    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.9k Views 31 Watching
    • uros76U
      uros76 @sdetweil
      @sdetweil yes the module shows on screen in form of QR code. That part works.
      My basics from config file:
      address: "0.0.0.0",
      useHttps: false,
      port: 8080,
      ipWhitelist: [],
      • uros76U
        uros76 @sdetweil
        @sdetweil ok will send you now…
          sdetweil @uros76
          @uros76 thanks… there was probably an error reported in the console where u do npm start (or pm2 logs if using pm2)
            sdetweil @uros76
            @uros76 posted a fix, sent email back
            uros76U 1 Reply Last reply
            • uros76U
              uros76 @sdetweil
              @sdetweil it works! Mega quick assistance. Tnx
              • F
                Fonzi03
                i too am getting the blank homescreen which only shows
                “configure magic mirror and modules”
                it wont let me upload the jsconfig or default config here how can i send them?
                S 2 Replies Last reply
                  sdetweil @Fonzi03
                  @fonzi03 send to my same userid at gmail. have to rename them to .txt instead of .js to attach to email
                    sdetweil @Fonzi03
                    @fonzi03 i sent email back
                      Dinschal
                      I’m not able to pull your module from github. I got this error.
                      Greetings
                        sdetweil @Dinschal
                        @dinschal hm… I don’t see that
                        rename the module folder and and git clone again
                        then delete the old folder
                          Dinschal
                          There is no module folder…
                          Okay everything fine… i have to go to bed :D my fault sry :D
                          Change pull to clone and it works ;) too much code today.
                          I’m really sorry :(
                            sdetweil @Dinschal
                            @dinschal huh?
                            ah, I see… to get the 1ST copy you use
                            git clone
                            to UPDATE later you do
                            git pull
                            with no extra parms…
                            see the two topics in my signature… I didn’t write em, but they are helpful
                            D 1 Reply Last reply
                              Dinschal @sdetweil
                              @sdetweil thanks a lot… sometimes this is the best time to go to bed :D
                              my brain isnt working much longer today :D
                                sdetweil @Dinschal
                                @dinschal I’ve been there… get some rest
                                  Dinschal @sdetweil
                                  first of all… my english is very bad :D
                                  today my goal is that your module is working… i have configure it cause i have the mm with localhost and use bitvise for ssh.
                                  So i have to change the localhost in my config :D
                                  I tired to read the error message but its to tiny :D the only thing i can read is localhost :D
                                    sdetweil @Dinschal
                                    @dinschal said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                    I tired to read the error message but its to tiny the only thing i can read is localhost
                                    what error message?
                                    u mean the module output when address:“localhost” is set??
                                    localhost means ONLY apps running inside the SAME system can access
                                    so a phone (use the qr code) , or another computer (use the url) cannot…
                                      Dinschal @sdetweil
                                      @sdetweil yeah this one ;) i want to change it cause the mirror is a gift for my parents and if i had to change something i only have my phone.
                                      I changed it to 0.0.0.0 so i get the qr but know my device is not allowed to access my mirror :D
                                        sdetweil @Dinschal
                                        @dinschal also have to edit the ipWhitelist.
                                        I set it to []
                                        ipWhitelist:[],
                                          Dinschal @sdetweil
                                          @sdetweil i did it let me check ;)
                                          okay i got it… but now i only have the "configuration window without the possibility to configure,
                                          i tryed it with a new pull and an new installation of your module :(
                                          • A
                                            Alyx
                                            amazing work!!! are users able to make module communicate with each other? Such as using voice commands to use another module via notifications?
                                            • 14
                                            • 15
                                            • 5 / 15
