    Making text etc clickable
    14 Posts 3 Posters 11.5k Views 4 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @broberg
      @broberg when you save the interval into a variabke you can stop/clear the interval
      this.interval = setInterval(...);
      clearInterval(this.interval);
      • brobergB Offline
        broberg Project Sponsor @strawberry 3.141
        @strawberry-3.141 Sorry to bother you with the poking stick, but, I’m having no luck in getting it to work.
        this is the code that updates the newsfeed item
        	scheduleUpdateInterval: function() {
        		var self = this;
        		self.updateDom(self.config.animationSpeed);
        		setInterval(function() {
        			self.activeItem++;
        		}, this.config.updateInterval);
        This also loads the first feed item when the page loads for the first time.
        how should I implement this in another function to pause/reset the scheduleUpdateInterval function?
          @broberg
            var self = this;
            self.interval = setInterval(function() {
              self.activeItem++;
          pause: function(){
          resume: function(){
            this.scheduleUpdateInterval();
          • brobergB Offline
            @strawberry-3.141
            No go on that either, this.interval is undefined it says.
            I have to research this some more, it’s giving me a headache.
            Could it have something to do with the fact that the interval is set in the scheduleUpdateInterval function and it can’t be reached from another function outside that?
            this.scheduleUpdateInterval(); works, I think. (I get more updates on top of each other if I click several times)
              @broberg what about this?
              this.interval = setInterval(function() {
                  self.activeItem++;
              brobergB 1 Reply Last reply Reply Quote 1
              • brobergB Offline
                @strawberry-3.141
                using that code snippet in the pause function just adds a new item with the updateInterval time,
                So I can change the interval on the next loaded news item, but not the current :(
                • brobergB Offline
                  so after strawberry-pi explained the last snippet of code I got it to work,
                  Big thanks for the patience!
                  These are the changes I’ve made so far, please consider that the code is probably not optimal, at all.
                   			var title = document.createElement("div");
                  			title.className = "bright medium regular fed";
                  			title.innerHTML = this.newsItems[this.activeItem].title;
                  			title.addEventListener("click", () => showdesc(this)); //Show description on click
                  			wrapper.appendChild(title);
                  			//below is the function to show description and hide title
                  			function showdesc(thisdesc) {
                  				thisdesc.intpause();	//pause the interval
                  				title.style.display="none";
                  				description = document.createElement("div");
                  				description.className = "medium light infoCenter";
                  				description.innerHTML = thisdesc.newsItems[thisdesc.activeItem].description;
                  				description.addEventListener("click", () => hidedesc(thisdesc));  //Hide description on click
                  				wrapper.appendChild(description);
                  			//and to close the description and return to title
                  			function hidedesc(thisdesc) {
                  				thisdesc.intresume();	//resume the interval
                  				description.style.display="none";
                  				title.style.display="block";
                  • brobergB Offline
                    Changes to the scheduleUpdateInterval
                    		var self = this;
                    		// setInterval placed within a variable so you can clear it
                    			self.activeItem++;
                    And some functions to start and stop the interval
                    	intpause: function(){
                    	intresume: function(){
                    • brobergB Offline
                      Next up, adding a timer to the description that doesn’t mess with the news items that is next in line,
                      Tried one version, but it couldn’t handle multiple start/stop clicks.
