    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 480.4k Views 31 Watching
    • uros76U
      uros76 @sdetweil
      @sdetweil it works! Mega quick assistance. Tnx
      • F
        Fonzi03
        i too am getting the blank homescreen which only shows
        “configure magic mirror and modules”
        it wont let me upload the jsconfig or default config here how can i send them?
          sdetweil @Fonzi03
          @fonzi03 send to my same userid at gmail. have to rename them to .txt instead of .js to attach to email
            sdetweil @Fonzi03
            @fonzi03 i sent email back
              Dinschal
              I’m not able to pull your module from github. I got this error.
              Greetings
                sdetweil @Dinschal
                @dinschal hm… I don’t see that
                rename the module folder and and git clone again
                then delete the old folder
                  Dinschal
                  There is no module folder…
                  Okay everything fine… i have to go to bed :D my fault sry :D
                  Change pull to clone and it works ;) too much code today.
                  I’m really sorry :(
                    sdetweil @Dinschal
                    @dinschal huh?
                    ah, I see… to get the 1ST copy you use
                    git clone
                    to UPDATE later you do
                    git pull
                    with no extra parms…
                    see the two topics in my signature… I didn’t write em, but they are helpful
                      Dinschal @sdetweil
                      @sdetweil thanks a lot… sometimes this is the best time to go to bed :D
                      my brain isnt working much longer today :D
                        sdetweil @Dinschal
                        @dinschal I’ve been there… get some rest
                          Dinschal @sdetweil
                          first of all… my english is very bad :D
                          today my goal is that your module is working… i have configure it cause i have the mm with localhost and use bitvise for ssh.
                          So i have to change the localhost in my config :D
                          I tired to read the error message but its to tiny :D the only thing i can read is localhost :D
                            sdetweil @Dinschal
                            @dinschal said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                            I tired to read the error message but its to tiny the only thing i can read is localhost
                            what error message?
                            u mean the module output when address:“localhost” is set??
                            localhost means ONLY apps running inside the SAME system can access
                            so a phone (use the qr code) , or another computer (use the url) cannot…
                              Dinschal @sdetweil
                              @sdetweil yeah this one ;) i want to change it cause the mirror is a gift for my parents and if i had to change something i only have my phone.
                              I changed it to 0.0.0.0 so i get the qr but know my device is not allowed to access my mirror :D
                                sdetweil @Dinschal
                                @dinschal also have to edit the ipWhitelist.
                                I set it to []
                                ipWhitelist:[],
                                  Dinschal @sdetweil
                                  @sdetweil i did it let me check ;)
                                  okay i got it… but now i only have the "configuration window without the possibility to configure,
                                  i tryed it with a new pull and an new installation of your module :(
                                  • A
                                    Alyx
                                    amazing work!!! are users able to make module communicate with each other? Such as using voice commands to use another module via notifications?
                                      sdetweil @Alyx
                                      @alyx I don’t understand your question
                                        sdetweil @Dinschal
                                        @dinschal is this from the qr?
                                        or did u enter a url?
                                        note the url is
                                        http://mmipaddr:mmport/modules/MMM-Config/review
                                          sdetweil @Alyx
                                          @alyx voiceCommander is built on top of MMM-Voice and Hello-Lucy
                                          so, CAN you, certainly… take a voice audio -> recognizer -> send notification to other modules…
                                          HOW depends on the module being used…
                                          sometimes there is some config
                                          sometimes there is file editing
                                          sometimes there is coding
                                          • A
                                            Alyx @sdetweil
                                            @sdetweil No worries I’ll install and play around with this tomorrow, I was wondering if it would help with setting up modules to talk to each other, as you know I’ve been having a few issues with that xD
                                            • 14
                                            • 15
                                            • 5 / 15
