    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 480.4k Views 31 Watching
      sdetweil @Fonzi03
      @fonzi03 i sent email back
        Dinschal
        I’m not able to pull your module from github. I got this error.
        Greetings
          sdetweil @Dinschal
          @dinschal hm… I don’t see that
          rename the module folder and and git clone again
          then delete the old folder
            Dinschal
            There is no module folder…
            Okay everything fine… i have to go to bed :D my fault sry :D
            Change pull to clone and it works ;) too much code today.
            I’m really sorry :(
              sdetweil @Dinschal
              @dinschal huh?
              ah, I see… to get the 1ST copy you use
              git clone
              to UPDATE later you do
              git pull
              with no extra parms…
              see the two topics in my signature… I didn’t write em, but they are helpful
                Dinschal @sdetweil
                @sdetweil thanks a lot… sometimes this is the best time to go to bed :D
                my brain isnt working much longer today :D
                  sdetweil @Dinschal
                  @dinschal I’ve been there… get some rest
                    Dinschal @sdetweil
                    first of all… my english is very bad :D
                    today my goal is that your module is working… i have configure it cause i have the mm with localhost and use bitvise for ssh.
                    So i have to change the localhost in my config :D
                    I tired to read the error message but its to tiny :D the only thing i can read is localhost :D
                      sdetweil @Dinschal
                      @dinschal said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                      I tired to read the error message but its to tiny the only thing i can read is localhost
                      what error message?
                      u mean the module output when address:“localhost” is set??
                      localhost means ONLY apps running inside the SAME system can access
                      so a phone (use the qr code) , or another computer (use the url) cannot…
                        Dinschal @sdetweil
                        @sdetweil yeah this one ;) i want to change it cause the mirror is a gift for my parents and if i had to change something i only have my phone.
                        I changed it to 0.0.0.0 so i get the qr but know my device is not allowed to access my mirror :D
                          sdetweil @Dinschal
                          @dinschal also have to edit the ipWhitelist.
                          I set it to []
                          ipWhitelist:[],
                            Dinschal @sdetweil
                            @sdetweil i did it let me check ;)
                            okay i got it… but now i only have the "configuration window without the possibility to configure,
                            i tryed it with a new pull and an new installation of your module :(
                            • A
                              Alyx
                              amazing work!!! are users able to make module communicate with each other? Such as using voice commands to use another module via notifications?
                                sdetweil @Alyx
                                @alyx I don’t understand your question
                                  sdetweil @Dinschal
                                  @dinschal is this from the qr?
                                  or did u enter a url?
                                  note the url is
                                  http://mmipaddr:mmport/modules/MMM-Config/review
                                    sdetweil @Alyx
                                    @alyx voiceCommander is built on top of MMM-Voice and Hello-Lucy
                                    so, CAN you, certainly… take a voice audio -> recognizer -> send notification to other modules…
                                    HOW depends on the module being used…
                                    sometimes there is some config
                                    sometimes there is file editing
                                    sometimes there is coding
                                    • A
                                      Alyx @sdetweil
                                      @sdetweil No worries I’ll install and play around with this tomorrow, I was wondering if it would help with setting up modules to talk to each other, as you know I’ve been having a few issues with that xD
                                        sdetweil @Alyx
                                        @alyx My Module ONLY addresses configuration of EACH module (stuff that goes in config.js)
                                        what that stuff DOES/MEANS, my module does not know…
                                        I read the source code to figure out the variables defined
                                        and merge that with any info from config.js
                                        and build a form to collect the data
                                        then on save, I take the elements with data and build a new config.js
                                        (rename the old and write the new)
                                        and if restart , then I restart MM to use that new config
                                        • A
                                          Alyx @sdetweil
                                          @sdetweil Sounds great as is Sam cant wait to try it tomorrow!
                                            Dinschal @sdetweil
                                            @sdetweil ah okay i used the wrong one… i used the one with config.html
                                            • 14
                                            • 15
                                            • 5 / 15
