);  // last replacement line
        			Log.debug("corrected TZ=" + tz);      // line not to be changed
        replace the lines BETWEEN line 37 and the last line (also not changed)
        with first replacement line thru last replacement line
        so it looks like that
        • K Offline
          Klassieker @sdetweil
          Hi Sam,
          I changed the rows and it works, no more noise.
          But what if the module is updated bu the developer?
          Thank you very much,
            @klassieker you were testing… I will submit a change request … next release is January 1.
            • K Offline
              @sdetweil Thanks, I will close this topic as solved
              • spitzlbergerjS spitzlbergerj referenced this topic on
              • T thger1312 referenced this topic on
