    Making text etc clickable
    14 Posts 3 Posters 12.6k Views 4 Watching
      broberg Project Sponsor
      I can report yes, it was a z-index issue.
      setting the region.fullscreen to z-index -1 made everything clickable.
      But I’ll probably just change the newsfeed to z-index 1
      I used a eventlistener to register the click and change the contents of this.innerhtml from title to description.
      Next up, make it draw a new div and pause the timer for the headlines.
        Any suggestions on how I pause the updateInterval ?
        I’ve tried just to change the var to another value when clicked, but it doesn’t change the current item interval.
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @broberg
          @broberg when you save the interval into a variabke you can stop/clear the interval
          this.interval = setInterval(...);
          clearInterval(this.interval);
            broberg Project Sponsor @strawberry 3.141
            @strawberry-3.141 Sorry to bother you with the poking stick, but, I’m having no luck in getting it to work.
            this is the code that updates the newsfeed item
            	scheduleUpdateInterval: function() {
            		var self = this;
            		self.updateDom(self.config.animationSpeed);
            		setInterval(function() {
            			self.activeItem++;
            		}, this.config.updateInterval);
            This also loads the first feed item when the page loads for the first time.
            how should I implement this in another function to pause/reset the scheduleUpdateInterval function?
            • strawberry 3.141S
              @broberg
                var self = this;
                self.interval = setInterval(function() {
                  self.activeItem++;
              pause: function(){
              resume: function(){
                this.scheduleUpdateInterval();
                @strawberry-3.141
                No go on that either, this.interval is undefined it says.
                I have to research this some more, it’s giving me a headache.
                Could it have something to do with the fact that the interval is set in the scheduleUpdateInterval function and it can’t be reached from another function outside that?
                this.scheduleUpdateInterval(); works, I think. (I get more updates on top of each other if I click several times)
                • strawberry 3.141S
                  @broberg what about this?
                  this.interval = setInterval(function() {
                      self.activeItem++;
                    @strawberry-3.141
                    using that code snippet in the pause function just adds a new item with the updateInterval time,
                    So I can change the interval on the next loaded news item, but not the current :(
                      so after strawberry-pi explained the last snippet of code I got it to work,
                      Big thanks for the patience!
                      These are the changes I’ve made so far, please consider that the code is probably not optimal, at all.
                       			var title = document.createElement("div");
                      			title.className = "bright medium regular fed";
                      			title.innerHTML = this.newsItems[this.activeItem].title;
                      			title.addEventListener("click", () => showdesc(this)); //Show description on click
                      			wrapper.appendChild(title);
                      			//below is the function to show description and hide title
                      			function showdesc(thisdesc) {
                      				thisdesc.intpause();	//pause the interval
                      				title.style.display="none";
                      				description = document.createElement("div");
                      				description.className = "medium light infoCenter";
                      				description.innerHTML = thisdesc.newsItems[thisdesc.activeItem].description;
                      				description.addEventListener("click", () => hidedesc(thisdesc));  //Hide description on click
                      				wrapper.appendChild(description);
                      			//and to close the description and return to title
                      			function hidedesc(thisdesc) {
                      				thisdesc.intresume();	//resume the interval
                      				description.style.display="none";
                      				title.style.display="block";
                        Changes to the scheduleUpdateInterval
                        		var self = this;
                        		// setInterval placed within a variable so you can clear it
                        			self.activeItem++;
                        And some functions to start and stop the interval
                        	intpause: function(){
                        	intresume: function(){
                          Next up, adding a timer to the description that doesn’t mess with the news items that is next in line,
                          Tried one version, but it couldn’t handle multiple start/stop clicks.
