    Bullseye
    45 Posts 8 Posters 24.4k Views 9 Watching
      sdetweil @bert269
      @bert269 don’t attach here… attach to the issue in github
        bert269 @sdetweil
        @sdetweil ok Sorry (is that why it’s not working…oops!)
        • BKeyportB Offline
          @sdetweil I don’t think you’re gonna be able to get around it.
          Manual install is failing too - apparently there’s a file in several packages that’s being locked by the system and causing errors in the nodejs installer.
          dpkg: error processing archive /var/cache/apt/archives/nodejs_14.18.1-deb-1nodesource1_armhf.deb (--unpack):
           trying to overwrite '/usr/share/doc/nodejs/api/embedding.json.gz', which is also in package nodejs-doc 12.22.5~dfsg-2~11u1
          dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
          Errors were encountered while processing:
          E: Sub-process /usr/bin/dpkg returned an error code (1)
          Any further installs will require this to finish, which won’t because of this error, etc.
          N S 2 Replies Last reply Reply Quote 0
          • N Offline
            nmwust @BKeyport
            @bkeyport
            Any chance you are using a full image and not a basic image. Thinking it may be related to the nodeRed install on the full image that is not there on the basic image. I hit what i think was the same error on a full image and had no problems if i swapped cards and went back to a basic image.
              sdetweil @BKeyport
              @bkeyport yeh, I installed nvm, then installed 14 and it was ok… then switched to 17 with nvm and its ok…
              not sure how to correct script yet
                I have updated the scripts… for bullseye…
                give it a try
                in each of the urls, replace master with bullseye to get the latest version
                for example install
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                replace master
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/bullseye/raspberry.sh)"
                raspiberry.sh, fixuppm2.sh and screensaver.sh have been updated
                let me know
                • BKeyportB Offline
                  Installing helper tools ...
                  Updating packages ...
                  [     <=>        ]Check current Node installation ...
                  Node.js is not installed.
                  Installing Node.js ...
                  chmod: cannot access '/usr/share/doc/nodejs/api/embedding.json.gz': No such file or directory
                  Reading package lists... Done
                  Building dependency tree... Done
                    libc-ares2 libjs-highlight.js nodejs-doc
                  Use 'sudo apt autoremove' to remove them.
                  The following NEW packages will be installed:
                    nodejs
                  0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                  Need to get 0 B/22.9 MB of archives.
                  After this operation, 116 MB of additional disk space will be used.
                  Selecting previously unselected package nodejs.
                  (Reading database ... 99829 files and directories currently installed.)
                  Preparing to unpack .../nodejs_14.18.1-deb-1nodesource1_armhf.deb ...
                  Unpacking nodejs (14.18.1-deb-1nodesource1) ...
                  node version is bash: line 227: node: command not found
                  bash: line 229: node: command not found
                  Node.js installation Done! version=
                  /usr/bin/env: ‘node’: No such file or directory
                  Minimum npm version: V6.0.0
                  Installed npm version: V
                  npm should be upgraded.
                  Installing npm ...
                  E: Unable to correct problems, you have held broken packages.
                  npm installation Done! version=V
                  Cloning MagicMirror ...
                  Cloning into 'MagicMirror'...
                  remote: Enumerating objects: 325, done.
                  remote: Counting objects: 100% (325/325), done.
                  remote: Compressing objects: 100% (290/290), done.
                  remote: Total 325 (delta 53), reused 146 (delta 22), pack-reused 0
                  Receiving objects: 100% (325/325), 477.94 KiB | 4.78 MiB/s, done.
                  Resolving deltas: 100% (53/53), done.
                  Cloning MagicMirror Done!
                  touch: cannot touch '/etc/chromium-browser/customizations/01-disable-update-check': No such file or directory
                  Installing dependencies ...
                  Unable to install dependencies!
                  log added to issue…
                    sdetweil @BKeyport
                    @bkeyport wonderful…
                      sdetweil @BKeyport
                      @bkeyport think I fixed it… give it a try, still bullseye in the urls
                      • bugsounetB Offline
                        bugsounet Banned @sdetweil
                        @sdetweil said in Bullseye:
                        @bert269 we need node 14 for MM… the bullseye is only node 12
                        are you sure ?
                          sdetweil @bugsounet
                          @bugsounet i get v12.22.5 right after boot up, image downloaded yesterday
                            sdetweil @bugsounet
                            @bugsounet did u select yes to install updates during setup? I selected no… do it later
                            reflashing SD card now.
                              I get on 1st boot after config, enabling ssh , and setting hostname
                              node -v
                              v12.22.5
                              cat /etc/apt/sources.list.d/nodesource.list
                              cat: /etc/apt/sources.list.d/nodesource.list: No such file or directory
                              ls /etc/apt/sources.list.d
                              raspi.list vscode.list
                                bugsounet Banned
                                curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                                can help ?
                                  sdetweil @bugsounet
                                  @bugsounet i got it in the latest script… different approach, but understand
                                  • O Offline
                                    OberfragGER @sdetweil
                                    Sorry for asking but i dont get the point.
                                    1 day before the release of Bullseye i installed busetr an used your script to get MM working. That worked flawless. Glad i made a backup then with my config.
                                    Days later, i upgraded to Bullseye and MM was not working any longer. I thought due some autostart things or something like that.
                                    When i now make a fresh bullseye install and use your script- is that working? No, or?
                                      sdetweil @OberfragGER
                                      @oberfragger yes, if you use the bullseye adjusted url (note the word master is replaced by bullseye i the url)
                                      I don’t want to break the current version while we test this out…
                                      I just updated the instructions with this link
                                        DJBOOB66
                                        Ok i tried
                                        And it did not work. What I did was use the master version then rename MM folder after install then use above code and then it work?
                                          sdetweil @DJBOOB66
                                          @djboob66 can u post the ~/install.log?
                                            DJBOOB66
                                            I have to do it again but will do it as soon as i can or is log found on file and were?
                                            • 2 / 3
