    Making text etc clickable
    14 Posts 3 Posters 12.6k Views 4 Watching
      bhepler Module Developer
      You’ll probably want to create a customized version of the Newsfeed module. The part of the code that actually puts the text on the screen is in the newsfeed.js file, specifically in the getDom: function() {...} portion of the code.
      If you look at it, it’s already creating a <DIV> element and changing the innerHTML to the value of the title from the newsfeed (line 149) title.innerHTML = this.newsItems[this.activeItem].title; It should be relatively easy to modify this area of the code to add the anchor tag & url.
        broberg Project Sponsor @bhepler
        @bhepler said in Making text etc clickable:
        I’ve found the part where it creates the actual content, I’ve tried adding onclick to text, to buttons, tried making functions to act on the onclick event etc. maybe it’s a z-index issue and something is in the way. because it doesn’t react at all to any clicks. I tried the anchor tag just to see if it would react, but no. Something is blocking the “clickability” of the MM module
          I can report yes, it was a z-index issue.
          setting the region.fullscreen to z-index -1 made everything clickable.
          But I’ll probably just change the newsfeed to z-index 1
          I used a eventlistener to register the click and change the contents of this.innerhtml from title to description.
          Next up, make it draw a new div and pause the timer for the headlines.
            Any suggestions on how I pause the updateInterval ?
            I’ve tried just to change the var to another value when clicked, but it doesn’t change the current item interval.
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @broberg
              @broberg when you save the interval into a variabke you can stop/clear the interval
              this.interval = setInterval(...);
              clearInterval(this.interval);
                broberg Project Sponsor @strawberry 3.141
                @strawberry-3.141 Sorry to bother you with the poking stick, but, I’m having no luck in getting it to work.
                this is the code that updates the newsfeed item
                	scheduleUpdateInterval: function() {
                		var self = this;
                		self.updateDom(self.config.animationSpeed);
                		setInterval(function() {
                			self.activeItem++;
                		}, this.config.updateInterval);
                This also loads the first feed item when the page loads for the first time.
                how should I implement this in another function to pause/reset the scheduleUpdateInterval function?
                • strawberry 3.141S
                  @broberg
                    var self = this;
                    self.interval = setInterval(function() {
                      self.activeItem++;
                  pause: function(){
                  resume: function(){
                    this.scheduleUpdateInterval();
                    @strawberry-3.141
                    No go on that either, this.interval is undefined it says.
                    I have to research this some more, it’s giving me a headache.
                    Could it have something to do with the fact that the interval is set in the scheduleUpdateInterval function and it can’t be reached from another function outside that?
                    this.scheduleUpdateInterval(); works, I think. (I get more updates on top of each other if I click several times)
                    • strawberry 3.141S
                      @broberg what about this?
                      this.interval = setInterval(function() {
                          self.activeItem++;
                        @strawberry-3.141
                        using that code snippet in the pause function just adds a new item with the updateInterval time,
                        So I can change the interval on the next loaded news item, but not the current :(
                          so after strawberry-pi explained the last snippet of code I got it to work,
                          Big thanks for the patience!
                          These are the changes I’ve made so far, please consider that the code is probably not optimal, at all.
                           			var title = document.createElement("div");
                          			title.className = "bright medium regular fed";
                          			title.addEventListener("click", () => showdesc(this)); //Show description on click
                          			wrapper.appendChild(title);
                          			//below is the function to show description and hide title
                          			function showdesc(thisdesc) {
                          				thisdesc.intpause();	//pause the interval
                          				title.style.display="none";
                          				description = document.createElement("div");
                          				description.className = "medium light infoCenter";
                          				description.innerHTML = thisdesc.newsItems[thisdesc.activeItem].description;
                          				description.addEventListener("click", () => hidedesc(thisdesc));  //Hide description on click
                          				wrapper.appendChild(description);
                          			//and to close the description and return to title
                          			function hidedesc(thisdesc) {
                          				thisdesc.intresume();	//resume the interval
                          				description.style.display="none";
                          				title.style.display="block";
                            Changes to the scheduleUpdateInterval
                            		var self = this;
                            		// setInterval placed within a variable so you can clear it
                            			self.activeItem++;
                            And some functions to start and stop the interval
                            	intpause: function(){
                            	intresume: function(){
                              Next up, adding a timer to the description that doesn’t mess with the news items that is next in line,
                              Tried one version, but it couldn’t handle multiple start/stop clicks.
